Apr 13, 2012, 08:52 PM
Joined Feb 2006
I need some help on a prop size and opinion if its going to work or not
I bought a foremost 160 from nitroplanes. ITS a big big jet. I dont want to make it edf but will put a turbine in it later. I wanted to know if I can do a pusher prop application on it. I will make the mount for the motor my question is if Im using a large 120mm edf motor with a 8mm shaft with a 935kv what size prop can i put on it. I was using this motor on 12s on a edf fan, but i know prop will be more efficent so i wanted to keep it light and use less cells. Please let me know your thoughts.
