This thread is privately moderated by ALL American, who may elect to delete unwanted replies.
Old Apr 12, 2012, 10:18 AM
ALL American is offline
Find More Posts by ALL American
It's Not Too Windy...Man Up
ALL American's Avatar
USA, CT, Wallingford
Joined Oct 2009
Gallery
Airfield Version 3 / FMS 1450 mm P51D Version 6
This is my new P51D for flying at the local park when I don't have time to go to my flying club. Its an FMS 1450 mm (57 Inch) P51D Version 6
FMS makes great airplanes but they almost all have some minor issues. So aside from rehinging all of the control surfaces with DuBro pinned hinges which was optional, I found a number of small issues (mostly aesthetic) that I felt needed correction:
  • The blue on the plane was three different shades so I repainted the blue on the cowl, spinner and on the plane. The camera's flash washes out the color which is actually a much richer blue than it appears in the photos.
  • The stripe decals on the top of each wing were crooked so I removed them and painted the stripes.
  • The Invasion Stripes were very sloppy with quite a bit of overspray so I repainted the Invasion Stripes.
  • The entire airframe was dulled a bit with Krylon Matte finish spray.
  • The motor alignment was off to the right and too low and the spinner gap against the cowl was fairly wide. This was unacceptable so I corrected the alignment and gap.
  • A number of minor issues were discovered during a thorough inspection such as, one of the retract's set screws was too small and was not actually securing the strut. Had I not caught this I'm sure the strut would have fallen out during a takeoff or landing. So inspect every screw on your plane!.
  • I use Gens Ace 4S 4000 Mah 25C packs which weigh 15+ Oz. I had to add 1.6 ounces of weight to the tail in order to obtain a good balance. While inverted, the plane flies with little to no down elevator so I think I have the CG right on the money.
The maiden flight went well as this plane is a big, easy to fly P51. There was a strong cross wind but the plane is so easy to fly that it was a non-issue. The plane required only a click or two of aileron trim to fly straight. The flight was 5 minutes with a 4S 4000 Mah 25C Gens Ace Pack and 3.89 volts per cell remained after the flight. As far as I'm concerned, the plane is fast enough with the 4 blade prop for flying at the park. I don't think I'll bring this to the club very often so the 4 blade will stay on for both its looks and its thrust.
This plane is a major improvement over the Version 5
Name: FMS Petie.jpg
Description: Name: FMS Petie 2.jpg
Description: Name: FMS Petie 3.jpg
Description:
Name: FMS Petie Wing Stripes Repaint.jpg
Description: Name: FMS Petie Underbelly.jpg
Description: Name: FMS Petie Underbelly 2.jpg
Description:
Name: FMS Petie Motor Realignment.jpg
Description:
Gens Ace 4S 4000 Mah 25C Lipo Placement
Name: Gens Ace 4S 4000 Mah 25C Placement.jpg
Description: Name: DSC00184.jpg
Description:
1.6 ounces of lead weight embedded under the Horizontal Stabilizer to obtain proper balance
Name: Tail Weight for Balance.jpg
Description:
Balance Point CG is 33% into the circle on the top of the wing.
Name: Balance Point.jpg
Description:
ALL American is offline Find More Posts by ALL American
Old Apr 12, 2012, 10:35 AM
Vintauri is online now
Find More Posts by Vintauri
MN WATTS Master
Vintauri's Avatar
United States, MN, Mankato
Joined Jul 2003
Looks great. Can you take a pic of your battery placement with that pack? I have been experimenting with where to put mine of a similar size.
Thanks!
Vintauri is online now Find More Posts by Vintauri
Old Apr 12, 2012, 11:06 AM
LICobra is offline
Find More Posts by LICobra
Warbird Enthusiast
LICobra's Avatar
Long Island, NY
A..Glad the maiden went well, she looks real good...now you just need to loose that non scale pilot and get a Shapeways pilot/cockpit.
LICobra is offline Find More Posts by LICobra
Old Apr 12, 2012, 01:23 PM
Prowler901 is online now
Find More Posts by Prowler901
Prowler901's Avatar
USA, NY, Amsterdam
Joined Jun 2007
Nice lookin' repaint! Glad to hear that you're happy with the improvements they've made.
