Old Apr 13, 2012, 11:57 PM
Litchking is offline
Find More Posts by Litchking
Litchking's Avatar
Joined Nov 2011
What is the critical temperature (or ambient temperature) for foam?
Hi Guys, I have a curious question....with the weather getting warmer,...what is the critical temperature for those EPP/EPO foam before they start to deform? Sometimes I tend to leave my foamie in the car...
Litchking is offline Find More Posts by Litchking
Old Apr 14, 2012, 12:23 AM
elfwreck is offline
Find More Posts by elfwreck
elfwreck's Avatar
United States, CA, Oakland
Joined Dec 2002
Hey now,
In summer just about anywhere in the US it can get hot enough in a car to soften the foam enough to warp or droop. Especialy if you put it in the trunk.
While driving it's not often an issue. Nor is it if you're just stopping at a shop or something. But an hour or two is about the safe maximum generally speaking.
RobII
elfwreck is offline Find More Posts by elfwreck
Old Apr 14, 2012, 05:24 AM
DeeBee1 is offline
Find More Posts by DeeBee1
DeeBee1's Avatar
United Kingdom, England, Brighton
Joined Apr 2007
It's not just the actual plane you need to watch. Foam sticky backed tape holding servos and receivers can also come loose when the weather is very warm.
DeeBee1 is offline Find More Posts by DeeBee1
Old Apr 15, 2012, 10:23 PM
Endlesslag is offline
Find More Posts by Endlesslag
Fly it like you STOL it!
Endlesslag's Avatar
United States, FL, Orlando
Joined Jan 2011
And hot glue will soften! I know this from experience
Endlesslag is offline Find More Posts by Endlesslag
Old Apr 17, 2012, 09:46 PM
Litchking's Avatar
Joined Nov 2011
wow...thanks for the info...will definitely keep these in mind
Old Apr 17, 2012, 10:05 PM
Foambird is offline
Find More Posts by Foambird
St. Louis
Foambird's Avatar
USA, MO, Ballwin
Joined Mar 2010
Warm Foam
There isn't a crtical temp. Just realize that a foam airplane exposed to extremes of sun will warp and flex.
I set my foamies in the sun for 15 minutes or so to let them adjust. There are trim changes you will need to make depending on the weather.
Foambird is offline Find More Posts by Foambird
Discussion What should be a good goal for temperature readings on a Savage? TamALEX Off-road Cars 1 Feb 22, 2012 05:51 AM
Discussion What's the coldest temperature soulreaper Multirotor Talk 2 Jan 04, 2012 02:27 PM
Discussion Using High Temperature Films on Foam for Trim hoppy Painting and Finishing Tips 0 Dec 11, 2011 10:05 PM
EasyBox 280 plans - looking for some review/critic Inflexo Parkflyers 102 Jul 10, 2004 09:55 PM
Step down transformer - in ambient state - what's happening? Moogee Life, The Universe, and Politics 3 Oct 31, 2002 02:07 PM
