Old Apr 13, 2012, 08:44 PM
HerrMueller is offline
Find More Posts by HerrMueller
Germany, BW, Freiburg
Joined Apr 2012
Idea
Collection and discussion of hacks, mods, improvements for KEYCAMS & other MiniCams
If you have a Hack or a Mod or an Add-On (electronic or mechanical)
* additional electronic circuits
* batterie / power supply
* mounts
* casings
* lenses ...
for a Keycam or another MiniCam, please share it with us and post it here.
Please do not only post a Photo, but also describe how you made it.
Users of the camera for all types of application are welcome.
This thread has been created in order to relieve the Keycam # 11 and #16 thread, and that the projects will be found more quickly. . xchm28x
HerrMueller is offline Find More Posts by HerrMueller
Old Apr 13, 2012, 08:46 PM
Joined Apr 2012
List of Projects
electronic (ÁC):
wszim:..#16...........................hack for remote controlled "on, fixed recording time, auto off" function. Microprocessor programming and soldering skills required!.
electronic:
bobflyman:..#11,#16.............Time Lapse 808 Camera Mod with a 555 Relay Timer Module
doctormord:..#11...................Adding an LED to indicate the camera is in record mode.
Peterschecke:..#16,#18.........Attaching a bigger LiPo Accu , with Photos
mechanical:
timetec:.. #11,#16.................hack to improve visibility of the three colored LEDs. Step by step guide with photos
wszim:..all 808.......................making a LED Light Pipe. Photos of another Version with the Led on the side
lenses:
timetec: ..#11,#16,#18.........hack to make lens re-focusing much easier. Step by step guide with photos
timetec:.. all 808...................M12 Lens Adaptor
isoprop:..#11........................Relocate the lens by 90 deg. to point out the wide side of the case.
timetec:..#16,#18.................OV9712 Sensor Extension. Step by step guide with photos
wszim:..all 808......................How fit a wide angle lense to an 808 camera. Step by step guide with photos
cases:
jlogres:..all 808......................Underwater - Diving case for 808. Video
mounts:
wszim:..all 808......................A car holder / stand with desired angles, easy to build. Step by step photos
thwaitm:..all 808...................magnet and fuel tube mount. text & photos
Peterschnecke:..all Cams....vibration damping mount, cheap and easy. Step by step guide with photos
theWolfTamer:.MD80/D001.Tripod Mount. Step by step guide with photos
knowledge:
HerrMueller:..#18, #1080......Pinout of the AV Cable #18 and #1080
Old Apr 13, 2012, 08:47 PM
Joined Apr 2012
Recently added links:
theWolfTamer:..MD80/D001...Tripod Mount. Step by step guide with photos
Old Apr 13, 2012, 08:52 PM
Joined Apr 2012
Announcement:
coming soon ...
A control unit with ÁC for the Keycam #16
Old Apr 14, 2012, 05:54 PM
jglenn is offline
Find More Posts by jglenn
Ohio
Joined Nov 2003
I don't have any camera hacks, but will say that the MD80 is great, start with it.
I tried a few different small cameras, all were bad except for this one. I paid $50.
http://www.gizmag.com/md80-micro-vid...m-cheap/13877/
jglenn is offline Find More Posts by jglenn
Old Apr 16, 2012, 09:53 AM
thwaitm is online now
Find More Posts by thwaitm
Team WarpSquad
United Kingdom, England, Royal Leamington Spa
Joined Jun 2011
808 - magnet and fuel tube mount
I've used silicone fuel tube CA'd to the camera housing in one instance. It clips front and back to two 1mm CF rods which stretch across my little heli's landing gear.
The idea was to have a quickly attachable/detachable camera which would end up pointing straight forward/the same direction each time.
Unfortunately, the tubing isn't really stiff enough to hold it against the vibrations and it needs at least an elastic band over the top especially in idle-up.
There's possibly more distance in securely fixing the rods to the camera and then sliding them into some tubing or sliding tubing over the camera rods attaching them to the heli. I've not quite made that design yet.
The second method I tried was a couple of 2g neodymium-iron-boron magnets shoegooed to the casing and then a matching pair glued to the heli. I attached them to the other magnets and then put goo on the heli and the back of the magnet. After it cured it actually provides a very solid mount but it's a little too far forward of the CoG and therefore suffers from vibrations/jello.
The magnet mount would be good for attaching to a car/anything steel (careful about scratching the paint though).
Neither of them are perfect but they are very easily fixed and removed and give reasonable video - maybe better if I could really dial out the vibes from my heli.
This video is from my V200D01 with shaved blades and therefore higher headspeed, video is better with these modded blades but flight characteristics and times are not - especially with the extra weight of the camera.
MINI0002.avi (1 min 58 sec)
thwaitm is online now Find More Posts by thwaitm
Old Apr 16, 2012, 01:51 PM
wszim is offline
Find More Posts by wszim
Polska, małopolskie, Nowy Sącz
Joined Dec 2011
Originally Posted by HerrMueller View Post
Thanks to wzim and the other posters. Your doing a great job for the community.
my nick is wszim he he
Announcement:
coming soon ...
