Old Feb 07, 2013, 07:38 PM
garryk is online now
Find More Posts by garryk
Corsair Captain
United States, AZ, Mesa
Joined Oct 2010
Originally Posted by SYMAWD View Post
Probably a Spin 8000 above. Seems similar to mine:
http://www.youtube.com/watch?v=sXr4qDe9qGM
Hey,,, I got the Spin 8800 KV and the stock screws are too big. I went to ACE Hardware and the smallest they had were the same size as the stock ones. Where can I get mounting screws smaller than the stock .80mm size?
Garry K.
garryk is online now Find More Posts by garryk
Old Feb 07, 2013, 09:06 PM
dsobbe is offline
Find More Posts by dsobbe
United States, IL, Chicago
Joined Jan 2011
Garry K.
Try Microfasteners.com
dsobbe is offline Find More Posts by dsobbe
Old Feb 07, 2013, 11:00 PM
CatBird is offline
Find More Posts by CatBird
CatBird's Avatar
Louisville, Colorado
Joined Oct 2007
Originally Posted by J_skaggs View Post
I have two 130X's and both consistently take off to the left and slightly to the rear. I consider it normal. If I just pop it up in the air, it goes straight up. If yours is really excessive, adjust the swash to grip linkages to try to correct it.
I fly my two on the same program, so that's a constant. One lifts off totally straight. The other tilts forward and right, but then is rock solid the minute I pop it up. I've tried adjusting the links manually and it made no difference for me. But now that I'm used to the little pop the moment I see it get light on the skids, it's not worth messing with.
CatBird is offline Find More Posts by CatBird
Old Feb 08, 2013, 12:10 AM
J_skaggs is offline
Find More Posts by J_skaggs
United States, CA
Joined Jan 2012
Agreed. If it flies right once airborne, that's what matters to me.
J_skaggs is offline Find More Posts by J_skaggs
Old Feb 08, 2013, 01:26 AM
Spyro37 is offline
Find More Posts by Spyro37
WIFE HAND LAUNCHED MY PLANES!
Spyro37's Avatar
Joined Jun 2009
Originally Posted by Rain4LA View Post
But I'm still going to fly my 130X on the 8s. The new settings seem to work really well.
Could you PLEASE email me your 8S "Model.ini" file settings.
I am getting THIS SERVO ISSUE using my Devo 8S Tx with DeViation hack FW.
Notice carefully that I get elevator and aileron "run-away servo" 'till they bind, even on the slightest throttle stick movement.
I am now sending you a PM of my email address, if you can send me the file.
Note that, I have tried all my Helis with AS3X gyro, and they were all doing the same thing. I would rather use the DeViation on my small helis than on the DX6i
- Spyro
Spyro37 is offline Find More Posts by Spyro37
Old Feb 08, 2013, 09:51 AM
Rain4LA is offline
Find More Posts by Rain4LA
Rain4LA's Avatar
Joined Nov 2012
- Spyro
Check your email.... I sent you that file.
Rain4LA is offline Find More Posts by Rain4LA
Old Feb 08, 2013, 12:02 PM
indoorheli is offline
Find More Posts by indoorheli
2 seconds from crashing
indoorheli's Avatar
United States, WA, Seattle
Joined Sep 2007
Hey listen - thanks for your help. I really appreciate it. I kept thinking about what you said the other day about the DFC head needing to be tight. Well you were RIGHT! And I am so happy! I tightened up the aluminum linkages that connect to the rotor hub and that got rid of the slop. BINGO! That was it. I wasn't used to that configuration, so I thought I needed it to be a little loose there for movement. But that was dumb. There shouldn't be any movement. Movement = play in this case. Oh well, live and learn, right? I mean, I still haven't flown it outside yet because of the snow. And I still have to nurse it off the ground because it wants to rotate and stuff. But bottom line.... When it gets off the ground, it's humming like a kitten. I couldn't be more psyched. I had to look everywhere until I finally found those Xtreme linkages in stock somewhere. I never did like those cheesy little plastic ones from Blade. So I'm really glad that they weren't the problem! But anyway, it's a bad-ass bird now. And I can't wait til this weather changes. Right now it's a freakin' blizzard.
