Old Apr 14, 2012, 04:01 AM
Gravity_Works is offline
Find More Posts by Gravity_Works
United States, TN, Brentwood
Joined Nov 2011
Question
Tightening Ultracote/Monokote Before Flying
My apologies if this is a silly question, but I built an ARF plane from Electrifly and the instructions came with a separate insert that says I need to iron my plane before trying to fly it. I'm supposed to go buy a special mini iron and go over the entire surface of the plane, which it says should take about an hour. Is this really necessary for aerodynamic purposes, or is it mainly aesthetic, or is it a prank being played by bored design engineers? ("Hey Bob, I wrote in the instructions that they have to sing to it in order to calibrate the framjibulator!" ... "That's nothing, I told them they have to iron it! Buahahaha!"
So, if I really do need to iron it, how do I know when it's done? I think it looks fine, seeing as it's brand new, and I don't even iron my clothes most of the time, much less my toys
Gravity_Works is offline Find More Posts by Gravity_Works
Old Apr 14, 2012, 04:20 AM
fmw is offline
fmw
Find More Posts by fmw
fmw
fmw's Avatar
Joined Jul 2009
Some models wrinkle more than others. You can ignore it if you like or heat the covering to stretch out the wrinkles as you prefer. Some use a heat gun but you should note that heat guns have the power to melt covering if overused.
fmw is offline Find More Posts by fmw
Old Apr 14, 2012, 04:22 AM
solentlife is online now
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
Most iron on coatings are a touch slack when sent from factory .. and a quick wipe over with an iron or heat gun just tightens up that small amount.
There's no need for a special iron ... a domestic iron set about mid-heat is fine. But make sure you clean it BEFORE and AFTER ....
Another way - which is what I do ........ take a hot-air blower that does paint stripping and carefully WAFT it over ... do NOT stay in one place or you will burn through ! Just waft it all over to tighten up ... and make sure you waft one side - then other and back again ... so yuou do not stress one side more than other.
If you are going to fly iron on film models - then it's worth getting the Model grade hot-air gun ... and a small domestic non-steam iron .... then you don't upset wife with smudge marks on iron sole !
solentlife is online now Find More Posts by solentlife
Old Apr 14, 2012, 07:32 PM
VENOMiTry is offline
Find More Posts by VENOMiTry
United States, MD, Glen Burnie
Joined Mar 2012
yea i say use a heat gun just be careful at first and keep moving with it or it will melt but a iron can make a wrinkle permanent cause sometimes it doesnt shrink it will just make it flat but will still have the wrinkle there so use a heat gun and just keep it far at first then ease it till you find the perfect distince and yes most manuals show a iron going over the gaps on the ailerons and certain corners of the plane but ive never done that cause i never had too
VENOMiTry is offline Find More Posts by VENOMiTry
Old Apr 14, 2012, 07:34 PM
dkrhardy is offline
Find More Posts by dkrhardy
United States, FL, The Villages
Joined Oct 2010
Use the iron on the places where the skin touches wood/balsa. That seals it so you can then use a hot air gun to shrink the skin.
Don
dkrhardy is offline Find More Posts by dkrhardy
Discussion Ultracote vs Monokote Wings of Balsa The Builders Workshop 23 Aug 22, 2015 02:25 PM
Question How long before flying should I charge? Jus Wanna Fly Batteries and Chargers 18 Dec 19, 2011 09:49 PM
Question Monokote vs ultracote? Advices please Turqui Painting and Finishing Tips 2 Nov 22, 2011 09:59 AM
Flying befor the rain kestrel2003 Parkflyers 3 Sep 28, 2003 01:29 PM
Alternatives to tape and ultracot DocMac Foamies (Kits) 0 May 25, 2001 07:45 PM
