Old Apr 13, 2012, 09:28 PM
PeTeR Loats is offline
Find More Posts by PeTeR Loats
Melb, Aus
Joined May 2008
Wing area vs Elevator area
Don't know if here or the builder workshop is the right place to post, but
Is there an ideal ratio for wing area compared to horizontal stabilizer?
PeTeR Loats is offline Find More Posts by PeTeR Loats
Old Apr 13, 2012, 09:54 PM
Piece is offline
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
It depends on the type of plane and the flying style.
There are some basic ratios or rules of thumb that people have cooked up, but they're pretty much made to be broken.
Piece is offline Find More Posts by Piece
Old Apr 14, 2012, 12:50 AM
elfwreck is offline
Find More Posts by elfwreck
elfwreck's Avatar
United States, CA, Oakland
Joined Dec 2002
Hey now,
While there are plenty of variables for a average sport or stunt model with um, normal proportions. Twenty percent of the wing area minimum for stable flight. Average is twenty five percent and thirty is huge. Often race or speed models will have long fuses and not need so much control so they may get down to fifteen percent. The longer the tail the smaller the stab can be if you don't care much for aerobatics.
If you get much more than square in tail length you get so much stability you can't stunt. Notice that most pattern ships are square. That is the wing span and fuse length are the same. Much shorter you start to get twitchy. Much longer, no stunts. Get it? Other than that if it looks about right it'll fly about right.
Now. Get busy designing.
RobII
elfwreck is offline Find More Posts by elfwreck
Old Apr 14, 2012, 07:39 AM
flypaper 2 is online now
Find More Posts by flypaper 2
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
The full size Zero fighter had a relatively oversized stab. One of the reasons it was so agile and makes a good model.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old Apr 14, 2012, 08:15 AM
Scaledown is offline
Find More Posts by Scaledown
It must have a machinegun
Scaledown's Avatar
Perth, Western Australia
Joined Sep 2004
The smallest tail in my fleet is 15%. It flies OK. The rest are in the region of 20%.
Scaledown is offline Find More Posts by Scaledown
Old Apr 14, 2012, 09:12 AM
JetPlaneFlyer is offline
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
Around 20% is typical for a 'normal' configuration.. But the tail area can vary from 0% (flying wing) to a several hundred % (canard).. and all points in-between.
JetPlaneFlyer is offline Find More Posts by JetPlaneFlyer
Old Apr 14, 2012, 12:20 PM
Threshold is offline
Find More Posts by Threshold
Threshold's Avatar
London UK
Joined Jul 2004
depends on the length of the fuz. Bewteen 20% to 25% and 12% for the vertical stab (tailfin and rudder) normal type plane.
Threshold is offline Find More Posts by Threshold
Old Apr 15, 2012, 02:02 AM
Melb, Aus
Joined May 2008
Thanks for the info, Ive had this design for awhile, but the tail never quite looked right to me, I do want it to do aerobatics so ...
Old Apr 15, 2012, 05:13 AM
Scaledown's Avatar
Joined Sep 2004
The tail looks fine but its a bit close to the wing. I would lengthen the rear fuselage by around 50%. Otherwise it will be very twitchy in pitch and you will find it hard to do smooth aerobatics.
Old Apr 15, 2012, 06:49 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Suggest you study the plan view of multiple model types - sailplanes, pattern aircraft, 3D - and consider their flying styles while you're at it.
..a
Old Apr 15, 2012, 08:33 AM
Aberdeen
Joined Mar 2006
+1, it looks like a nice design but it is very short coupled. Typically the gap between the TE of the wing and the LE of the tail is at least 1.5 x wing chord. Short coupled planes can fly ok but longer coupling gives more stability.
Discussion Good wing loading ratio (weight to wing area) Pinky_d_brain Beginner Training Area (Aircraft-Electric) 5 Apr 07, 2012 02:59 PM
Discussion what is habu wing area ? for wing loading calc ? rcfun2005 Electric Ducted Fan Jet Talk 1 Mar 03, 2012 04:35 PM
Question wing incidence on scratch built vs. elev.travel meldar9 Electric Plane Talk 6 Oct 23, 2006 08:26 PM
Question Wing Area vs. Wing Loading inquary!! FlattyFlier Electric Plane Talk 7 Nov 12, 2004 06:05 PM
Question Tail area vs wing area target Slope 4 Nov 26, 2003 07:44 PM
