Old Nov 17, 2012, 05:54 PM
Eric Henderson is offline
Find More Posts by Eric Henderson
Eric Henderson's Avatar
United States, NV, Las Vegas
Joined Dec 2005
Habu-2 efflux upgrade
Gary she is already to go, but it's getting dark a lot earlier here in "Sin City".....
I added a thrust tub to firstly bridge the gap betwen the fuse and the fan housing. You could see the wing join seam flex open under full power. Secondly, the Habu-2 tailpipe exit is just about the right diameter for a thrust tube to give speed,however, I also needed to fit a smoother exit liner.
I did break down and cut a cheater hole in the center of the wing. This wee beastie needs more air !!!!
Regards,
Eric.
Eric Henderson is offline Find More Posts by Eric Henderson
Old Nov 17, 2012, 06:08 PM
Joined Dec 2005
Thrusttube tools.
This may not be new, but here are the tools that I use to open up these foam EDFs.
Basically I was using a cut-off broom handle and sandpaper. Then, one day walking through my local Home Depot hardware store saw some pipe fittings. Then I bought some dry-wall sand papaer. This stuff has openings in it to let plaster dust escape. I guesed it would work for foam and it did.
The PVC joins were very close to 70mm. It does not take much twisting or back and forth movement to remove some good volume of foam. The drytwall sandpaper comes in different grades.
The last picture is my final variant that I used in the Habu. The "former" is a section of pipe from a big-ass shop-vac. the best part about this tool is that I connect it to the vac and have it turned on while I work the foam---no dust, just noise ( I use ear plugs for long jobs).
Hope this helps someone? -- Eric.
Old Nov 17, 2012, 09:31 PM
TX79 is offline
Find More Posts by TX79
United States, NY, Cohoes
Joined Oct 2010
Does anybody know when the replacement landing gear set PKZ7106 will be available from Horizon? It just says "back ordered."
TX79 is offline Find More Posts by TX79
Old Nov 17, 2012, 10:57 PM
ChuckTseeker is offline
Find More Posts by ChuckTseeker
ChuckTseeker's Avatar
Adelaide Plains Australia
Joined Dec 2007
started the painting of my new Habu 2 airframe fitout, first up i taped everything i didn't want painted and then fitted the plane together
Next it got it's first coat of Createx Pearlized Tangerine which is going to be my base coat for the paint job silly me didn't realize how much paint i had left and ran out before i finished the first coat so more was ordered, will keep updating as i go
cheers chuck
ChuckTseeker is offline Find More Posts by ChuckTseeker
Old Nov 17, 2012, 11:12 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
cheers chuck
Looks great Chuck.
Prof100 is offline Find More Posts by Prof100
Old Nov 18, 2012, 01:37 AM
efflux RC is offline
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
Regards,
Eric.
Looking good Eric.
You won't need the cheater.
I like your sanding tool. here's a pic of what I've been using lately.
It even works on EPO (which I dislike working with). So I'm keeping my mods to a mininum.
The Habu 2 outlet is nearly 59mm. Most guys who install thrust tubes onto 70mm EDFs, run them at about 56mm (that's a big difference). If you decide to put a full thrust tube in it. Make it at least as small as 56mm if your looking for top end speed. The amps will go upa bit, and you will loose a very liitle static thrust. (acceleration and vertical performance)
.......at Chuck.
Very nice!
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Nov 18, 2012, 07:36 AM
jimmy34256 is offline
Find More Posts by jimmy34256
Destructive Tester
jimmy34256's Avatar
Tampa, FL
Joined Apr 2008
Do you need the whole kit or just the wheels & struts?
jimmy34256 is offline Find More Posts by jimmy34256
Old Nov 18, 2012, 07:41 AM
Destructive Tester
jimmy34256's Avatar
Tampa, FL
Joined Apr 2008
cheers chuck
Color matches your vest.......
Old Nov 18, 2012, 10:01 AM
Joined Dec 2005
Originally Posted by efflux RC View Post
Looking good Eric.
.......at Chuck.
Very nice!
