Old Apr 14, 2012, 02:43 PM
joyalflyer is offline
Find More Posts by joyalflyer
joyalflyer's Avatar
United States, MD
Joined Jan 2012
Help!
Dihedral of rubber powered plane
hi guys I am currently working on Messerschmitt rubber powered plane from Guillows and a Grumman F6F Hellcat. Both of these need a dihedral, but I am not quite sure how to do it. i have searched the internet but there isn't that much of any information or resources. So if you guys can help me that would be great?
joyalflyer is offline Find More Posts by joyalflyer
Old Apr 14, 2012, 04:57 PM
hastf1b is offline
Find More Posts by hastf1b
F1B is ok.
Monheim am Rhein Germany
Joined Jul 2008
I'm not sure if that helps here. http://www.youtube.com/watch?feature...JNmh_n44U&NR=1
http://www.hippocketaeronautics.com/...p?topic=9354.0
Heinz
hastf1b is offline Find More Posts by hastf1b
Old Apr 14, 2012, 05:52 PM
joyalflyer's Avatar
United States, MD
Joined Jan 2012
Thanks for the reply but I need more detailed information
Old Apr 14, 2012, 08:38 PM
scrubs is offline
Find More Posts by scrubs
scrubs's Avatar
United States, NM, Rio Rancho
Joined Dec 2004
Conventional wisdom is 1" per ft of span. But both are low wingers (could almost call the Hellcat a mid wing). So conventional wisdom there is wing tips a little higher than the thrustline.
Bruce will probably chime in with more info. Or maybe Yak52.
scrubs
scrubs is offline Find More Posts by scrubs
Old Apr 14, 2012, 09:47 PM
BMatthews is offline
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
Oh... OK... Since you mentioned me....
Joyalflyer, just to set the stage by starting with low wing scale models you're biting off a rather large hunk for one mouthful. Low wingers bring a lot of odd stability issues and greatly reduce the odds of success for those fairly new to rubber power. On top of this you're trying to also toss in the scale aspect. A double whammy against the chance of success.
To have a fighting chance of success you want to use enough dihedral that the wing tips come up to around half way up the canopy in each case. I know that is a lot and will make the model look funny. But it's going to give you, who is apparently a relative rubber power beginner, a fighting chance of flying decently.
If what you are asking is how to glue in the dihedral then I suggest you study the plan more. Typically the Guillow kits were good at showing a diagram of how to block up the wings to do the center joint with dihedral.
BMatthews is offline Find More Posts by BMatthews
Old Apr 15, 2012, 04:14 AM
Yak 52 is offline
Find More Posts by Yak 52
Yak 52's Avatar
UK
Joined Jan 2009
Could you be more specific in your question? Then a more detailed answer will be possible...
Are you asking a question about the design, ie what angles are neccesary?
Or are you struggling with the actual construction of the dihedral break of the wing?
As Bruce has said if you are just starting out, more dihedral will make trimming easier. You might have to compromise the scale looks a bit but at least you'll get it flying...
Yak 52 is offline Find More Posts by Yak 52
Old Apr 15, 2012, 09:36 AM
joyalflyer's Avatar
United States, MD
Joined Jan 2012
What I really want to ask is the actual break of the wing. I actually don't know how to do it?
Old Apr 15, 2012, 11:15 AM
B for Bruce
BMatthews's Avatar
Joined Oct 2002
There should be a sketch on the plans. But I agree that they are not allways that clear.
The classic way to do it is to make the two sides separately. Then with one still pinned to the building board to bring the other into place and raise the tip by twice the amount of dihedral you want and pack it there with a block of some sort. Pin the raised wing with pins near the center line to hold it and trim the spars as needed to achieve a good match. Then glue the ends together to hold things steady while you then glue the dihedral braces across the face of the butt joint. You definelty want some sort of wood to span the joint as the end to end butt joint has very little strength. Gluing a brace across the long grain faces is far stronger.
THe root rib has to be fitted in there at some point. It also has to be cut out to allow for the braces. When to add it is the question and it depends on how many upper spars you have. It's simply a question of when is the most convenient time to stick it in there without it getting in the way.
That help?
Old Apr 15, 2012, 01:22 PM
joyalflyer's Avatar
United States, MD
Joined Jan 2012
It helps a lot, but like video would be much better
Old Apr 16, 2012, 08:45 PM
Megowcoupe is online now
Find More Posts by Megowcoupe
Balsa Flies Better!
Stamford, CT
Joined Oct 2000
Another way to do it is pretty simple- just build in the dihedral like Bruce says- fit in the root rib- and add some gussets to the corners. Make sure that the grain runs along the long axis of the gusset.
However, while the Hellcat has a great planform for FF, Guillows designs generally suck- too much wood and too heavy. Try starting with a Golden Age Reproductions kit- the P-51 isn't too tough a build, and mine has everybody in WWII mass launch events indoors scared. (not of collisions, its the slowest plane up there.)
Sam
Megowcoupe is online now Find More Posts by Megowcoupe
Old Apr 18, 2012, 09:34 PM
B for Bruce
BMatthews's Avatar
Joined Oct 2002
I seriously doubt there's anything along the lines of a video on this sort of thing. Also there's so many options for what needs to be dealt with.
Sometimes you just need to walk the tightrope without the safety net.
Many of us here trying to help you did it ourselves with nothing more than a little planning and though before the internet, videos and You Tube were even something written about in Science Fiction. So just wade on in, the water is fine...
Old Apr 18, 2012, 11:21 PM
aeronca52 is offline
Find More Posts by aeronca52
Culper Junior
eastern pa
Joined Feb 2007
Here's something from Mike's Flying Scale Model Planes site. Proceed to chapter 6 on building wings and you will see some pictures on the dihedral subject. I'm cutting and pasting so I hope you see the right pages.
http://www.ffscale.co.uk/comp6.htm
And here's a place with lots of color pictures of models and a section with building tips (in the 'selection' box)
http://www.easybuiltmodels.com/
aeronca52 is offline Find More Posts by aeronca52
Discussion Request good airfoil for slowflying rubber powered Peanuts Dinser Modeling Science 25 Jul 07, 2012 12:45 AM
For Sale Comet rubber powered airplane kits auggiesp51 Aircraft - Electric - Airplanes (FS/W) 1 Feb 26, 2012 04:12 PM
Discussion Estes Rubber Band Power Flying Model Plane's aeronaught Free Flight 14 Aug 22, 2009 10:33 PM
Sold hand built micro rubber power for RC conversion! ---------- Bi-Plane termite Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Apr 12, 2009 09:49 PM
Hobbico P-51 Mustang Rubber Power Plane Conversion Aaron13 Beginner Training Area (Aircraft-Electric) 2 Aug 16, 2002 04:08 PM
