Old Oct 02, 2012, 01:16 AM
Mugen4Lfe is offline
Find More Posts by Mugen4Lfe
Mugen4Lfe's Avatar
Joined Sep 2011
Originally Posted by crashkorey View Post
I just installed flaps and gear and with a turnigy 5 s battery on board the cg is way off. To balance the cg is now at about 2 inches from leading edge. Is this normal and if not where's the best place to hot glue some weight. I hate adding more weight.
It's always best to try moving components around for CG before adding dead weight. Try moving the esc further aft if you haven't done so already. See post #817 for ideas.
Mugen4Lfe is offline Find More Posts by Mugen4Lfe
Old Oct 02, 2012, 06:22 AM
Kurtzz is offline
Find More Posts by Kurtzz
Pounding the Kool-Aid
Kurtzz's Avatar
First Hill of the Ozarks
Joined Dec 2008
Originally Posted by proline1 View Post
Just got my Habu 2 and noticed that there was a red and yellow paint mark/dot on a couple servo plugs. Can anyone help me understand what they represent? Thanks much!
The red dots are on the retract extensions.
Kurtzz
Kurtzz is offline Find More Posts by Kurtzz
Old Oct 02, 2012, 06:24 AM
Kurtzz is offline
Kurtzz's Avatar
Joined Dec 2008
Kurtzz
Oops, will have to look tonight, they might be on the aileron extensions, been a while.
Kurtzz
Old Oct 02, 2012, 05:17 PM
proline1 is offline
Find More Posts by proline1
United States, NY, Syracuse
Joined Sep 2011
Kurtzz
Ok great look forward to update. Thanks!
proline1 is offline Find More Posts by proline1
Old Oct 03, 2012, 12:49 PM
TX79 is offline
Find More Posts by TX79
United States, NY, Cohoes
Joined Oct 2010
Flap Installation
Putting the flaps on my H2. Whats the best way to hold the servos on? Hot glue? What kind of tape to cover the wires?
TX79 is offline Find More Posts by TX79
Old Oct 03, 2012, 03:28 PM
Mugen4Lfe's Avatar
Joined Sep 2011
I like using Liquid Nails which is a silicone glue. Blenderm tape is nice and light weight.
Old Oct 03, 2012, 03:33 PM
MikePS is offline
Find More Posts by MikePS
AMA 983978
United States, FL, Jacksonville
Joined Sep 2011
I've always used hot glue on my servos in foam planes, never had an issue with them coming loose.
MikePS is offline Find More Posts by MikePS
Old Oct 03, 2012, 07:19 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Low to medium temp hot glue does the job of holding in servos.
Prof100 is offline Find More Posts by Prof100
Old Oct 03, 2012, 09:12 PM
kevinrc is offline
Find More Posts by kevinrc
Happy Habu Hustler
Joined May 2012
I carefully peeled back the original tape, then reapplied it and covered the edges with clear packing tape.
kevinrc is offline Find More Posts by kevinrc
Old Oct 03, 2012, 11:15 PM
crashkorey is offline
Find More Posts by crashkorey
United States, NJ, Freehold Township
Joined May 2009
Hey guys I put an 80 amp turnigy esc up front and I needed a lot of lead in the tail to get the 4 inch cg. Total lead weight was 2.4oz or 68.4 grams. Is this way to much and will it hinder performance? There wasso many wires from the flaps and retracts that I didn't want to put the esc in the back. I had a hard enough time getting all the wired up into the fuselage. Thanks a lot.
crashkorey is offline Find More Posts by crashkorey
Old Oct 03, 2012, 11:18 PM
jgalexander is offline
Find More Posts by jgalexander
Flying Full Size & Fun Size :)
jgalexander's Avatar
United States, CA, Calabasas
Joined Apr 2010
Too much? No. Will it decrease your performance? A little bit, but not a ton. You might consider scooting the battery as far aft as possible. In my V1 I cut away the rear foam 'supports' from the battery bay so I could get the plane CG'ed without needing extra weight. It helped a lot.
Best,
J
jgalexander is offline Find More Posts by jgalexander
Old Oct 03, 2012, 11:41 PM
Joined May 2009
Best,
J
Thanks so much. I don't think the battery will go back as the reciever is right there. I forgot to mention I had a 5s in there. Thanks again.
Old Oct 04, 2012, 12:20 AM
Joined Apr 2010
You might also consider swapping the battery and Rx locations.
If you're going to fly it nose-heavy, just keep in mind that you'll need to fly it a bit faster to avoid a stall. If it does stall, it'll lead to a sharp nose-drop - something to watch out for.
J
Old Oct 04, 2012, 02:59 AM
Mugen4Lfe's Avatar
Joined Sep 2011
The servo wire "mess" is what kept me from putting my esc in the triangle hole. I shortened many of my servo wires to get rid of the excess wiring. This freed up enough room to put the esc in the "tip" of the air intake. I try to always do whatever it takes to prevent adding dead weight.
Old Oct 04, 2012, 10:13 PM
supercollider is offline
Find More Posts by supercollider
C.E.R.N. field tester
supercollider's Avatar
United States, NE
Joined Sep 2012
Dumb question here. For the guys running 5s, are you hand launching? With the extra weight of the lipo and esc, I don't want to lawn dart it. Any advice?
supercollider is offline Find More Posts by supercollider
Sold 2 PNP Parkzone Habu's - willing to ship jgalexander Aircraft - Electric - Jets (FS/W) 16 Mar 29, 2012 09:44 PM
For Sale Brand New in pack ParkZone Habu EDF Jet Painted Wing PKZ7020 zsultan Aircraft - Electric - Airplanes (FS/W) 3 Nov 15, 2011 12:36 AM
For Sale Brand New in pack ParkZone Habu EDF Jet Painted Wing PKZ7020 zsultan Aircraft - Electric - Jets (FS/W) 0 Nov 13, 2011 02:40 PM
Sold Brand New Parkzone Habu EDF Jet BNF zsultan Aircraft - Electric - Airplanes (FS/W) 0 Nov 07, 2011 01:05 PM
Sold Brand New Parkzone Habu EDF Jet BNF. zsultan Aircraft - Fuel - Airplanes (FS/W) 4 Nov 07, 2011 01:04 PM
