There IS that Hammond 1455T1601 case you could try...
Dear Frank Hurd:
The PIPE Here, and when I spotted this thread and your desire to make yourself a KNOBBY RC radio (alternative name for a "single stick" radio, from its RUDDER KNOB atop the single joystick shaft) I literally "homed in" on your quest... ...and if you get a gander at the Adobe Reader PDF file I've attached, it's for the Hammond 1455T1601 case, an ideally sized 6-1/2 by 6-5/16ths by 2 inch dimension aluminum case from Hammond Enterprises of Canada. Both Digi-Key and Mouser have this case, and it's about $27.00 or less for one of these. British Columbia, Canada RC flier ANDY HORKA (RCGroups own "Jazzboy") has already used at least two of those cases for his own 2.4 GHz SpredSpec knobby radios that he's built at his blog...give those a good look, and see if you can use one of these yourself for your METAL knobby radio case needs! Sure hope this helps... Yours Sincerely, The PIPE.. ..!!
| Thread Tools | |
| Sold Sullivan 468 aluminum fuel tank stopper | marksextra | Aircraft - Fuel - Engines and Accessories (FS/W) | 1 | Feb 23, 2012 09:04 PM |
| Sold Aluminum Body Posts, Frame Spacers & 44 Aluminum Washers | Dave8888 | Aircraft - Electric - Helis (FS/W) | 2 | Dec 22, 2011 01:52 PM |
| For Sale Blade cx2 lower aluminum head set and aluminum swashplate + more | HyperHelis | Aircraft - Electric - Helis (FS/W) | 2 | Mar 27, 2010 07:00 PM |
| For Sale KMP Tornado CP 400 ARF Blowout - Aluminum Head, Aluminum Case | realdeal | Aircraft - Electric - Helis (FS/W) | 3 | Oct 26, 2006 12:51 PM |
| Bonding Aluminum to Aluminum | RGinCanada | Dock Talk | 19 | Nov 05, 2004 06:59 PM |