I opted for the "stock" Habu opening for one reason only. My plastic sheeting was only that long. The local stores always carry it in 12" pieces in the pre-pakaging When I get some bigger sheeting I will swap in a new thrust tube.
I saw your drill version. Was going to do it and then I saw my shop-vactube and hit on the "run-the-vac-as-I sanded" idea. Made the little lady happy about the foam dust. My "light jobs electric modelling workshop" is in the house adjacent to the living room.
Regards,
Eric.
Old Nov 18, 2012, 11:57 AM
supercollider is online now
Find More Posts by supercollider
C.E.R.N. field tester
supercollider's Avatar
United States, NE
Joined Sep 2012
ChuckTseeker,
Great color, please post photos when you are completely done painting and detailing.Top and bottom. I like custom paint on the habus. The white airframe just begs for it.
thanks
supercollider is online now Find More Posts by supercollider
Old Nov 18, 2012, 12:04 PM
TX79 is offline
Joined Oct 2010
Habu 2 Parts
Not the whole kit although that's what it looks like I need to buy. I need the red, white, and blue plastic assembly that screws into the bottom front and holds the front wheel in place, and also one of the blue plastic assemblys that holds the wing wheel assembly in place as well as the small rectangular blue clip that screws into the assembly to hold the whole wheel assembly in place.
Old Nov 18, 2012, 12:54 PM
172AMD is offline
Find More Posts by 172AMD
Richmond B.C. Canada
Joined Aug 2006
http://www.parkzone.com/Products/Def...ProdID=PKZ7106
172AMD is offline Find More Posts by 172AMD
Old Nov 18, 2012, 03:06 PM
Chuck is offline
Balsa to the Wall
Chuck's Avatar
Deep in the East Texas Piney Woods
Joined Dec 2001
Question about the front LG plate on the unpainted airframe. The guide says to use 2.5x8mm screws to mount it to the fuse, but they seem too big, and the kit came with some smaller screws. Are they for the LG plate?
Chuck
Chuck is offline Find More Posts by Chuck
Old Nov 18, 2012, 11:03 PM
Jetnfast is online now
Find More Posts by Jetnfast
Jetnfast's Avatar
United States, CA, Temecula
Joined Feb 2008
On the subject of retracts, I am thinking about trying these out...
http://www.hobbyking.com/hobbyking/s...dproduct=12883
or these:
http://www.hobbyking.com/hobbyking/s...teerable_.html
http://www.hobbyking.com/hobbyking/s...g_1_Pair_.html
with these struts:
http://www.hobbyking.com/hobbyking/s...dproduct=11300
Anyone try that combo or something similar? I still need to figure out what to do for the nose retract, since I am not sure if the ones above have a steering mech...
Jetnfast is online now Find More Posts by Jetnfast
Old Nov 19, 2012, 07:39 PM
erikc641 is offline
Find More Posts by erikc641
United States, NM, Las Cruces
Joined Jul 2012
I am using the http://www.hobbyking.com/hobbyking/s...g_1_Pair_.html, however the steerable one above it will not work. You need one with a reversible mounting plate.
erikc641 is offline Find More Posts by erikc641
Sold 2 PNP Parkzone Habu's - willing to ship jgalexander Aircraft - Electric - Jets (FS/W) 16 Mar 29, 2012 09:44 PM
For Sale Brand New in pack ParkZone Habu EDF Jet Painted Wing PKZ7020 zsultan Aircraft - Electric - Airplanes (FS/W) 3 Nov 15, 2011 12:36 AM
For Sale Brand New in pack ParkZone Habu EDF Jet Painted Wing PKZ7020 zsultan Aircraft - Electric - Jets (FS/W) 0 Nov 13, 2011 02:40 PM
Sold Brand New Parkzone Habu EDF Jet BNF zsultan Aircraft - Electric - Airplanes (FS/W) 0 Nov 07, 2011 01:05 PM
Sold Brand New Parkzone Habu EDF Jet BNF. zsultan Aircraft - Fuel - Airplanes (FS/W) 4 Nov 07, 2011 01:04 PM
