The last time that happened to me, I accidentally plugged in the power supply (Battery/ESC) backwards. Reverse polarity will quickly heat up a receiver and destroy the circuit.
Please check if you accidentally plugged in the Batt/ESC with incorrect polarity. Even plugging in one correct polarity and the other to the Signal connection can ruin a receiver. Perhaps Spektrum has a safeguard against this, I don't know. If so, then yours could be a different problem. |
is it just slightly warm to the touch, or more warm to hot. if it's just slightly warm to the touch, I'd say it's perfectly normal. I'd start plugging in servos and see which one one causes it to get hot. |
OK. sounds like you have nothing to lose at this point, so try plugging the battery in reversed. If the battery was made with the connector and wires backwards then everything should work.
Otherwise you need to determine which pin on your esc is positive and which is negative then make sure the battery + and - are connecting to those pins. On your ESC, the inside pin should be negative and one outside pin will be positive and the other outside pin will be the signal pin. |
Joined Jan 2012
a question to you tat has not been asked.What kind of batt are you using.If the burst rate is to high it might be the reason it is over heating.I can remember if the cub is a 7.4v or a 11.1v
if it is a 11.1v the better batt will be something like a 3s 20cell 1200 - 1600 MAH.If you are using something like a 4s batt that can be the reason the burst rate will be to high |
| Thread Tools | |
| Whoops! Obama gets bit by the 'ol hot mic'.... | SKYPILEIT | Life, The Universe, and Politics | 82 | Apr 09, 2012 04:04 AM |
| Discussion Computer getting hot with RF 6 | Ernie Misner | Simulators | 17 | Mar 27, 2012 09:13 AM |
| Discussion Align K10382A 6A External BEC getting realy HOT | hotdog1 | Electric Heli Talk | 27 | Sep 16, 2011 10:24 PM |
| Help! Motor getting way too hot - why?? | pureguava | Power Systems | 6 | Sep 05, 2011 09:34 AM |
