Apr 13, 2012, 08:12 AM
United States, NC, Jacksonville
Joined Apr 2006
Custom outrunner shaft and bearing service
So I have been re-shafting quite a few motors recently for various reasons and am just curious if there would be enough interest to start a service. Most of time I have been replacing a shaft that is too short and I wanted to maximize the bite on the adaptor. I can also install bearings from Boca if anyone desired to upgrade or just needed new bearings. Shaft material I have been using and is easy to work with is O1 tool steel. I is a little oversized so I grind it down by hand to fit snugly in the bearings of the particular motor I am re-shafting. I can do 3mm, 3.17mm, 4mm, 5mm, 6mm, and 8mm shafts. All I would need to know is how far you need the shaft to extend. Since I mainly do this for EDF use I do not cut C-clip slots, nor do I have the ability to do so. If the shaft needing replacement is for an endbell propeller mount motor a Collar would have to be used. Priceing below.
$11.30 shipped back for 3mm, 3.17mm and 4mm shafts
$13.30 shipped back for 5mm and 6mm shafts
$15.30 shipped back for 8mm shafts
$1 per bearing installed plus the cost of the bearing.
