Old Sep 22, 2012, 12:47 PM
fh64_lucky is offline
Find More Posts by fh64_lucky
Ginger or MaryAnn ??
fh64_lucky's Avatar
United States, TX, Garland
Joined May 2005
More blades sound the best,but fans like CS are kind of iffy....they can throw blades and hurt motor shaft and maybee cause a crash.I know alloy fan may be pricey but you will never hurt it,nor need to balance it....ever!You can always install it in another EDF if the jet crashes,thrust is its best thing,as all the multi blades over 5 will put out.I flew Wemos/HETs for years and yes they are great fans but now I am into the sound more then top speed with a few of mine.Anybody who hears it comments on that....
fh64_lucky is offline Find More Posts by fh64_lucky
Old Sep 22, 2012, 07:31 PM
WhalleyB0Y is offline
Find More Posts by WhalleyB0Y
WhalleyB0Y's Avatar
Canada, BC, Fort Langley
Joined Jul 2011
[QUOTE=WhalleyB0Y;22804537]Thanks for the input guys. The 1900kv wasn't a typo on my part but it is what I was told this motor was. The motor and ZTW esc came out of a 90mm FA18 foamie that had been scrapped. I flew that plane on 6s a few times before a reversing lead took it down.
http://edfhobbies.com/index.php?rout...&product_id=74
This is the motor I have and I can see now why it won't work in Habu.
The 5mm shaft and outrunner design wont fit into a Wemo pro mini fan.
I really would like a nice alloy fan and an optimal motor for 5s or 6s.
WhalleyB0Y is offline Find More Posts by WhalleyB0Y
Old Sep 22, 2012, 07:56 PM
erikc641 is offline
Find More Posts by erikc641
United States, NM, Las Cruces
Joined Jul 2012
Originally Posted by kalmon View Post
I was thinking about getting a Velocity 3700kv from EffluxRC but I do not know if it will fit the stock eflite EDF fan and housing. If it fits it should provide about the best power you'll get out of 4S.
-Brian
Hi Erik,
I have lots of experience with the 80mm E-Flite EDF, but never put the Smaller 70mm Delta V fan together.
The motor will fit the housing just fine, and the shaft is the proper 4mm, but you may need to shorten the shaft, and put a flat on it, as we do here. You can do it yourself from my drawing. But the numbers may be different for the 70mm E-Fite fan.
http://www.effluxrc.com/5mm-Shaft-Mo...2-EFL32-SM.htm
The rotor must always mount as close to the motor housing as possble (with rubbing the housing or the motor screws.
This motor is great for 4s, You should use a heat sink and thermal compound from the samw page.
http://www.effluxrc.com/28mm-Heat-Si...ned-2836HS.htm
5s is for burst WOT throttle only. (High speed passes)
Best regards, Gary
On Sat, Sep 22, 2012 at 10:17 AM,
You have received a contact request from a visitor to your storefront at http://www.EFFLUXRC.COM:
Velocity "3700" Semi-hot wind, 3700kv
http://www.effluxrc.com/Velocity-370...V2860-3700.htm
Will this motor bolt right in to the stock setup of the Parkzone Habu 2?
Thank you,
The Quick Shopping Cart Team
Kind regards,
Gary - efflux RC
erikc641 is offline Find More Posts by erikc641
Old Sep 23, 2012, 03:46 PM
alan49 is offline
Find More Posts by alan49
alan49's Avatar
Joined Jun 2010
Hi All
I have just ordered my first jet the habu2 and was wondering would a nano tec 5C 4000Mah be ok with a 75ESC CC lite and the sock motor.
Thanks Alan
alan49 is offline Find More Posts by alan49
Old Sep 23, 2012, 04:26 PM
jgalexander is offline
Find More Posts by jgalexander
Flying Full Size & Fun Size :)
jgalexander's Avatar
United States, CA, Calabasas
Joined Apr 2010
The batt will make you a bit nose heavy, and you might have to carve some foam from the underside of the canopy, but that's it. Guessing by 5c you mean 18.5v / 5 cells. The ESC is fine - make sure you get good ventilation.
Best,
Josh
jgalexander is offline Find More Posts by jgalexander
Old Sep 23, 2012, 04:50 PM
alan49 is offline
alan49's Avatar
Joined Jun 2010
Best,
Josh
Yes 5cell lol... Would the stock motor be OK
Old Sep 23, 2012, 05:01 PM
swps is offline
Find More Posts by swps
Some Girls r Bigger thn Others
swps's Avatar
USA, UT, Cedar Hills
Joined Jun 2010
5s 4000 will be too nose heavy IMHO. The biggest I'd go is 3300mh 5s. I've flown mine with a 4000mh 4s and it was VERY nose heavy.
