Without knowing the make of the esc it's hard to say for sure. However the bec in most esc's sends 5 to 6 volts to the rx. If in doubt, check it with a volt meter.
Latest blog entry: Hobby King "SIX" hexa
If you look close at the photo, the bec puts out 5.5 volts and 3 amps.
Chances are your rx is capable of handling "up to" 7.2 v. It will still work at 5.5. Same for the servo. You do realise that is not a marine esc don't you? There is no cooling on it.
![]() Back to the esc... it should live as long as you don't over amp it and since you are planning to run 12v guessing it won't be a large boat. Unless you are planning ti use an aircraft type "stick" radio you may need to invest in a pistix to make it work with a pistol type transmitter. http://www.offshoreelectrics.com/pro...pistix&cat=136 Adding a water cooling plate wouldn't hurt either. http://www.offshoreelectrics.com/pro...-80678&cat=136 |
| Thread Tools | |
| Discussion What Voltage Regulator can output 5Volts with 8 to 70 volts Input ? | lazy-b | DIY Electronics | 4 | Apr 03, 2012 04:45 PM |
| Discussion What is the Minimum Input Voltage for a CC BEC Pro? | Alan Hahn | Castle Creations | 2 | Mar 22, 2012 02:41 PM |
| Help! Eagle Tree OSD/elogger V4 voltage/pack input | 558th_AV8R | Eagle Tree Systems | 3 | Feb 13, 2012 07:50 PM |
| Discussion Input Battery Voltage Error | taekwondo | Batteries and Chargers | 8 | Jan 11, 2012 03:41 PM |
| Discussion 4S Gold reporting wrong input voltage | a1pcfixer | FMA Direct | 8 | Oct 31, 2011 11:38 AM |
