Closed Thread
This thread is privately moderated by flint 222, who may elect to delete unwanted replies.
Old Apr 13, 2012, 12:38 AM
United States, NY, Deer Park
Joined Aug 2011
Trader Rating: 0
RC Car hpi- racing switch RTR w/ Scion xB Body (Gold Rush Mica) - $149 (Deer Park,NY
For Sale New Factory sealed Box , HPI-Racing Switch RTR w/ Scion xB Body (Gold Rush Mica) $149.00. Call 631-767-1207
http://www.hpiracing.com/scionxb/
Scion xB RC Car by HPI Racing (1 min 21 sec)
Scion xB Switch RC Car by HPI Racing (2 min 27 sec)
HPID06** 104945 Switch RTR w/Scion xB Gold Rush Mica 4944258527789 365.00
This is the True Ten scale electric powered HPI Switch On-Road RTR Car.
FEATURES: Front wheel drive, plastic body friction shocks, 12 ball bearings,
cam type motor mount for easier adjustment, 35T, ESC w/reverse, 8 body mount
layout patterns, 1500mAh stick battery, wall charger
REQUIRES: 8 AA cells, phillips screwdriver, track equipment
TECH NOTES
This is the True Ten Scale, electric powered, radio controlled,
ready to run HPI Switch On-Road Car with Scion XB Body in Gold.
FEATURES: Chassis: Bathtub type, plastic construction
Drive: Front wheel
Motor: 35T Saturn
Motor Mount: Cam type for wider gear ratio settings and easier
backlash adjustment
Pinion Gear: 24 tooth
Spur Gear: 62 tooth composite
Ball Bearings: 12 in main drive
Body: Prepainted with body trim and head/tail light decals applied,
8 body mount layouts allows use of a variety of different bodies
Shocks: Friction, plastic construction
Gearbox: Front, sealed
Differential: Planetary
Transmission: One-speed
Tires: Molded slick rubber
Wheels: Five-spoke, black in color 1" (24.5mm) wide, 1.7 (43mm)
diameter
Radio: TR-1 27MHz 2-channel pistol grip with steering and throttle
trim and reverse, transmitter does not have charge jack
Battery: 7.2V 1500mAh NiCD stick pack with standard connector
Battery Charger: 110V wall type
Speed Control: Electronic, with reverse
Suspension: Independent McPherson strut
Camber Tie Rods: Fixed, non-adjustable
Steering Tie Rods: Fixed, non-adjustable
Steering: Bell crank type with servo saver
INCLUDES: HPI Switch RTR On-Road Car with Scion XB Body, High Torque 35T
Saturn Motor, reversible electronic speed control, black plastic
wheels, molded rubber tires, 7.2V 1500mAh rechargeable NiCD,
AC wall charger, and instruction manual
REQUIRES: Radio Batteries: Eight AA size
Misc. Items: Building and track equipment
SPECS: VEHICLE-
Length: 11.2" (285mm)
Width: 6.5"-6.9" (164mm-174mm) adjustable
Height: 2.6" (65mm)
Weight: 38oz (1080g)
Wheelbase: 8.3 - 8.9" (210 - 225mm)
Gear Ratio: 6.28:1
Tires: 2.4 x 1.02" (60mm x 26mm)
BODY-
Length: 14.4" (366mm)
Width: 6.1" (155mm)
Height: 4.7" (119mm)
COMMENTS: For Replacement Ball Bearings use:
Qty. Size Location Qty. Bearing Set
4 10x15mm Fr Hubs 2 DTXC1595
4 10x15mm Rear Hubs 2 DTXC1595
2 10x15mm Spur Gear 1 DTXC1595
2 10x15mm Diff 1 DTXC1595
The Scion XB in Gold
BOX DIMENSIONS: 12.13" W. X 9.75" H. X 18.75" L.
BOX WEIGHT: 6.71 LBS.
flint 222 is offline Find More Posts by flint 222
Closed Thread
Sold HPI Racing Savage RTR w/Kawasaki KFX 700 ATV Body (RTR) reddyrightnow Cars - Trucks and Parts (FS/W) 4 Feb 04, 2012 12:34 PM
Sold New Hpi E10 On Road RTR Monstermanhbf Cars - Cars and Parts (FS/W) 15 May 08, 2010 07:31 AM
Alert HPI Nitro RS4 RTR Gas Powered On-Road FOR SALE KA-T Car Talk 0 Feb 12, 2006 12:54 PM
For Sale HPI Nitro RS4 RTR Gas Powered On-Road KA-T Cars - Cars and Parts (FS/W) 1 Feb 11, 2006 06:03 AM
