Old Jan 30, 2013, 10:14 AM
indoorheli is offline
Find More Posts by indoorheli
2 seconds from crashing
indoorheli's Avatar
United States, WA, Seattle
Joined Sep 2007
Yes you can
indoorheli is offline Find More Posts by indoorheli
Old Jan 30, 2013, 10:19 AM
garryk is online now
Find More Posts by garryk
Corsair Captain
United States, AZ, Mesa
Joined Oct 2010
What size pinion would you recommend?
Garry K.
garryk is online now Find More Posts by garryk
Old Jan 30, 2013, 10:30 AM
iTz Nicholas72 is offline
Find More Posts by iTz Nicholas72
Joined Nov 2010
Originally Posted by Dejavu*Xion View Post
They put out some decent batteries. I know a dude who runs them in his 500 and likes them alot.
Went ahead and ordered two along with a paraboard from EPBuddy.
iTz Nicholas72 is offline Find More Posts by iTz Nicholas72
Old Jan 30, 2013, 11:16 AM
indoorheli's Avatar
Joined Sep 2007
Garry K.
If it is like the hp08s a 10t is good
Old Jan 30, 2013, 05:37 PM
imagine 50 is offline
Find More Posts by imagine 50
Joined Jan 2011
Originally Posted by imagine 50 View Post
descricion in the video....motor.esc.battery,,etc
imagine 50 is offline Find More Posts by imagine 50
Old Jan 30, 2013, 05:46 PM
cstoutr is offline
Find More Posts by cstoutr
United States, LA, Calhoun
Joined May 2012
Imagine50
There's no description in the video.
cstoutr is offline Find More Posts by cstoutr
Old Jan 30, 2013, 06:44 PM
indoorheli's Avatar
Joined Sep 2007
spin 8000, pinion 10t.....80% motor......battery gens ace 2s 450mha 25-50c....ESC stock
Old Jan 30, 2013, 08:49 PM
cstoutr is offline
Joined May 2012
Ok
Which is better all around, spin8000, HP08, or HP10?
Old Jan 30, 2013, 09:26 PM
Joined Nov 2010
Description:
Description:
Old Jan 31, 2013, 01:28 PM
lasakro is offline
Find More Posts by lasakro
Seeking Control
lasakro's Avatar
United States, NY, Amsterdam
Joined Dec 2012
Originally Posted by iTz Nicholas72 View Post
lasakro is offline Find More Posts by lasakro
Old Jan 31, 2013, 01:33 PM
harryhenderson - crvnation is offline
Find More Posts by harryhenderson - crvnation
Joined Dec 2012
Wow, that looks like a HARD hit to the front of the frame. Hope your control board is okay.
harryhenderson - crvnation is offline Find More Posts by harryhenderson - crvnation
Reply With Quote  (Disabled)
Old Jan 31, 2013, 06:18 PM
Joined Nov 2010
Full negative pitch into asphalt from almost 30ft up. What happens when you try a new move while talking to someone.
Old Feb 01, 2013, 01:11 AM
Corsair Captain
Joined Oct 2010
I just ordered an 8800kv motor with a 10t pinion. Hope this is a good match. May have to lower the throttle curve a bit huh?
Garry K.
Old Feb 01, 2013, 01:43 AM
lasakro is offline
Seeking Control
lasakro's Avatar
Joined Dec 2012
Garry K.
I just upgraded my V120D02S to a 2S with CC10 and HP08S 8000KV. With the 10 tooth I measure 5450 RPM. I still need to setup the Governor but got board with that project for now. My 130X arrived yesterday. So that's holding my interest for now. Well built solid heli compaired to WK. Spyro prepared me for it's arrival. I've got the silicone o rings installed and spent time with the scotch tape. Tail vib is still present but now is gone above 25% throttle. Better than it was. Still watching video's on the topic. I swapped to WK tail flange bearings, no change. Metal A gear is in and c gear well seated. The tail being plastic didn't last long. Landed hard on carpet and cracked it. Had 45+ MPH winds today and this guy likes to run in a small living room. For now I have a V120 CF tail installed. The tail box also isn't to resuliant for holding a fin on, in plastic, with a machine screw. Have a Micoheli box coming with a CF fin. Expect it will be a better mount with the aluminum treads instead of plastic.
While you are in programming mode is there any feed back with the LED's to let you know where your'e at with your aileron stick movements? Doesn't look so. I've got a tail twitch I'm working on but already at -6 or so. May need to go after A/E gain next because it's starting to look like a body twitch.
Bob
Old Feb 01, 2013, 07:48 AM
Joined Dec 2012
Bob
Yes. Red is elevator, Green is aileron and Blue is rudder. When the lights are solid, you are at "center" or the zero position. You cycle through the channels with up/down elevator and right aileron raises the gain while left aileron lowers it. You can go 10 points up (gain higher) or down (gain lower) from there. Each time you move the stick to go up a point, the light for that respective channel starts blinking faster and vice versa for when you move the stick down a point. It's kind of difficult/imprecise judge how many points you are from center solely by looking at the flashing lights, so I just count the steps up or down. If you get lost, bump the stick back to center until you get a solid light and start over. All three channels work exactly the same way.
For Sale New in the box E-Flite Taylorcraft ARF Kit plus High Performance E-Flite components Philscho Aircraft - Electric - Airplanes (FS/W) 4 Aug 19, 2012 12:25 AM
For Sale E-Flite 300 32e SHP ****SOLD*** E-Flite still aviable tomtheman Aircraft - Electric - Airplanes (FS/W) 2 Mar 28, 2012 08:01 PM
Sold E-flite 60A ESC w/ E-flite Brushless 1010kV Motor joshfneptune Aircraft - Electric - Power Systems (FS/W) 3 Mar 05, 2012 08:18 PM
Discussion E-Flite Taylorcraft 450 ARF Kit and High Power E-Flite electrical components $300 Philscho Hot Online Deals 1 Mar 02, 2012 08:11 PM
Discussion E-Flite Su-26 and E-flite Extra 260 repair Joe Slow Crash Discussion 1 Sep 27, 2011 11:50 AM
