Old Apr 12, 2012, 01:53 PM
Wings of Balsa is offline
Find More Posts by Wings of Balsa
Joined Jan 2012
Ultracote vs Monokote
Title is self explanatory. Please give your opinion.
Wings of Balsa is offline Find More Posts by Wings of Balsa
Old Apr 12, 2012, 03:03 PM
WAGliderGuy is offline
Find More Posts by WAGliderGuy
Airliner Builder
WAGliderGuy's Avatar
United States, WA, Seattle
Joined Feb 2010
Ultracote - much easier to shrink and goes around curves with no problem. I especially like their Parklite.
WAGliderGuy is offline Find More Posts by WAGliderGuy
Old Apr 12, 2012, 03:11 PM
dedStik is offline
Find More Posts by dedStik
Redacted per NSA "suggestion"
dedStik's Avatar
United States, VA, Virginia Beach
Joined Feb 2012
I've only experience with monokote but it is a bear to work around curves. Also I suck at cutting a straight line even with a straight edge.
dedStik is offline Find More Posts by dedStik
Old Apr 12, 2012, 04:19 PM
lindart is offline
Find More Posts by lindart
Art Schmitz
United States, TN, Crossville
Joined Jan 2012
+1 for Ultracote...ease of application.
lindart is offline Find More Posts by lindart
Old Apr 12, 2012, 05:15 PM
Marion is offline
Find More Posts by Marion
Marion
USA, NC, Hillsborough
Joined Oct 2003
For me Ultracote is easier to work with. But it costs more and is only 24 inches wide, while Monocote is 26 inches wide. Depending on the size of your model, that extra 2 inches of width can make a difference.
Marion is offline Find More Posts by Marion
Old Apr 12, 2012, 05:31 PM
ChuckA is offline
Find More Posts by ChuckA
Tennessee
Joined Sep 2003
Ultracote is not as strong as Monocote and is much more likely to flutter. Your choice: ease of construfction or ease of destruction.
ChuckA is offline Find More Posts by ChuckA
Old Apr 12, 2012, 06:23 PM
NACA0012 is offline
Find More Posts by NACA0012
Joined Mar 2012
Ultra - shrinks like crazy, but won't stretch.
Mono - doesn't shrink as much, but will stretch.
Ultra - glue is mediocre, hard to keep it stuck down
Mono - better glue, narrow trim bits stay down better
Ultra - often goes slack/ripply in the hot sun
Mono - tends to stay shrunk better long term
Ultra - keep heatguns away from seams or they'll pull loose
Mono - you can burn through it with a heat gun before the seams pull
Ultra - easier for a novice to produce a presentable result.
Mono - harder for novices to work with.
That being said, today's Monokote isn't nearly as good as it was 30 years ago. I had some planes I built in high school back in the 70's stored in hot attics and the Monokote on them was tight and still stuck when I took them down decades later. I rather doubt today's product would withstand that kind of test.
You can get a decent result with either product. Each has multiple shortcomings and multiple strengths.
NACA0012 is offline Find More Posts by NACA0012
Old Apr 13, 2012, 08:14 AM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Which Monokote, old or new formula?
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Apr 13, 2012, 08:42 AM
pisco2010 is offline
Find More Posts by pisco2010
Brazil, SP, Rio Claro
Joined Nov 2009
I just started covering a newly-built, vintage Sterling Lancer SL-62. It has some funny curves that Monokote didn't like. Ultracote went smoothly without a single wrinkle.
I'm slowly but surely moving to Ultracote/Oracover.
pisco2010 is offline Find More Posts by pisco2010
Old Apr 13, 2012, 01:01 PM
scigs30 is offline
Find More Posts by scigs30
Joined May 2005
They are both good coverings and both have their positives and negatives. I prefer Monokote but it does requires a bit more skill to apply. I only say this because Ultracote and be put on the frame wrinkles and all, and shrunk tight. Monokote has to be put on wrinkle free before you even think about shrinking it. I have been using Monokote since the 80's and have not noticed this big change in formula everyone is talking about. I have only covered 2 planes with Ultracote and decided I like Mono better. Hobbico/great planes/top flite/Monokote could do a better job of showing people how to use their product. They do sell a DVD that is ok, but I think they would be better off videoing a ARF worker using their product. As much as I love Mono, it is a pain to apply Mono over Mono without punching holes on the base coat. I look at ARFs covered with Mono and there are no bubbles or holes punched in the base covering. I wonder how the heck they do that? I am covering a Peter Rake Fokker DVII with Mono right now and covered the nose block with one piece of Mono, this is how good the stuff stretches.
http://www.rcgroups.com/forums/showt...1613951&page=2
scigs30 is offline Find More Posts by scigs30
Old Apr 13, 2012, 01:36 PM
Blue Falcon is offline
Find More Posts by Blue Falcon
Chicago
Joined Jul 2008
+ 1 Ultracote. Why fight the wrinkles of Monokote?
Blue Falcon is offline Find More Posts by Blue Falcon
Old Apr 13, 2012, 03:07 PM
scigs30 is offline
Joined May 2005
What wrinkles?
Old Apr 14, 2012, 11:45 AM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
I find that Monokote varies by color. Some are easier to work with than others.
You just have to practice with either one to get a feel for it, then you can do a lot with either one.
Greg
gkamysz is offline Find More Posts by gkamysz
Old Apr 15, 2012, 06:12 PM
Thermalin is offline
Find More Posts by Thermalin
I'm a pilot, 100 yrs too late
Thermalin's Avatar
USA, FL, Palm Harbor
Joined Jan 2005
Ultracote for me.. I have not had any of the issues described above. Mono is probably stronger though I cannot tell a difference b/c it's so thicker, heavier which I beleive causes the shrinkage issues and hence harder to apply on compound curves and in general. I gladly pay the extra two bucks at the LHS for ultracote.
Thermalin is offline Find More Posts by Thermalin
Old Apr 16, 2012, 09:05 PM
Oberst is offline
Find More Posts by Oberst
Oberst's Avatar
Lacona, NY
Joined Dec 2009
I like Ultra the best. It seems that Mono changed from what it used to be in my opinion. It doesn't like to shrink as well.
Solartex is my favorite for scale model covering if I don't plan on using cloth and dope. It's a bit pricey, but nice to work with.
Pete
Oberst is offline Find More Posts by Oberst
Discussion Ultracote adhesive MOUNTAINROAD The Builders Workshop 12 Mar 07, 2012 10:32 PM
Wanted Hangar 9 Ultracote, Corsair Blue HANU905 brianfp_400 Aircraft - General - Miscellaneous (FS/W) 0 Feb 25, 2012 01:50 PM
Question Monokote vs ultracote? Advices please Turqui Painting and Finishing Tips 2 Nov 22, 2011 09:59 AM
For Sale FS - Great Planes F15 Eagle - never flown! Great Monokot scheme! electricFlyNut Aircraft - Fuel - Airplanes (FS/W) 5 Oct 18, 2010 11:21 PM
Alternatives to tape and ultracot DocMac Foamies (Kits) 0 May 25, 2001 07:45 PM
