Feeling your pain on the 130X...
Just got a new main board, flipped it inverted, then the tail started piroing as fast as it could. WTH? Any ideas? Tail gears aren't stripped. |
Latest blog entry: 3DHS 48" Extra Windy Day Flying
Nope they are solid.
Fairfield County, Connecticut
Joined Dec 2009
I made a 3D printed 3rd torque tube bearing case, you can check it out at helifreak: http://www.helifreak.com/showthread.php?t=507723
My other 130X's DS35 finally went bad. It is now chattering after countless flights. If you guys would read the reviews of the DS35 http://www.horizonhobby.com/products...gsReviews=true, that issue is common or maybe VERY COMMON. But having tried DS35 on my 130x, I will never go back to linear servo for rudder use. The stock linear servo constantly oscillates causing tail to go bad eventually. I have gone through all HobbyKings's servos and can not find any substitute. Finally found one that maybe possible and risked ordering one. Just received it, a DS37 and hooked it up loose (unmounted). 1. DS35 = 3.5 gram digital, whereas, DS37 is a 3.7gram digital 2. The servo was reversed throw compared to DS35 3. DS37 = 19.9mm from front to back, with 8.5mm thickness DS35 = 17.7mm with 6.5mm thickness USAGE: 1. With the DS35, my servo mount (or any mount) is a true plug & play. Because the DS37 was 1.5mm longer, I had to eliminate the two brackets included with the mounting hardwares, trim the servo ears and use dab of epoxy to glue it to the servo mount. Drop of CA should also work. 2. Reversed the servo throw, which requires soldering skills swapping four hair size cables inside the DS37 servo. Mounting the servo on the right side of the boom, rather than left side should also work the same, which I did not try. * Utilizing the servo mount I use, does not matter with the 2mm difference thickness. * trim the servo ears, and use epoxy instead. Parts used: 1. http://www.banggood.com/Wholesale-Wa...7-p-50193.html 2. http://www.oomodel.com/v120d02s-serv...o-p-63449.html I will fly the heli tomorrow, and if everything is well (I don't see why not), I will use the same servo on my other 130X once it's DS35 servo also wears out. * The second picture is the DS35 servo that went bad, the rest of the pics is DS37 on my 130X. |
Yes, both items were free shipping too.
I just tried it flying outside the house. It worked so far. Tomorrow, I will try it 3D flying. I am placing another order of servo just in case I need one, I don't have to wait for the next boat to depart. I don't mind paying extra on the DS35 but the DS37 may have better longevity. OK, I'll just admit it, I'm also cheap ![]() - Spyro |
Yeah, I'd like to know as well.
About 100-150 hundred flights on DS35. I fly around 15-20 flights a week. So it was not that much as far as "how many weeks". The linear tail servo on both my 130s had less flights before it went gradually bad. Not complaining about any of the servos, but a better servo would be awesome, right? I just came back from the field. I flew the DS37 a few times. Last flight, I had bad tail wag on FFF. I am not sure if it was the gyro or the servo or what caused it. It won't stop, even after I stopped it to hover. I decided to hit normal flight mode, and wag disappeared. Toggled to stunt mode and did it again sometime during the flight. Clicked the NORMAL mode & wag disappeared again, including the 130X ![]() It was so windy, and normal mode should have not been an option Wind took my heli. ![]() Went to pick it up, nothing was damaged at all. Flew it again, of course, it run out of juice on inverted ![]() I packed up, it's too windy and gusty, no one else wants to fly but me. Both my 130s were OK at the end of the day, so I'm happy. I was not able to pin point what caused the tail wag during my last flight. The wind is too strong to trouble shoot, test, & fly again. And I don't want to break parts. It could be just the rudder gain since the DS37 has more servo throw compared to the stock linear and the prior DS35. I could either: 1. lower the gyro gain ? 2. move the pushrod to the inner hole of the servo arm? 3. Or decrease my rudder throw (dual rate)? |
Decreasing rudder throw will only lower the piro rate, won't affect system gain which if too high causes wagging..
I would suggest moving in on the arm to get the same throw as the DS35. Then the mechanical gain is the same so you should not have to lower the electrical gain. Pat MacKenzie |
Latest blog entry: er9x heli 450 heli set up (flybar)
It flew great the first few flights until the last one. I will move it to the next inner hole before I fly it again. I don't want to lower gyro gain as much as possible if possible, unless I have to. - Spyro |
| Thread Tools | |
| For Sale New in the box E-Flite Taylorcraft ARF Kit plus High Performance E-Flite components | Philscho | Aircraft - Electric - Airplanes (FS/W) | 4 | Aug 19, 2012 12:25 AM |
| For Sale E-Flite 300 32e SHP ****SOLD*** E-Flite still aviable | tomtheman | Aircraft - Electric - Airplanes (FS/W) | 2 | Mar 28, 2012 08:01 PM |
| Sold E-flite 60A ESC w/ E-flite Brushless 1010kV Motor | joshfneptune | Aircraft - Electric - Power Systems (FS/W) | 3 | Mar 05, 2012 08:18 PM |
| Discussion E-Flite Taylorcraft 450 ARF Kit and High Power E-Flite electrical components $300 | Philscho | Hot Online Deals | 1 | Mar 02, 2012 08:11 PM |
| Discussion E-Flite Su-26 and E-flite Extra 260 repair | Joe Slow | Crash Discussion | 1 | Sep 27, 2011 11:50 AM |
