Old Apr 12, 2012, 08:39 PM
EAGLESTRIKE 1's Avatar
Morro Bay, Ca.
Joined Jul 2005
Building a light board ???
Has anyone built a light board that can discharge 7.4 - 24 v batteries . and possably be able to adjust the current flow by useing a dial or knob........
EAGLESTRIKE 1 is offline Find More Posts by EAGLESTRIKE 1
Old Apr 13, 2012, 07:44 AM
Joined Sep 2008
This might be what you are looking for http://helifreak.com/showthread.php?t=277056 on page 8 there is a guy using lights
evdreamer is offline Find More Posts by evdreamer
Old Apr 13, 2012, 11:02 AM
Morro Bay, Ca.
Joined Jul 2005
that was interesting reading , thanks for that info ....I am leaning more to useing light bulbs to drain the batteries and avoid exessive heat and bright light effect that he mentions by regulating the current with a type of rheostat . or something like that........
I think I have worked out most of the bugs so far but I am now stuck on versatility.....I am not sure how to bring the voltage of lets say a 4s 5s or 6s down to around 12v in to safely operate my system ... it is probably something simple like an in line diode or resister before input . thats where I am stuck......
Old Apr 14, 2012, 10:07 AM
United States, UT, Herriman
Joined Jan 2012
A couple options.. 7812 linear regulator, but it would have to be switched out when using less than about 15v. You could also use a resistor voltage divider. That would make lower voltage batteries discharge slower, but you should be able to have one of the resistors be a pot and you could adjust it that way. There are lots of options, in part because the load can handle a wide voltage range.
You could also skip the bulbs and use a power resistor instead. That would be able to handle any battery if you got a really high wattage unit.
ttabbal is offline Find More Posts by ttabbal
Old Apr 15, 2012, 04:25 AM
Joined Mar 2006
Better than light bulbs, good for up to 36 volts.
http://www.rcgroups.com/forums/showthread.php?t=1352331
spog is offline Find More Posts by spog
Discussion DBlum Cessna 182 Build Thread - Brushless w/ Ailerons, Flaps, Lighting Paul Penney Parkflyers 6 Jun 10, 2012 01:11 PM
Question How do I build light control linkages for my RC Tomboy? gdh240 Vintage & Old-Timer Designs 26 Apr 15, 2012 12:51 PM
Help! Double Horse 9116 not responding SOLID red light on control board esbuff Electric Heli Talk 4 Nov 30, 2011 08:59 PM
For Sale Ready To fly MCX2 New tail lights new servo board new motors 2 new lipos 63 shipd blueindian Aircraft - Electric - Helis (FS/W) 3 Oct 31, 2011 06:18 PM
Sold Xaircraft FC1212S,AHRS,esc board, compass,GPS and pilot light badbill Aircraft - Electric - Multirotor (FS/W) 1 Oct 24, 2011 05:19 PM
