Old Apr 12, 2012, 08:52 AM
Why kamikaze pilot wear helmet
mikes68charger's Avatar
United States, OH, Columbus
Joined Jul 2010
How to hand launch a pusher plane
I guess I should of asked this before now as I'm sitting in the emercy room wateing to get stitchs
I have a HET F20 70mm EDF that was a bungy launch.
I hate bungy. And to me it flew sub par. Sapac MB1 on 50c 5s 3400
So I converted it to a pusher set up with an ARC 28-58-1 on 40c 4s 2600 with a 6x4 prop with 5.5 thrust and 160 prop speed
When I threw it, it sliced my hand 5 time and cut my finger nail in 1/2
And broke the prop. But I flew it for 3 min before I found out I was bleeding every wear.
And it fly 2 times better.
So except wearing a glove. How do you guys hand launch a pusher with out being in the hospital with a up set wife?
mikes68charger is offline Find More Posts by mikes68charger
Old Apr 12, 2012, 09:27 AM
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
Followthrough. Don't leave your hand hanging up where the plane will get it when it goes by. Honestly.
mw (RiteWing pilot)
Mark Wood is offline Find More Posts by Mark Wood
Old Apr 12, 2012, 09:30 AM
LesUyeda's Avatar
San Diego, California
Joined Dec 2004
Discus Launch. Grab a wingtip, spin and release.
Les
LesUyeda is offline Find More Posts by LesUyeda
Old Apr 12, 2012, 10:36 AM
Shelter Kitty "Orange Death"
bartricky's Avatar
United States, FL, Monroe
I used the follow through method on my Stryker and was OK.
The factory approved method was to launch it power off and add power once it left your hand.
bartricky is offline Find More Posts by bartricky
Old Apr 12, 2012, 10:38 AM
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
I hand launch pushers with 14" props all the time. Have yet to get a nick, much less a cut.
Be careful where you hold the plane relative to the prop. And launch with vigor.
Sparky Paul is offline Find More Posts by Sparky Paul
Old Apr 12, 2012, 10:45 AM
Flying Full Size & Fun Size :)
jgalexander's Avatar
United States, CA, Calabasas
Joined Apr 2010
All of the above are correct, and for sure the safest way is to keep the throttle at zero until after you throw/release. Kinda tough with the f-20 though, as it isn't really much of a glider, eh?
Take a look at all the "similar threads" right down below this post - some interesting reading there....
Josh
jgalexander is offline Find More Posts by jgalexander
Old Apr 12, 2012, 10:59 AM
DIY Mania from Taiwan
Taiwan
Joined Aug 2011
Use PVC launcher
regards
Sam
samwei1950 is offline Find More Posts by samwei1950
Old Apr 12, 2012, 11:26 AM
Moorpark, Ca.
Joined Apr 2004
follow through. The F7U in the pic has a 7 X 5 prop and the CF-105 has a 8 X 6 prop. Notice how far my hand is away from the prop at he time the prop could contact my hand.
RickAvery is offline Find More Posts by RickAvery
Old Apr 12, 2012, 12:02 PM
Livermore, CA
Joined Sep 2004
When I started to build pushers as slower parkflyers, with larger props, I got a few cuts as well. So I usually launch with power off.
Some of my pushers can be launched from the wing tip.
Butch777 is online now Find More Posts by Butch777
Old Apr 12, 2012, 01:47 PM
Joined Jul 2010
Thanks guys. I ended up with 20 stitches and a split finger nail
Since this was a maden flight I think now she has the power to be thrown underhand. The f20 is not very easy to hold on from bottom as the wings are flush with the bottom of the bird so you can only hold on behind the wing
And I don't think there is any glide ratio on a jet like this.
But thanks for the ideals
So 2nd question. It turned out the prop tips broke off at landing and not in my hand. So if you turn the break feature dose the motor know where to stop it so it dose not hit the ground?
Old Apr 12, 2012, 01:52 PM
Ascended Master
Palmdale, CA
Joined Oct 2000
The prop stops, but it may windmill just a tad. With any luck at all, any ground contact will just push it out of the way.
Old Apr 12, 2012, 09:35 PM
Joined Aug 2011
I have a T-38 and F-15 pusher, also a couple of super bandit pushers. I find that with the power that I have on the back end of these planes, I can just hold them by the end of the wing and swing it up at about a 45-60 degree angle (same motion as throwing a frisbee), and I never have torque issues and it is a piece of cake to launch. I'm scared of the moving part in the back of the plane and won't even think of risking it with a conventional toss.
Sorry about your arm!
gmwahl is offline Find More Posts by gmwahl
Old Apr 12, 2012, 11:06 PM
Expo is built into my thumbs
Hance's Avatar
USA, ID, Niter
Joined Jul 2008
mw (RiteWing pilot)
Exactly ! I have more hand launch pushers than any other style of plane and have never been so much as nicked by a prop. Throw it like you mean it and follow through. Its scary to think what the prop on my Demon would do to ones fingers. A 6X4 prop spinning at 40,000+ rpm is gonna leave a mark.
Hance is offline Find More Posts by Hance
Old Apr 13, 2012, 12:13 AM
It must have a machinegun
Scaledown's Avatar
Perth, Western Australia
Joined Sep 2004
I've never broken a prop on landing. I've broken a weak engine mount a few times, but not a prop. Then again you have a heavy plane for such a small prop. Try a different brand of prop. Make sure the brake is really on.
I presume you are landing on grass.
Scaledown is offline Find More Posts by Scaledown
Old Apr 13, 2012, 12:23 AM
Art Schmitz
United States, TN, Crossville
Joined Jan 2012
+1 A distinct downwards follow through gets the job done safely.
lindart is offline Find More Posts by lindart
Help! How do I hand Launch Flybynight2 Electric Plane Talk 50 Jan 10, 2012 03:07 PM
Discussion How to hand launch a low wing plane...?? joy4u Fuel Plane Talk 5 Oct 18, 2010 06:13 PM
Discussion How to hand launch R4U Corsair plane? skilet Electric Warbirds 30 Aug 04, 2009 09:06 PM
Video How not to hand launch a pusher jet cmala Electric Plane Talk 18 Feb 09, 2008 12:39 AM
Discussion How to hand launch this plane? 2MuchAir Electric Plane Talk 11 Mar 10, 2006 12:22 PM