It will be fine with stock motor with the ICE75.
swps is offline Find More Posts by swps
Old Sep 23, 2012, 05:24 PM
kalmon is offline
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
90%+ of the time the stock motor is just fine. Remember to use throttle management and not run it WOT all the time. Also the CC Ice Lite might not me a good idea unless you are mounting it on the belly. There is very little air flow through the electronics area and an Ice lite WILL overheat there.
5S 4000 will be quite a bit of weight up front. You'll need lead in the tail to make it balance. A much better option would be something in the 2900-3500mAh range.
-Brian
kalmon is offline Find More Posts by kalmon
Old Sep 25, 2012, 01:51 AM
supercollider is online now
Find More Posts by supercollider
C.E.R.N. field tester
supercollider's Avatar
United States, NE
Joined Sep 2012
Hi All
Thanks Alan
You could mount the esc further back than stock location, like in one of the inlet ducts or behind the fan unit. This would help cool it since it is a CC Lite. Also would help with balancing the 4000Mah. Still might need some more weight in the rear.
supercollider is online now Find More Posts by supercollider
Old Sep 27, 2012, 05:15 AM
proline1 is offline
Find More Posts by proline1
United States, NY, Syracuse
Joined Sep 2011
QUOTE=eaticus;22808842]My Habu 1 flies on 4s3300 25c GenAce. It get 3.5 minutes of mostly full throttle then it is time to land. It consumes around 2800mah.[/QUOT
I have 4S 2500Mah 25C Gens Ace available from another plane. Wondering if I drop in Habu2 (no flaps/landing gear) for shake down flights (with correct CG) is this feasible??? Any idea on flight times? 2 minutes? Thanks!
proline1 is offline Find More Posts by proline1
Old Sep 27, 2012, 12:22 PM
G-Forse is offline
Find More Posts by G-Forse
Denver, CO
Joined Nov 2007
run 2 2500 4s in parallel you should get 6-7 minutes
G-Forse is offline Find More Posts by G-Forse
Old Sep 27, 2012, 01:02 PM
boolis is offline
Find More Posts by boolis
Joined Jun 2007
Hi,What an awsome EDF plane! I was flying her all day today...did around 20 flights! My Habu 2 is tired...Check the first video of a risky flight I had today at a parking lot.See my landing passing on top of cars! Will never fly again with so many traffic at the parking lot for safety reasons.It was empty and all of a sudden it was full of cars and people.Next time this happens I will just leave or stop flying.Too risky.
ParkZone Habu 2 EDF Risky Flight (3 min 11 sec)
Another flight of today...
ParkZone Habu 2 New Version (3 min 36 sec)
One more...
ParkZone Habu 2 EDF Flight (3 min 45 sec)
boolis is offline Find More Posts by boolis
Old Sep 27, 2012, 01:06 PM
proline1 is offline
Joined Sep 2011
Ok but weight at close to 600gr!!! I was mostly thinking of running the 2500's for shake down/maiden flights until I can decide on 4S or 5S and Mah. I understand short flights but hate to jump in and rush on final power/battery set-up. Any opinions/suggestions would be greatly appreciated! Thanks
Old Sep 27, 2012, 07:45 PM
WhalleyB0Y's Avatar
Joined Jul 2011
Umm... What is a "Shake Down" flight?
Old Sep 27, 2012, 08:01 PM
Jetnfast is offline
Find More Posts by Jetnfast
Jetnfast's Avatar
United States, CA, Temecula
Joined Feb 2008
A maiden or first flight to work out the kinks, tune the trim and throws and make any fine adjustments to the CG.
Jetnfast is offline Find More Posts by Jetnfast
Sold 2 PNP Parkzone Habu's - willing to ship jgalexander Aircraft - Electric - Jets (FS/W) 16 Mar 29, 2012 09:44 PM
For Sale Brand New in pack ParkZone Habu EDF Jet Painted Wing PKZ7020 zsultan Aircraft - Electric - Airplanes (FS/W) 3 Nov 15, 2011 12:36 AM
For Sale Brand New in pack ParkZone Habu EDF Jet Painted Wing PKZ7020 zsultan Aircraft - Electric - Jets (FS/W) 0 Nov 13, 2011 02:40 PM
Sold Brand New Parkzone Habu EDF Jet BNF zsultan Aircraft - Electric - Airplanes (FS/W) 0 Nov 07, 2011 01:05 PM
Sold Brand New Parkzone Habu EDF Jet BNF. zsultan Aircraft - Fuel - Airplanes (FS/W) 4 Nov 07, 2011 01:04 PM
