Old Aug 31, 2012, 05:34 PM
efflux RC is offline
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
Originally Posted by Mugen4Lfe View Post
@effluxrc
If the desire is to reduce the amp draw and maintain the same power level, by going to 6s, what would be the reason? To avoid over amping the ESC? IF that's the reason, wouldn't it be cheaper and easier to just upgrade the ESC to a higher amp rating? Sorry, the whole point of all this kind of got lost in my brain!
The whole point of post #654 was to explain how to reduce the amp draw by going to 6s.
The power is the same.
The watts is the same.
The rpms are the same.
The amps are lower (and the voltage is higher) with 6s......using a 2133 (or about) motor.
That was the whole exercise as was Wallyboy's? desire.
Most folks are looking for more speed by going to a higher cell count.
Some folks look for more speed by using only a higher kv motor than stock, (with a 4s count, big bigger lipos) but the amps go waay up.
Either is not the case here.
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Aug 31, 2012, 08:16 PM
Josef086 is offline
Find More Posts by Josef086
Joined Jan 2010
@effluxrc
Applying what @efflux said with his example:
If you plan to run the stock motor on 5s switch to a larger esc. I tested mine on the watt meter and saw I was pulling 65 amps.
A 6s setup on a 2700kv motor will allow you to have the same performance as running the stock motor on 5s but will draw amps closer to watt the stock setup does on 4s.
Josef086 is offline Find More Posts by Josef086
Old Sep 01, 2012, 12:17 PM
WhalleyB0Y is offline
Find More Posts by WhalleyB0Y
WhalleyB0Y's Avatar
Canada, BC, Fort Langley
Joined Jul 2011
Nah I got sidetracked onto a subject regarding a different plane. The wemo fans can only handle a certain amount of rpms and my motors can exceed that quite easily. I wanted to limit this with modified throttle curve not to reduce the current but to limit the rpms so the plane flies more scale and not like a funjet.
I completely understand the controller function and how the motor see full current at a frequency relevant to the throttle input. I am not trying to reduce the amps because the esc can handle full current. I know I can buy more motors with a lower kv to also reduce rpm. Or use a lower voltage blah blah. I am just saying that one could produce the same power output of a lesser voltage setup as with a higher voltage setup and reduce the current.
I refered to my other edf (not a habu) that has a lot of thrust. By programming flights modes with different throttle curves I can go from funjet style flying at full throttle to more scale flying with the flick of a switch. More importantly I can fly with only the rpms I need and not have to worry about throttle management because the throttle is limited to the curve programmed in a flight mode.
Sorry about the confusion, but it appears that I really needed to explain myself.
WhalleyB0Y is offline Find More Posts by WhalleyB0Y
Old Sep 01, 2012, 09:42 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Thanks for the clarification.
Bill
Prof100 is offline Find More Posts by Prof100
Old Sep 02, 2012, 11:50 AM
tclaridge is online now
Find More Posts by tclaridge
United States, VA, Clifton
Joined Nov 2005
The burst rate for the Pro 60 ESC is 75 amp for 15 sec. Are folks trading up to the Pro 80 because of the heat using 5S, or just the max amps going over 60 amp (continuous).
I would like to know if anyone tried keeping the stock ESC on 5S and if it worked. The spec says it should be fine.
tclaridge is online now Find More Posts by tclaridge
Old Sep 02, 2012, 12:46 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
You want headroom for any ESC application. There have been posts of guys running a 5S with the stock ESC but they never report back when it melts down and the plane crashes. It would be too much like eating crow. I run a 5S with a Hobbywing 80 amp ESC and it gets very warm if I have a spirited flight.
Old Sep 02, 2012, 01:37 PM
swps is offline
Find More Posts by swps
Some Girls r Bigger thn Others
swps's Avatar
USA, UT, Cedar Hills
Joined Jun 2010
I have on one in the past but I was at 61amp on that system and it worked fine. My buddy saw me doing that and we measured his and he was at 69 amps but still gave it a whirl. He had a thermal shut down about a minute in but 5s stuck with him as he upgraded to an 80amp esc that week. On my current Habu 2 I didn't even try and just replaced it with an 80 amp hobbywing and sold my 60 amp and still came out ahead in $$$.
swps is offline Find More Posts by swps
Old Sep 03, 2012, 10:28 AM
kalmon is offline
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
Burst rating is just that, burst. 5S runs at 65 continuous. It will probably work for a few flights but it will eventually melt and you'll have a habu lawn dart. When you spec and ESC you want headroom and to be safe always pick an ESC that is the next step up from the highest recorded amps you measure on the motor/fan combo.