But on a different note, I went ahead and bought a DX6i for my 300x so I could use the recommended settings. (Maybe it also had something to do with what you were saying about safety too. ) But I just want everything to be right on that helicopter. And I don't want to confuse that cool receiver in any way. But I'm still going to fly my 130X on the 8s. The new settings seem to work really well.
Thanks again!
Glad you got it working, what a great heli when it is in the air
That 8s is a great radio and I really liked the ones I had. But like I said when i move up the size of the heli the respect for the damage it can do also grows. I just dont want to increase my chances many fold in finding an unknown glitch. For 130 and smaller I see no issues with using custom FW and it makes it so you can play with a large range of micro heli's.
While the dx6i, or any spek radio for that matter isnt cheap, chances are reduced drastically for possible issues and if anything goes wrong and they will be right there helping.
You will love that 300x, I just got another one just yesterday. Hopefully I will get to fly it today
indoorheli is offline Find More Posts by indoorheli
Old Feb 08, 2013, 09:11 PM
Benf207 is offline
Find More Posts by Benf207
Fairfield County, Connecticut
Joined Dec 2009
Do you guys think it's worthwhile to do a motor upgrade?
Benf207 is offline Find More Posts by Benf207
Old Feb 08, 2013, 11:01 PM
indoorheli's Avatar
Joined Sep 2007
I think the hp08s was a very nice upgrade from stock.
Old Feb 09, 2013, 12:03 AM
CatBird is offline
CatBird's Avatar
Joined Oct 2007
Happened to see an ad for 15% off Boca bearings at the Boca web site. Coupon code 15CART2012. I'm not quite to the point of needing to replace mine, so I can't vouch for it, but others might give it a try.
Old Feb 09, 2013, 12:23 AM
Corsair Captain
Joined Oct 2010
I just upgraded mine to the Spin 8800kv with a 10t pinion. I flew 1 battery and it definitely has more zing. The wind was about 20mph though, so my tick tocks were all over and I'm not that good at them yet anyways. I am looking forward to trying it again in better conditions.
Garry K.
Old Feb 09, 2013, 01:15 AM
brushless55 is offline
Find More Posts by brushless55
big ignore list
brushless55's Avatar
United States, CO, Longmont
Joined Nov 2011
Originally Posted by lovespicyfood View Post
Maybe look at gear mesh and adjust. Mine ran a little hot when I first got it and once I adjusted mesh, temps went down significantly. I now have probably ~80 flights and it runs strong.
I'll check that out
brushless55 is offline Find More Posts by brushless55
Old Feb 09, 2013, 01:17 AM
big ignore list
Joined Nov 2011
is a new esc needed for this motor or will the stock esc work just fine?
thanks
Old Feb 09, 2013, 09:24 AM
lasakro is offline
Find More Posts by lasakro
Seeking Control
lasakro's Avatar
United States, NY, Amsterdam
Joined Dec 2012
thanks
Stock ESC is fine.
lasakro is offline Find More Posts by lasakro
Old Feb 09, 2013, 12:19 PM
keithy4129 is offline
Find More Posts by keithy4129
United States, NJ, Clayton
Joined Aug 2010
Just picked up a 130x with a metal umbrella gear. Does anyone know if the metal gear wontbe so close to servo, the stock plastic one is pretty much touching it.
keithy4129 is offline Find More Posts by keithy4129
For Sale New in the box E-Flite Taylorcraft ARF Kit plus High Performance E-Flite components Philscho Aircraft - Electric - Airplanes (FS/W) 4 Aug 19, 2012 01:25 AM
For Sale E-Flite 300 32e SHP ****SOLD*** E-Flite still aviable tomtheman Aircraft - Electric - Airplanes (FS/W) 2 Mar 28, 2012 09:01 PM
Sold E-flite 60A ESC w/ E-flite Brushless 1010kV Motor joshfneptune Aircraft - Electric - Power Systems (FS/W) 3 Mar 05, 2012 09:18 PM
Discussion E-Flite Taylorcraft 450 ARF Kit and High Power E-Flite electrical components $300 Philscho Hot Online Deals 1 Mar 02, 2012 09:11 PM
Discussion E-Flite Su-26 and E-flite Extra 260 repair Joe Slow Crash Discussion 1 Sep 27, 2011 12:50 PM
