Old Aug 24, 2012, 05:55 PM
fh64_lucky is offline
Find More Posts by fh64_lucky
Ginger or MaryAnn ??
fh64_lucky's Avatar
United States, TX, Garland
Joined May 2005
Add CF to wings, and to horizontal stabs.Move stock fan location back farther to allow for more batteries.Change out elevator servo to a MG and flaps if you use them(I dont) Tac glue all the pieces that are held in with screws, it will make overall airframe stronger yet you can cut them off if you ever need to get back into those areas.Thats about all I have, and I have the strongest setup to date, and its holding up great! Joe
fh64_lucky is offline Find More Posts by fh64_lucky
Old Aug 24, 2012, 06:56 PM
STANG KILLA SS is offline
Find More Posts by STANG KILLA SS
STANG KILLA SS's Avatar
Killeen TX
Joined Dec 2006
how are you adding CF to the wings? since it appears to have dihedral?
STANG KILLA SS is offline Find More Posts by STANG KILLA SS
Old Aug 24, 2012, 07:40 PM
Mugen4Lfe is offline
Find More Posts by Mugen4Lfe
Mugen4Lfe's Avatar
Joined Sep 2011
In the stock configuration, I don't feel that it needs carbon fiber spars. Also, I believe the stock elevator servo IS metal geared.
Mugen4Lfe is offline Find More Posts by Mugen4Lfe
Old Aug 24, 2012, 08:16 PM
fh64_lucky's Avatar
Joined May 2005
He asked about upgrading the Habu with high powered setup.....I do not know about the stock servos, but I rather not trust the 1 servo that it comes with on hi-per setups.
http://www.rcgroups.com/forums/showp...4&postcount=74
I am right at 3000 watts with crazy verticle, but it is never going to be a speed demon.I am at 125mph now (which is over 40mph from stock setup)
without thrust tube with my new 6s 65c3300 , even if I put thrust tube in,130s is all about its going to hit.Wing is thick,intakes are huge,and its on draggy side overall, but for what it was made for,its better then perfect as it flies brilliant for a foamy.
Old Aug 24, 2012, 08:22 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
I agree. No CF spars needed for a stock configuration or even a 5S upgrade.
Prof100 is offline Find More Posts by Prof100
Old Aug 24, 2012, 08:33 PM
fh64_lucky's Avatar
Joined May 2005
You may not "need" CF on wings on a 5s or more setup, but that wing flex is not good on ailerons and servos as it will end up breaking wires at servos...experience talking.
I know this thread seems to have interest in stock setups and newer pilots to EDFs and thats great, I chose to start a thread on the building,mods and flights of higher performance Habu's. If anyone has interest in that side of this cool jet,read up on my thread, shows how you can have 6s setups that are not nose heavy and no need for any lead in the tail either.
Old Aug 24, 2012, 09:01 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
A modification thread is always a great idea. Fire it up, I will subscribe, but you have to post a boat load of build pictures of your mods. I would also suggest saving the first few posts as a "reserve" to post links to airframe mods, power system, etc.
Bill
Old Aug 24, 2012, 09:06 PM
fh64_lucky's Avatar
Joined May 2005
I all ready did a few weeks ago....
http://www.rcgroups.com/forums/showthread.php?t=1698345
Rather keep stock vrs hi-per seperated as the newer guys who are not sure about removing foam or alot of experience in mods prolly dont want to try what a few of us are doing.I flew a stock habu,and knew it was a great platform,just way to slow for me to keep my interest,now with red/white n blue colors it appealed to my taste more but was sure it was never going to see a stock second of flying...lol
Old Aug 24, 2012, 09:07 PM
Killeen TX
Joined Dec 2006
definatly interested in a thread of this type.
so no one has any speed/drag comparisons of the habu, VS the Freewing Cobra/ Hobby Lobby Rebel?
Old Aug 24, 2012, 09:24 PM
fh64_lucky's Avatar
Joined May 2005
Well, IMO they will all be about the same,EPO foam,semi sym wings ect.
It would be hard to compare them,I think the Habu spent a good amount of time on the drawing boards before they put it out as it is a really nice design, goes together with no problems and very easy to mod with alot of options open to hop-ups.The bolt on retracts are also no fuss and work great.This is one of the few foamys I am really enjoying.
Old Aug 25, 2012, 01:37 PM
Mugen4Lfe's Avatar
Joined Sep 2011
I'm seriously thinking of stepping up to a 5s. The added WEIGHT of retracts has not been the most thrilling "upgrade". During my thread searches, I've seen many have made the move to 5s and have reported no problems with the stock motor. Others have fried theirs. The BL15 3200kv is supposedly "rated" for only up to 4s. I guess I need to decide to take the plunge or not. Anyone want to talk me into or out of it?
Old Aug 25, 2012, 02:20 PM
kevinrc is offline
Find More Posts by kevinrc
Happy Habu Hustler
Joined May 2012
If you're looking for input from others, that itself is a big vote for flying the airplane as-is.
If later you want the greater performance and expense of upgrading to 5s you can do so. If you do it now and regret it you're already out the money, and if you cut foam foam out it may not go back in.
kevinrc is offline Find More Posts by kevinrc
Old Aug 25, 2012, 04:21 PM
Killeen TX
Joined Dec 2006
im definatly not doing flaps or retracts. gonna go light for the high power setup. its a grass field so ill be hand launching(another reason to keep light) and belly landing.
Old Aug 25, 2012, 07:17 PM
Killeen TX
Joined Dec 2006
what kind of hinges are on the habu?
Old Aug 25, 2012, 07:51 PM
kalmon is offline
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
The Habu is probably the perfect first EDF. It is nice looking, and flies very well when slow. It is not a speed demon and takes tons of work to go fast. I can't compare it to the hobbylobby Rebel/freewing Cobra, I can say that it is great design that does what it is supposed to do extremely well.
Bone stock out of the box, you'll still get 90mph so can't complain to much about speed.
Foam live with hinges, tape on it as well.
-Brian
kalmon is offline Find More Posts by kalmon
Sold 2 PNP Parkzone Habu's - willing to ship jgalexander Aircraft - Electric - Jets (FS/W) 16 Mar 29, 2012 09:44 PM
For Sale Brand New in pack ParkZone Habu EDF Jet Painted Wing PKZ7020 zsultan Aircraft - Electric - Airplanes (FS/W) 3 Nov 15, 2011 12:36 AM
For Sale Brand New in pack ParkZone Habu EDF Jet Painted Wing PKZ7020 zsultan Aircraft - Electric - Jets (FS/W) 0 Nov 13, 2011 02:40 PM
Sold Brand New Parkzone Habu EDF Jet BNF zsultan Aircraft - Electric - Airplanes (FS/W) 0 Nov 07, 2011 01:05 PM
Sold Brand New Parkzone Habu EDF Jet BNF. zsultan Aircraft - Fuel - Airplanes (FS/W) 4 Nov 07, 2011 01:04 PM