In this case 65 measured so a 70+ should be fine, in my case I like CC so the CC75 would be the right choice.
-Brian
kalmon is offline Find More Posts by kalmon
Old Sep 04, 2012, 09:51 AM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
Originally Posted by lashmett75 View Post
Got mine all done and ready to maiden this weekend. She is out fitted with a TJ70 fan with the changsun 10 bladed rotor. All stock servos and eflite retracts. It is all stock except the power system. I did use the dremel and sanding disk to open the battery well to except a 6s 3300 65c nano tech battery. esc is the cc lite ice 100. Here are some photos.
Nice work on the 6s setup and moved ESC. How many caps did you use for the long battery leads?
Old Sep 04, 2012, 07:00 PM
shung1 is offline
Find More Posts by shung1
shung1's Avatar
Joined Jan 2011
Hi mate, I just did the same mod to mine, running an EXTREME 70mm ALLOY 10 BLADE FAN & HET MOTOR 6s 900+W. I to moved the esc into the air duct for betta cooling. Also i set mine up as flapperons instead of installing 2 extra servo's. How did you find the CG with the 6S Lipo and retracts installed? Cheers
Photo's & footage up soon......
shung1 is offline Find More Posts by shung1
Old Sep 04, 2012, 07:30 PM
jimmy34256 is offline
Find More Posts by jimmy34256
Destructive Tester
jimmy34256's Avatar
Tampa, FL
Joined Apr 2008
Any speed readings from this setup???
jimmy34256 is offline Find More Posts by jimmy34256
Old Sep 04, 2012, 08:53 PM
shung1 is offline
shung1's Avatar
Joined Jan 2011
not yet hopefully soon.
Old Sep 05, 2012, 12:42 AM
efflux RC's Avatar
Joined Aug 2009
@effluxrc
For most folks it's not. Most who go to higher cell counts are looking for more speed. That was covered in the posts above.
Site Sponsor
Old Sep 05, 2012, 01:51 AM
Mugen4Lfe is offline
Find More Posts by Mugen4Lfe
Mugen4Lfe's Avatar
Joined Sep 2011
@effluxrc
I'm fully aware that most people go to a higher cell count for more speed. That's actually the whole reason I asked the question in the first place..."why go to a higher cell count and then limit the throttle?" I couldn't see the reason behind it. But Whalleyboy answered it in post #663 and it's clear now how the whole line of questioning got started in the first place.
Mugen4Lfe is offline Find More Posts by Mugen4Lfe
Old Sep 05, 2012, 11:06 PM
Joined Nov 2005
Thanks guys for the info on 5S with stock ESC. Just the explaination I was looking for. Looks like it pushes the stock ESC too hard, but the Pro 80 is an easy upgrade.
Sold 2 PNP Parkzone Habu's - willing to ship jgalexander Aircraft - Electric - Jets (FS/W) 16 Mar 29, 2012 09:44 PM
For Sale Brand New in pack ParkZone Habu EDF Jet Painted Wing PKZ7020 zsultan Aircraft - Electric - Airplanes (FS/W) 3 Nov 15, 2011 12:36 AM
For Sale Brand New in pack ParkZone Habu EDF Jet Painted Wing PKZ7020 zsultan Aircraft - Electric - Jets (FS/W) 0 Nov 13, 2011 02:40 PM
Sold Brand New Parkzone Habu EDF Jet BNF zsultan Aircraft - Electric - Airplanes (FS/W) 0 Nov 07, 2011 01:05 PM
Sold Brand New Parkzone Habu EDF Jet BNF. zsultan Aircraft - Fuel - Airplanes (FS/W) 4 Nov 07, 2011 01:04 PM
