Espritmodel.com Heli Air
Old Feb 05, 2013, 02:23 PM
Rain4LA's Avatar
United States, IL, Chicago
Joined Nov 2012
There's a whole lotta shakin' goin' on!
130x2 (0 min 30 sec)
Yeah, so instead of somersaulting, it's got some serious jitters.
Sometimes I wonder if I picked the right hobby...
But I can't seem to stop.
Rain4LA is offline Find More Posts by Rain4LA
Old Feb 05, 2013, 02:30 PM
Controls Engineer
lasakro's Avatar
United States, NY, Amsterdam
Joined Dec 2012
Originally Posted by Rain4LA View Post
http://www.youtube.com/watch?v=rDs5z...ature=youtu.be
It's kind of strange that there are now 2 people in the past few pages with helis that look bad gyros? Maybe?
lasakro is offline Find More Posts by lasakro
Old Feb 05, 2013, 02:34 PM
indoorheli's Avatar
United States, WA, Seattle
Joined Sep 2007
That looks like a mechanical issue, how does your tail move without the tail rod connected?
I had a 450pro that did similar (though not at Fast forward), and it turned out to be bad bearings. Somewhere something is binding
indoorheli is offline Find More Posts by indoorheli
Old Feb 05, 2013, 02:36 PM
Can't get enough
jabsten's Avatar
United States, WA, Puyallup
Joined May 2010
Mechanical I would say. Also what are you doing with the tail servo?
J
jabsten is offline Find More Posts by jabsten
Old Feb 05, 2013, 02:38 PM
Controls Engineer
lasakro's Avatar
Joined Dec 2012
He also mentioned a bunch of sub-trim just to get it off the ground. Then it does that.
Old Feb 05, 2013, 02:40 PM
indoorheli's Avatar
Joined Sep 2007
Yeah, if you are trying to fight a mechanical issue with the tx the gyros will get even more confused
Old Feb 05, 2013, 02:46 PM
Controls Engineer
lasakro's Avatar
Joined Dec 2012
I still would like to know what happens to the swash after you apply throttle. No motor and no sub trims.
Old Feb 05, 2013, 02:49 PM
indoorheli's Avatar
Joined Sep 2007
Yes that would show one issue and he should do that test too to check if he is getting added cyclic on take off. Though that would not cause main the issue in that video.
Old Feb 05, 2013, 03:14 PM
Rain4LA's Avatar
Joined Nov 2012
Are you talking about the tail rod to the servo? It is connected. It's just not the stock servo. It's a DS95.
Also, some of the mechanical issues could be because of these mods (most likely is) I just installed the DFC style head and tail mods.
[IMG][/IMG]
[IMG][/IMG]
Old Feb 05, 2013, 03:15 PM
Rain4LA's Avatar
Joined Nov 2012
It slowly pushes forward and slightly left.
Old Feb 05, 2013, 03:20 PM
Controls Engineer
lasakro's Avatar
Joined Dec 2012
Mine does that when I add sub-trim. That's where we need to figure out why. Does it stop tilting or start to bind?
Old Feb 05, 2013, 03:23 PM
Rain4LA's Avatar
Joined Nov 2012
No, If I don't stop it - it just slams into the ground. I was watching some other dude on YouTube with the same problem on his 130X and he was using a Spektrum. I called HH, but he wanted to get into the whole "settings" conversation and I can't. I'm not running a Spektrum - and if they knew that, they wouldn't help me, Plus all those "non-Eflight" mods.
Old Feb 05, 2013, 03:24 PM
indoorheli's Avatar
Joined Sep 2007
[IMG][/IMG]
[IMG][/IMG]
Tail rod, disconnect it and mover your tail slider around to check and see if you feel any binding. Move those grips around and see if it is nice and no noticeable notches as you turn it. Make sure when you do this you disconnect the grips from the slider and do them one by one or you can miss an issue.
On the DFC head, can you move it much with your hands via the dampers? DFC needs a very tight, low slop head
Old Feb 05, 2013, 03:25 PM
if pigs could fly!
RyoOhki1701's Avatar
France, IdF, Paris
Joined Feb 2013
Interesting developments Couldn't do a vid of my own bird, but here's a link describing the exact same issue.
Blade 130X How to subtrim a bad mainboard that doesn't zero pitch/roll/yaw rates at center sticks (6 min 42 sec)
watch at 1:55 how the swashplate on 130X #2 moves on its own.
Also a very long description explaining how AS3X doesn't work as, say, a BeastX would, and why subtrim might not have so much ill effect. Can't say whether this is spot on or wishful thinking of course.
We'll see how it goes when I have the chance to hit the field again.
RyoOhki1701 is offline Find More Posts by RyoOhki1701
Old Feb 05, 2013, 03:37 PM
Rain4LA's Avatar
Joined Nov 2012
I really appreciate all the help guys.. I've gotta jump off this board and get some other s*%@ done!
For Sale New in the box E-Flite Taylorcraft ARF Kit plus High Performance E-Flite components Philscho Aircraft - Electric - Airplanes (FS/W) 4 Aug 19, 2012 12:25 AM
For Sale E-Flite 300 32e SHP ****SOLD*** E-Flite still aviable tomtheman Aircraft - Electric - Airplanes (FS/W) 2 Mar 28, 2012 08:01 PM
Sold E-flite 60A ESC w/ E-flite Brushless 1010kV Motor joshfneptune Aircraft - Electric - Power Systems (FS/W) 3 Mar 05, 2012 08:18 PM
Discussion E-Flite Taylorcraft 450 ARF Kit and High Power E-Flite electrical components $300 Philscho Hot Online Deals 1 Mar 02, 2012 08:11 PM
Discussion E-Flite Su-26 and E-flite Extra 260 repair Joe Slow Crash Discussion 1 Sep 27, 2011 11:50 AM