Prowler901 is online now Find More Posts by Prowler901
Old Apr 12, 2012, 03:51 PM
Joined Oct 2009
Thanks!
Thanks!
The Gens Ace 4S 4000 Mah 25C packs are a snug fit in the upper compartment that is intended for the battery pack. It must be pushed far enough into the battery bay so that the canopy snaps on.
I had to add 1.6 ounces of weight to the tail in order to obtain a good balance. I'll try to snap a picture of the battery placement tomorrow.
Thanks! You're right, the shrimp in the pilot's seat needs to go.
I wouldn't go that far...LOL
I finally got my last FMS P51D to a point that I was pretty happy with and then a fellow member at my club decided to fly in the wrong direction and we a mid air. After that, I was through with that plane. This new plane really needed very little in terms of mechanical or functional modifications so in that respect I guess I'm happy with the improvements.
Regards,
Anthony
Old Apr 12, 2012, 04:33 PM
flmlm is offline
Find More Posts by flmlm
flmlm's Avatar
Holly Hill, Fl.
Joined Mar 2005
Great looking airframe...thanks for sharing.
Regards
flmlm is offline Find More Posts by flmlm
Old Apr 12, 2012, 07:54 PM
Joined Oct 2009
Regards
Mike,
How's your E Flite P51B rebuild coming along?
Regards,
Anthony
Old Apr 13, 2012, 05:13 PM
Joined Oct 2009
Thanks!
I added some additional photos to my first post which show the LIPO Pack placement, the addition of tail weight and where my P51D balances.
I hope it helps.
Regards,
Anthony
Old Apr 13, 2012, 05:18 PM
MN WATTS Master
Vintauri's Avatar
Joined Jul 2003
Thanks Anthony, I have the same packs and have been playing with how to mount them to get it to balance.
Steve
Old Apr 25, 2012, 01:02 PM
porcia83 is offline
Find More Posts by porcia83
United States, CT, Hartford
Joined Jun 2009
As usual...nice plane made nicer with the upgrades. Looks great!
porcia83 is offline Find More Posts by porcia83
Reply With Quote  (Disabled)
Old Apr 25, 2012, 01:09 PM
Joined Oct 2009
Thank You Tom!
Are we going to fly this summer?
Anthony
Old Apr 25, 2012, 02:42 PM
porcia83 is offline
Joined Jun 2009
Without a doubt...either north or south, we'll figure it out!
Old Sep 26, 2012, 02:40 PM
ryanbe15 is offline
Find More Posts by ryanbe15
ryanbe15's Avatar
United States, MD, Bethesda
Joined Sep 2012
Does teh Krylon Matte finish spray help protect the paint on the foam? Does it not do harm? How are the retracts on this plane as i'm looking to get this one from bananahobby.
ryanbe15 is offline Find More Posts by ryanbe15
Old Sep 26, 2012, 04:21 PM
Joined Oct 2009
The Krylon Matte did not damage the paint or foam, it slightly dulled the finish. The retracts are lousy. After six flights one died so I replaced them with larger retracts.
Old Sep 26, 2012, 09:16 PM
ryanbe15 is offline
ryanbe15's Avatar
Joined Sep 2012
Can you please provide the link to the larger retracts? How long have you been flying with the bigger retracts? Also, this plane would be my 2nd low wing plane. Is this plane easy to fly?
Sold TX LPU: FMS 1450mm P-51 Mustang, Version 6, Blue Nose Roswalt Aircraft - Electric - Airplanes (FS/W) 8 Mar 04, 2012 01:30 PM
Discussion Is small or big lens the best? 2.6 mm or 3.6 mm? Voguna FPV Talk 8 Sep 19, 2011 07:00 AM
Discussion NEW - Airfield/FMS 1400 mm 57" P51D Mustang **See For Sale section** staged22 Electric Warbirds 1 Aug 24, 2010 12:32 PM
Found NEW - Airfield/FMS 1400 mm 57" P51D Mustang ALL American Aircraft - Electric - Airplanes (FS/W) 3 Jul 13, 2010 09:42 PM
