Old Apr 13, 2012, 01:49 PM
Pandissix is online now
Find More Posts by Pandissix
Pandissix's Avatar
United States, CA, Ladera Ranch
Joined May 2007
TAM A-4 EDF Project
I thought it would be interesting to show a refurbish and over haul on a old Tam Jets A-4. This was a Turbine version, that with the help of "AirSally" we ended up modifying for EDF. New inlet cheeks for EDF were put on and ducting was made by AirSally.
This set up is using the XPS fan, Castle HV160 and TP 6500 12S 45C packs.
Pandissix is online now Find More Posts by Pandissix
Old Apr 13, 2012, 01:50 PM
Pandissix's Avatar
Joined May 2007
Took some video of the maiden flight, with Jeff Fassbinder doing the honors. Very solid performance. Only snag was a axle/wheel issue that I will document later.
A 4 Skyhawk from Tamjets (5 min 38 sec)
Old Apr 13, 2012, 01:54 PM
Pandissix's Avatar
Joined May 2007
The A4 is a poplular jet here at PVMAC field...as you can see...a few of us have the same scheme...and there are a few more that werent here this day.
Old Apr 13, 2012, 01:56 PM
Pandissix's Avatar
Joined May 2007
I decided to re-paint the A4 to something a bit different. First idea was to go with VT-24 shown here...with my brother who flew this for the Marine Corps back in the 1980's, but decided its the same training command scheme and wanted something a bit different.
Old Apr 13, 2012, 01:59 PM
Pandissix's Avatar
Joined May 2007
Did some searching around and decided to re-paint this in the Navy Agressor SQD, Top Gun school scheme. A bit different and with a sinister style....if you know me, I dont keep anything ARF...and if its not Luftwaffe...is gotta be something dark.
So with the help of Todd Burley...we are going with this new scheme.
Old Apr 13, 2012, 02:01 PM
Pandissix's Avatar
Joined May 2007
Yes...I know mine has the ECM hump....as was pointed out when I picked this scheme...but not going for true scale....this is just for fun and having a new paint scheme.
Old Apr 13, 2012, 02:07 PM
tburley is offline
Find More Posts by tburley
Bakersfield, CA
Joined Sep 2003
oh..............thats the paint scheme.
I thought you only wanted me to wash the plane
tburley is offline Find More Posts by tburley
Old Apr 13, 2012, 02:08 PM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
what was your all up weight with the 120
jcdfrd is offline Find More Posts by jcdfrd
Old Apr 13, 2012, 02:12 PM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
Good to see it fly ,it has a nice turbinelike sound . what was the all up weight?
AIR SALLY is online now Find More Posts by AIR SALLY
Old Apr 13, 2012, 02:22 PM
jefffassbinder is online now
Find More Posts by jefffassbinder
jefffassbinder's Avatar
United States, CA, Chino Hills
Joined Jan 2011
Nice looking scheme
That bird flys good, all Tams A4s fly good with the dynamax and xps your 18 lbs range. Go to the dr tam100 your 15 lbs same bird. I must admit I like it at the lower weight, especially in turns. Well Todd is bad ass with paint and prep.
jefffassbinder is online now Find More Posts by jefffassbinder
Old Apr 13, 2012, 02:49 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
John it's a full size Dynamax 127mm. i bet it is 18 ish lbs.it was a turbine build to start with .
Old Apr 13, 2012, 07:26 PM
bidule is online now
Find More Posts by bidule
jean-claude Terrettaz
bidule's Avatar
Carp, Ontario, Canada
Joined Mar 2000
Nice to see this post . I'm almost ready ( the Jet is ready not me!) to maiden mine.
Fan is a TJ 120 and CC HV 120 and 12 GEN Ace 5500 ~ 17.5 lb
How much runway you need to take off ?
bidule is online now Find More Posts by bidule
Old Apr 13, 2012, 08:04 PM
Joined Jan 2011
About 250 ft
On takeoff don't try to roll into power, apply throttle faster than normal so you get rudder authority. Also, make sure cg is on the front carbon spar. With full flaps keep at least half throttle on. Make sure you have up trim mixed with full flaps as Tam tells you in the manual. Once you get it dialed in you can use some crow but keep the power until touch down almost 1/4 throttle flare and then back off power.
It looks really nice on touch down.
Good luck.
Jeff
Old Apr 13, 2012, 09:57 PM
bidule's Avatar
Joined Mar 2000
Thank you Jeff
Old Apr 14, 2012, 03:13 AM
Eddie P is offline
Find More Posts by Eddie P
Official Boat Bum
Eddie P's Avatar
United States, NV, Reno
Joined Mar 2000
Good advice on flying the TJ-A4. I'll only mention I don't gun the throttle on takeoff with my A-4, I smoothly increase power like I do with all my takeoffs. The nose wheel steering seems to work OK.
PS - Camo on A-4's looks nice And if you are worried about scale on the other model you were looking at, don't sweat it too much. Besides, that model you referenced has 2 seats anyway The camo birds did sometimes have the avionics hump in the aggressor role. Especially since the A-4M, the "sports car" version of the A-4, all had the "hump" though the windscreen glass is slightly different on the "M".
Eddie P is offline Find More Posts by Eddie P
Sold Tam Jets 128mm A-4 Air Sally Ducting Ron101 Aircraft - Electric - Jets (FS/W) 5 Mar 24, 2012 07:32 PM
For Sale BVM Bandit EDF with Tam TJ100 Pandissix Aircraft - Electric - Jets (FS/W) 0 Dec 29, 2011 03:23 PM
Sold Tam Jets A-4 EDF version ready to fly $2700 Ron101 Aircraft - Electric - Jets (FS/W) 1 Jul 20, 2010 03:29 PM
Video Tam a-4 EDF monkamarm2000 Electric Plane Talk 5 Jul 10, 2007 11:35 AM