I'm very intrigued. What will this do?
wszim is offline Find More Posts by wszim
Old Apr 17, 2012, 08:11 AM
Peterschnecke is offline
Find More Posts by Peterschnecke
Peterschnecke's Avatar
Joined Mar 2012
Cheap an easy to build vibration damping mount
I wanted to have a mount that I can attach securely and also damps the damn vibrations on my motorbike.
What you need:
2 M5 screws
2 self-locking nuts
some Aluminium
4 earplugs
superglue
costs should be less than 10 $
How to do it:
Cut 2 pieces of alumium that have the same dimensions and a third one that is the half the length of the other two. Cut out some space for the buttons of the camera and you are almost ready.
Now glue the earplugs between the first two aluminium parts and your vibration damper is ready. The third pice of aluminium will be screw on top and hold the camera in place.
Feel free to add anything you need to attach the mount where you want it. I added another plate to mount it on the footrest of my bike. But you could also use a magnet i.e. out of an old harddrive to stick the mount to any metal.
Result:
A comparison between velcro and the earplug damper with the #3
808 #3 with and without vibration damper (5 min 35 sec)
Also works just fine with the #16
34PS Fireblade auf Landstraßen unterwegs HD (2 min 57 sec)
Peterschnecke is offline Find More Posts by Peterschnecke
Old Apr 19, 2012, 02:11 PM
fmkit is offline
Find More Posts by fmkit
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
today I replaced 6mhz crystal with 10MHz clock
http://www.youtube.com/watch?v=PczYhdhCaQc
fmkit is offline Find More Posts by fmkit
Old Apr 20, 2012, 07:50 PM
Cougar429 is online now
Find More Posts by Cougar429
Cougar429's Avatar
Canada, ON, Windsor
Joined Apr 2008
fmkit, what advantage does the overclocking give you?
Cougar429 is online now Find More Posts by Cougar429
Old Apr 21, 2012, 05:59 PM
fmkit is offline
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
when you chase other plane or birds, or crash there will be almost 2x frames that you can step/notice, something like "matrix" and "Inception" movies
many players can speed up playback then overclocked movie looks normal
Old Apr 21, 2012, 10:12 PM
Mtz is offline
Mtz
Find More Posts by Mtz
Mtz
Mtz's Avatar
Romania, PH, Ploiesti
Joined Mar 2012
I am thinking to use some mini USB connector to "Mount & connect«" the camera in the car.
enjoy,
Mtz
Mtz is offline Find More Posts by Mtz
Old Apr 22, 2012, 02:08 AM
camcc is offline
Find More Posts by camcc
Joined Mar 2012
808#16: Half of a solution and half of problem...need some info/help
Hi,
I successfully assembled one of the MintyBoost:
http://www.ladyada.net/make/mintyboost/
If the LiPo of my 808 #16 is emptied it is possible to use this charger as
an external power supply -- I was able to record over one hour of video
until the SD card was full.
It is also possible to charge the camera if the LiPo is emptied -- but it stopps charging very soon.
When connecting the camera to the PC then, charging continues i.e. the LiPo was not fully charged by the MintyBoost.
If the LiPo is only partly discharged, it is no problem to charge it with the PC, but
it is not possible to do the same with MintyBoost.
MintyBoost offers 5V at 500mA. I measured the voltage and it is ok.
For all tests the same USB-cable was used.
Now I am a little bit off ideas...
Since 5V/500mA is exactly according to USB standards I dont know how to convince MintyBoost to charge my camera or to convince the camera to accept MintyBoost as a charging/external power supply if the LiPo is partly discharged.
Any idea is heartly welcome!
Thank you very much in advance for any
help.
Best regards,
camcc
camcc is offline Find More Posts by camcc
Old Apr 22, 2012, 06:10 AM
Mtz is offline
Mtz
Mtz
Mtz's Avatar
Joined Mar 2012
I am not good in electronics but maybe you can ask if you can use another micropower boost instead of LT1302, to provide 1A not 500mA.
Mount & Safe «
Easy assure your camera in 2 seconds.
Or if you use some tic tac box you can use it and also assure the "treasure".
enjoy,
Mtz
Last edited by Mtz; Apr 23, 2012 at 07:27 PM. Reason: Added the Mount & Safe advanced technology ;)
Old Apr 23, 2012, 04:29 AM
midelic is online now
Find More Posts by midelic
midelic's Avatar
Joined Apr 2012
Has somebody a schematic circuitry of #16 camera ?I'm interested only the charging circuit of the LIPO battery from miniusb female connector to battery plug(including the green LED).
midelic is online now Find More Posts by midelic
Discussion Blade MCX 2 general discussion, mods, DX6i settings + more valiantGLX Coaxial Helicopters 981 May 11, 2016 12:58 PM
Mini-HowTo DIY Internal antenna mod for Futaba 8FG and others vespa Radios 47 Dec 08, 2014 09:40 AM
Suggestion Heads up about possible virus/hack for mods and users HappyKillmore Site Suggestions / Complaints 3 Dec 31, 2011 08:08 AM
Discussion Heres something interesting, keycam mod Arley FPV Talk 8 Aug 17, 2010 01:29 PM
