Old Oct 28, 2012, 08:58 AM
tclaridge is online now
Find More Posts by tclaridge
United States, VA, Clifton
Joined Nov 2005
Chuck,
For the Habu, spoilerons do the trick. No flaps needed. However, when I install retracts and go to 5S, I will go ahead and switch to flaps so I can still use my 6 channel Rx.
I will post my spoileron setup in a following post so you know the mix method and deflection amounts. They really work great for the Habu.
tclaridge is online now Find More Posts by tclaridge
Old Oct 28, 2012, 09:04 AM
Jetnfast is offline
Find More Posts by Jetnfast
Jetnfast's Avatar
United States, CA, Temecula
Joined Feb 2008
The added benefit of adding flaps outweigh the negatives for a ROG setup in my opinion. There is a negligible amount of extra weight for two sub micro servos and a harness for adding flaps. Plus with the Habu 2 all the work is already done for You since the cutouts are already there and the flaps already cut. You will be able to land slower, take off in less distance and if you have never used them on a model, add to the learning experience of different aerodynamics through RC. If you plan on ROG, add the flaps, if you plan on hand launching and belly landing there is probably no need.
Jetnfast is offline Find More Posts by Jetnfast
Old Oct 28, 2012, 09:32 AM
Joined Nov 2005
Easy Spoileron Setup
Here is an easy way to setup spoilerons on the Habu 2. Jetnfast makes good points on using flaps, but for me, I fly off a nice grass field. I have plenty of take-off room, and landing with spoilerons is a piece of cake. I decided not to use the flaps because the spoilerons are so effective on the Habu. I am going to save the time, money, and effort and just do retracts. I have found that using the spoilerons teach you the same methods when using flaps on other planes:
You will need to remove the aileron "Y" and replace it with two 3" or 6" servo extensions. Plug the right aileron into the aileron port, and plug the left aileron into Aux1. Select "Flaperon" for your wing type, and use 25% takeoff, and 50% landing for your flap system. No elevator adjustment is necessary. Make sure the aileron deflection is UP on both sides when applying your flap switch and NOT DOWN.
Measured from the outboard side of the aileron (towards the wing tip) the first flap setting should give you 4mm up, and the second flap setting should be at about 8mm.
That's it!
Old Oct 28, 2012, 10:33 AM
Joined Nov 2005
Flight Report, Stock Setup
I am very pleased with the Habu 2!! After my first few flights, I checked the ESC temperature, and it ranged from 113-126 deg F. This is very good and not hot at all. It looks like this problem is solved from the first Habu.
The plane flies great, and it looks to be the same performance as the first Habu with stock equipment and fixed gear. It looks great in the sky, and I like this color scheme better when it is cloudy.
My CG came to 3.5", and that did seem to make the nose feel heavy. I needed 6 clicks of pitch-up elevator to trim. So I think the 4" CG per the manual would have been better. Since I will be doing the 5S battery mod, I will not add nose weight at this time because I will add the Pro 80 ESC mounted aft. But if I was leaving this plane stock, I would move the CG to 4".
Old Oct 28, 2012, 01:21 PM
supercollider is offline
Find More Posts by supercollider
C.E.R.N. field tester
supercollider's Avatar
United States, NE
Joined Sep 2012
That's it!
Good info. Just to be clear, when applying the flap switch, should the ailerons both go up towards the canopy, or down towards the landing gear? Also, do you have to set up any elevator with this configuration?
thanks
supercollider is offline Find More Posts by supercollider
Old Oct 28, 2012, 06:16 PM
Terminator is offline
Find More Posts by Terminator
Yorba Linda, Ca.
Joined Oct 2003
My 2 cents...
Oh, raising hand here...I know the answer...
Both ailerons go up in crow, flaps go down towards the landing gear.
I recall reading above that no elevator compensation was required.....
You might want to give that theory a go....
I am a glider kinda guy and usually we would mix in a bit of down elevator with our crow mixes....
I was wondering why they do not couple the flaps and ailerons to lessen the travel of the ailerons it would require more channels in the receiver and transmitter ?
Also would allow you to camber whole trailing edge for short take offs and help dial in the crow landings....
back to reading....
Good luck.
Alan
Terminator is offline Find More Posts by Terminator
Old Oct 28, 2012, 09:16 PM
Joined Nov 2005
Terminator, your answers are correct, but I did not give settings for crow, just for spoilerons, and I did not see a need to mix any elevator. However, since I was flying with a nose heavy CG, I was pulling back on the stick a lot.
