Old Apr 12, 2012, 12:51 PM
lijoy_alex is offline
Find More Posts by lijoy_alex
Joined Mar 2012
My GWS ESC 25A not arming
I connected my GWS ESCs (25A) to my Hobby King board and tried increase the throttle but the ESCs just beep every 3 secs. I tried it with a Ardupilot System and it doesn't get armed also.
What might be the problem?
lijoy_alex is offline Find More Posts by lijoy_alex
Old Apr 12, 2012, 07:50 PM
twn Chen is offline
Find More Posts by twn Chen
Taiwan, 北市
Joined Dec 2010
Probably some of the connectors and leads were not soldered well, might have been from your Hobby King board. But I have no idea about what Hobby King board you mentioned. Normally an ESC is desgined to connect with motor, receiver and battery.
Chen
twn Chen is offline Find More Posts by twn Chen
Old Apr 14, 2012, 09:38 AM
Joined Mar 2012
I use 'HobbyKing Multi-Rotor Control Board V2.1 (Atmega168PA)'. Its a stabilization board. I want to use this setup for my Quad board.
Lijoy
Old Apr 14, 2012, 07:06 PM
twn Chen is offline
Taiwan, 北市
Joined Dec 2010
Suggest plugging this ESC with one motor, battery and receiver, forget the control board at this moment, to see if it works correctly for you. If so, probably the board itself was in trouble, or you have to refer to the board's manual again.
Chen
Help! ESCs will not arm using DX7 or my 9C TM8 simages Power Systems 16 Mar 04, 2012 06:03 PM
Discussion ESCs connecting but not arming motor tezact Power Systems 4 Feb 11, 2012 11:48 AM
Discussion Esc not arming? motor won't start. dudly Electric Plane Talk 5 Jan 15, 2012 10:47 AM
Discussion GWS 2205/15T Brushless Motor Plus 25A ESC kieranb Power Systems 2 Dec 05, 2011 03:51 PM
Discussion Now with data: Hobbyking SS 25A esc works great it was my fault for not testing first handyfella Power Systems 40 Mar 26, 2011 09:29 AM
