Old Feb 12, 2013, 02:56 PM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Originally Posted by johnnyrocco123 View Post
What are the dimensions of the stock batteries?
Do the TP batts fit with ease?
The TP 325 65c packs and the new Hyp 400 & 500 35c packs fit under the canopy just fine without any modifications at all. Just strap them down on the battery tray like you do with any other pack. The CG is pretty close to neutral with the TP 325 65c & Hyp 400 35c packs. The bird is slightly nose-heavy with the Hyp 500s, but not enough to notice when sport-flying or doing basic aerobatics.
Joel
turboparker is offline Find More Posts by turboparker
Old Feb 12, 2013, 03:22 PM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
Joel
Cool thanks,
I will get a few.
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Feb 14, 2013, 01:02 AM
iTz Nicholas72 is offline
Find More Posts by iTz Nicholas72
Joined Nov 2010
White wrap for my extended tail boom supports
iTz Nicholas72 is offline Find More Posts by iTz Nicholas72
Old Feb 14, 2013, 01:56 AM
GrahamWilson is offline
Find More Posts by GrahamWilson
Beating air into submission!
GrahamWilson's Avatar
Australia, NSW, Vaucluse
Joined Aug 2011
After three months of flying my 130x today it loses the bind to my DX8 and it will not rebind. Tried to bind it to a DX7 with no connection happening.. Any ideas or has the board gone to RC heaven?
GrahamWilson is offline Find More Posts by GrahamWilson
Old Feb 14, 2013, 08:11 AM
garryk is offline
Find More Posts by garryk
Corsair Captain
United States, AZ, Mesa
Joined Oct 2010
Call HH and tell them what's up. They're usually very good at replacing a bad part.
Garry K.
garryk is offline Find More Posts by garryk
Old Feb 14, 2013, 09:35 AM
rynldgalano is offline
Find More Posts by rynldgalano
REYNALDO
rynldgalano's Avatar
Cyprus, Nicosia
Joined Dec 2011
unplug your motor and servos, connect the battery to the rx and on your tx set your troutle to 100% position hold the bind mode while making on your tx.
rynldgalano is offline Find More Posts by rynldgalano
Old Feb 17, 2013, 01:37 PM
MarkEHansen is offline
Find More Posts by MarkEHansen
United States, CA, Sacramento
Joined Jun 2012
Pitch curve on the 130X using DX6i?
After lurking for a long time, I finally purchased a 130X and am setting up my Spektrum DX6i based on the values in the 130X manual.
However, I don't seem to be setting the pitch curve properly. The 130X manual shows settings for Normal, Stunt and Hold.
It was my understanding that to select Normal mode on the DX6i, I set the switch marked "Gear / F Mode" to 0 (zero) and to select Stunt mode, I set the switch to 1.
However, no matter what I set the pitch curve for Normal mode, and regardless of the F Mode switch position, I get full pitch (negative to positive) with the collective stick movement.
I even set the pitch curve for Normal mode to 50% for all 5 positions, and I still get full pitch change when I move the collective stick (with the F Mode switch in either position).
Am I using the wrong switch to select Normal/Stunt mode?
I'm a beginner with collective pitch and really don't want to start with any negative pitch until I get a better feel for the helicopter.
MarkEHansen is offline Find More Posts by MarkEHansen
Old Feb 17, 2013, 01:44 PM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Are you checking with the throttle hold on?
It has its own pitch curve and will take priority over any other flight mode.
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Feb 17, 2013, 02:17 PM
Joined Jun 2012
Thanks Pat. That was it. I went down this path because when I reduced to low collective while in low hover, I saw the heli get pulled down to the ground. However, *that* was probably due to the pitch at low collective (in normal mode) being just a little to low. The book says to set it to 30%, but I'll try starting at 35% or maybe 40%.
Thanks again for your help. I knew it had to be something silly
Old Feb 17, 2013, 03:55 PM
Joined Jun 2012
That didn't take too long. I cracked the landing skids on the 130X. I tried using super glue, but I can't get it to bond. I've tried the two brands that I have: Gorilla Glue and Krazy Glue. Both say to hold the parts together for 30 seconds, which I've done. As soon as a let go, the parts just come back apart. Can this type of plastic not be bonded with super glue, or am I using the wrong type?
Old Feb 17, 2013, 04:00 PM
Joined Jun 2012
Also, does anyone know of a set of training gear that I can buy for this sized helicopter? I looked on the Horizon Hobby web site and didn't see anything. Is it considered unnecessary for such a small helicopter?
Old Feb 17, 2013, 04:02 PM
CatBird is offline
Find More Posts by CatBird
CatBird's Avatar
Louisville, Colorado
Joined Oct 2007
I have yet to break a landing skid, but I've been amazed at how well this Plastruct Plastic Weld (Google that to see a picture) works on other parts made of the same plastic. In my experience, stuff that gets hard (CA and Epoxy) isn't much use on this type of flexible, waxy plastic. Others have reported success with hot glue as well - also flexible.
CatBird is offline Find More Posts by CatBird
Old Feb 17, 2013, 04:03 PM
lasakro is offline
Find More Posts by lasakro
Seeking Control
lasakro's Avatar
United States, NY, Amsterdam
Joined Dec 2012
Guess not I've found a couple of layers of heat shrink tubing to work well while waiting for the replacements to arrive just go easy on them. Haven't had luck with glue. I also haven't tried melting them together with a soldering iron.
There is training gear out there. I think a saw them at HeliDirect.
lasakro is offline Find More Posts by lasakro
Old Feb 17, 2013, 05:05 PM
Joined Jun 2012
Heh, if I could go easy on it, I probably wouldn't have broken it in the first place
Seriously though, thanks to you both for the advice.
Old Feb 17, 2013, 05:14 PM
brushless55 is online now
Find More Posts by brushless55
big ignore list
brushless55's Avatar
United States, CO, Longmont
Joined Nov 2011
I had this crazy buzzing vibration thing going on in the tail shaft
so I pulled the tail shaft and put several drops of thick oil on it, re installed the shaft and dang it is smooth as butter now!!
brushless55 is online now Find More Posts by brushless55
For Sale New in the box E-Flite Taylorcraft ARF Kit plus High Performance E-Flite components Philscho Aircraft - Electric - Airplanes (FS/W) 4 Aug 19, 2012 12:25 AM
For Sale E-Flite 300 32e SHP ****SOLD*** E-Flite still aviable tomtheman Aircraft - Electric - Airplanes (FS/W) 2 Mar 28, 2012 08:01 PM
Sold E-flite 60A ESC w/ E-flite Brushless 1010kV Motor joshfneptune Aircraft - Electric - Power Systems (FS/W) 3 Mar 05, 2012 08:18 PM
Discussion E-Flite Taylorcraft 450 ARF Kit and High Power E-Flite electrical components $300 Philscho Hot Online Deals 1 Mar 02, 2012 08:11 PM
Discussion E-Flite Su-26 and E-flite Extra 260 repair Joe Slow Crash Discussion 1 Sep 27, 2011 11:50 AM