When I get a chance to fly after the hurricane, I will double check the trim using spoilerons and report back if any elevator should be mixed in.
Old Oct 30, 2012, 12:01 PM
WhalleyB0Y is offline
Find More Posts by WhalleyB0Y
WhalleyB0Y's Avatar
Canada, BC, Surrey
Joined Jul 2011
Does anyone have Dx8 settings for Habu crow/ flap that they wouldn't mind sharing?
WhalleyB0Y is offline Find More Posts by WhalleyB0Y
Old Oct 30, 2012, 12:12 PM
DamonH is online now
Find More Posts by DamonH
DamonH's Avatar
United States, NM, Clovis
Joined Oct 2011
I would take those as well if someone has them. Thanks
DamonH is online now Find More Posts by DamonH
Old Oct 30, 2012, 06:59 PM
harttvboy is offline
Find More Posts by harttvboy
Crazy Pilot-gone insane...
United States, CT, Monroe
Joined Nov 2009
Hi all,
I just finished upgrading to 5s and retracts and flaps. Everything seems to fit nicely .
Here is my question.
On 4s, people have had no issues with the pro esc's bec. I am using the turnigy tz85a esc with bec to power all electronics. This seems to test well with multiple cycles on the retracts and moving all the control surfaces randomly and erratically. I know flight loads will alter the amps being pulled on this esc, as well as not turning the motor on may have an effect.
http://www.hobbyking.com/mobile/view...dparentcat=455
This is the link to the esc.
I own the castle bec, and soldered it up, but removed it because of all the wiring mess. I also see that with the supplied RX I'd have to plug this into the Batt/bind port, which bothers me since I lost an airplane to an ar7000 that locked up with a similar config.
Thanks!
Best,
Chris
harttvboy is offline Find More Posts by harttvboy
Old Oct 30, 2012, 07:06 PM
Prof100 is online now
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Originally Posted by harttvboy View Post
Hi all,
Thanks!
Best,
Chris
Chris,
What is your question? I cannot find a question mark.
Bill
Prof100 is online now Find More Posts by Prof100
Old Oct 30, 2012, 07:13 PM
Joined Nov 2009
Originally Posted by Prof100 View Post
Chris,
Bill
Good call Bill -
Is the BEC on the above linked esc enough juice for my electronics?
I could see no noticable brownouts taking place.
Thanks all!
Best,
Chris
Old Oct 30, 2012, 07:18 PM
Prof100's Avatar
Joined Jul 2007
Good call Bill -
Thanks all!
Best,
Chris
Chris,
The specs show 5 amp BEC so in my mind you should rethink not using the CC 10 amp BEC and figure out a cleaner way of packaging it under the canopy. 6 servos and 3 servoless retracts is a lot of load especially one stalls. You really don't want to shut down your ESC.
Bill
Old Oct 30, 2012, 07:40 PM
Joined Nov 2009
Chris,
Bill
Thanks Bill,
I'll make an inline adapter between my ESC and battery when I get power back - we got hit by Hurricane Sandy, and will most likely be without power for days .
This stinks - I mean really, not showering stinks LOL.
Thanks!
Best,
Chris
Old Oct 30, 2012, 09:02 PM
DamonH's Avatar
Joined Oct 2011
Thanks!
Best,
Chris[/QUOTE]
Also,
You dont have to plug bec into batt/bind. You can y it into any of the other channels. I usually y it into throttle channel.
Sold 2 PNP Parkzone Habu's - willing to ship jgalexander Aircraft - Electric - Jets (FS/W) 16 Mar 29, 2012 10:44 PM
For Sale Brand New in pack ParkZone Habu EDF Jet Painted Wing PKZ7020 zsultan Aircraft - Electric - Airplanes (FS/W) 3 Nov 15, 2011 01:36 AM
For Sale Brand New in pack ParkZone Habu EDF Jet Painted Wing PKZ7020 zsultan Aircraft - Electric - Jets (FS/W) 0 Nov 13, 2011 03:40 PM
Sold Brand New Parkzone Habu EDF Jet BNF zsultan Aircraft - Electric - Airplanes (FS/W) 0 Nov 07, 2011 02:05 PM
Sold Brand New Parkzone Habu EDF Jet BNF. zsultan Aircraft - Fuel - Airplanes (FS/W) 4 Nov 07, 2011 02:04 PM
