Old Apr 12, 2012, 06:07 PM
electricrc68 is offline
Find More Posts by electricrc68
The Sweet Aroma of Fuel
electricrc68's Avatar
United States, PA, Downingtown
Joined May 2011
Lipos to storage voltage?
hey guys. if i have a fully charged lipo that i wasn't able to use, how would i go about to discharge it down to storage voltage?
electricrc68 is offline Find More Posts by electricrc68
Old Apr 12, 2012, 06:10 PM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
Easiest and cheapest way...
Plug it into a discharged lipoly of same cell count and limit current flow with a power resistor like this.
Another very effective and foolproof way is to use an automotive lightbulb in conjunction with this cutoff circuit.
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Apr 12, 2012, 06:15 PM
Joined May 2011
cool thanks. my charger has a discharge setting; could i use that to get it down to the right voltage?
Old Apr 12, 2012, 06:19 PM
So. Cal.
Yes, you can. However, lipo cutoff voltage on most chargers is WAY too low and can damage your lipoly. You can use NiMH discharge and set cutoff to ~3.8V/cell and it should get you in perfect storage range.
Some chargers have Lipo storage setting that will discharge and cutoff at appropriate voltage.
Note that most inexpensive chargers have extremely limited discharge capability and will take a VERY long time to reach storage voltage on a large pack. Also, there have been many reports of burned up chargers as a result of using a charger to discharge lipolys. It's for this reason that I never recommend using an expensive charger to discharge packs. It's much cheaper to replace a lightbulb than an entire charger...
Mark
Old Apr 12, 2012, 06:35 PM
Joined May 2011
Mark
okay cool thanks.
Old Apr 13, 2012, 02:28 PM
Joined May 2011
just a question; how do you discharge a lipo using a lightbulb?
Old Apr 13, 2012, 02:31 PM
So. Cal.
There's a simple circuit that was linked in post #2 above that is fun to build and works wonderfully. It uses cheap 12V automotive lightbulbs.
Here it is again: http://www.rcgroups.com/forums/showthread.php?t=1131817
Mark
Old Apr 13, 2012, 05:31 PM
Joined May 2011
oh okay thanks.
Mini-HowTo Discharging packs to storage voltage bill34207 Racing Boats - Electric 19 Nov 21, 2015 01:51 AM
Discussion Storage of fully charged Lipo batterries Billtheboss Batteries and Chargers 63 Nov 12, 2014 07:19 PM
Discussion LiPo Charge/Storage question Zenmaniac Batteries and Chargers 7 Mar 17, 2012 10:24 PM
Discussion 70C pack - ideal storage voltage floatcharge Batteries and Chargers 8 Dec 20, 2011 03:37 PM
Discussion Proper winter storage for Storage state LIPOS? proweddingphotos Beginner Training Area (Aircraft-Electric) 5 Nov 01, 2011 12:27 PM
