United States, ID
Joined Apr 2007
I just got one from Horizon.........haven't built it yet but, I've looked it over and fitted the pieces together. It will build very light......no doubt the battery has to be in the nose to get close to CG..........not sure the battery will be enough to get it to balance. I would hate to stuff lead in the nose but it might need some. With the tow release set up, there isn't a lot of room in the nose to work with. I'm sure the AUW ready to fly will be less than 7lbs...........not bad for a 10ft wing. The plane is actually built quite well for the money. I was pleased with it.
C of G
Don't want to contradict Rossco, because he has a ton of experience, (but I'm about to do so) regarding CG on this aircraft, but as the Ka6, Ka8, ASK18, etc. all have a straight leading edge with a swept-forward trailing edge, the effect is that of a swept-forward wing. In other words, the C of G is further forward than it would be on a wing where the spar sticks out at 90 degrees from the fuselage and the tip rib is nicely in line with the root rib. I've seen a couple of scary maiden flights on ASK-18's where they were balanced at 33% because that is the rule-of-thumb, and it is close to unworkable. For the forward swept wing, I would start at about 28% and work back as you fly the plane and become comfortable with it. Nose heavy works....tail heavy potentially becomes a bag of balsa.
Try this CG calculator when you get your plane: http://adamone.rchomepage.com/cg2_calc.htm CG is not a function of airfoil, it is a function of planform, and this will give you a head start on a successful first flight. Just sayin'....... Dave Smith |
Just got one from Horizon Hobby also. Picked up the white one. Been eying this over on the U.K. site of flea bay. Cost was just astounding to get it over here in the U.S. Finally someone had them here.
Couple of quick questions for you guys. Anyone using micros in the wings and full size in the fuselage, or is it micros all the way around? The instruction show something like HS425BB for rudder and elevator. Also, has anyone thought about adding blade type spoilers over the standard flip style spoilers? Reasons for either? Over all the kit looks very well made. Finish is great so far. will keep along for any other news or ideas. Thanks. tink |
| Thread Tools | |
| New Product Horizon Hobby/Seagull Ka8-B | R.M. Gellart | Scale Sailplanes | 0 | Mar 01, 2012 02:47 PM |
| Discussion Esprit Ka8-b | harrye | Scale Sailplanes | 4 | Oct 18, 2011 11:26 AM |
| For Sale !!! NEW PICS Robbe ash 26-e 4.5 meter arc n.i.b. | FLYBABE | Aircraft - Sailplanes (FS/W) | 10 | Sep 27, 2011 10:13 PM |
| Discussion Electrifying a 1:4 vintage Ka8 | GNieuwoudt | Scale Sailplanes | 16 | Sep 15, 2011 12:16 PM |
| Discussion Electrifying a 1:4 vintage Ka8 | GNieuwoudt | Electric Sailplanes | 3 | Sep 11, 2011 12:17 PM |
