Old Jan 28, 2013, 08:45 PM
dsobbe is online now
Find More Posts by dsobbe
United States, IL, Chicago
Joined Jan 2011
Originally Posted by tracknoob View Post
So, I headed to LHS hoping they might have orange (I would have bought any color that was bright, including white) but all they had was a set of stock black ones. Of course, I took 'em, but still will eventually go with something else.
I've both sprayed and brushed black skids with Rust-O-leum yellow. Both stick incredibly well. The only down side is the 24 hour drying time. Rit dye is easier and faster on white parts, though.
dsobbe is online now Find More Posts by dsobbe
Old Jan 29, 2013, 05:19 AM
vmmattil is offline
Find More Posts by vmmattil
vmmattil's Avatar
Finland, Uusimaa, Helsinki
Joined Nov 2011
As a crash result I installed lynx tail case, tail grips, tail blades and a metal A gear. As a result spoolup is nice with no vibration but in higher speeds the heli vibrates aggressively from the tail. What should I try next, lowering the gain?
vmmattil is offline Find More Posts by vmmattil
Old Jan 29, 2013, 05:24 AM
lasakro is offline
Find More Posts by lasakro
Seeking Control
lasakro's Avatar
United States, NY, Amsterdam
Joined Dec 2012
Hi guys. First time here. I've got a 130X due on Wednesday. This is the first battery I'll have that uses the balance connector to power the heli. Is the link below the best option to charge these with UMX style connectors and a Hitec X4 AC? I've been using XH adapters. With only two balance lines coming from the charger how does it properly balance voltage on 6 batteries in parallel with inconsistent voltages between cells? Seems kind of a hack to me at first glance.
http://helidirect.com/micro-parallel...er-p-28400.hdx
lasakro is offline Find More Posts by lasakro
Old Jan 29, 2013, 05:29 AM
lasakro is offline
Seeking Control
lasakro's Avatar
Joined Dec 2012
Did you balance the tail blades? Is the tail driven shaft straight? Did you inspect the tail boom for cracks? Sometimes they are easy to miss.
Old Jan 29, 2013, 07:34 AM
turboparker is online now
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Voltage is always identical on all parallel branch circuits, therefore all cells connected in parallel will simply self-balance. The charger sees the parallel UMX packs as a single large 2s pack. However, you should not mix nearly empty & nearly full packs, nor should you mix healthy packs with old, tired, saggy packs.
Joel
turboparker is online now Find More Posts by turboparker
Old Jan 29, 2013, 08:23 AM
garryk is online now
Find More Posts by garryk
Corsair Captain
United States, AZ, Mesa
Joined Oct 2010
Thinking of dipping my blades and skids in this.
http://www.amazon.com/Generation-SUP...he+dark+paints
Garry K.
garryk is online now Find More Posts by garryk
Old Jan 29, 2013, 10:02 AM
erkq is online now
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
Garry K.
The reviews are disappointing.
erkq is online now Find More Posts by erkq
Old Jan 29, 2013, 11:15 AM
RUDDERLESS is offline
Find More Posts by RUDDERLESS
Joined Oct 2009
Confused...again
Could somebody explain to me why my C gear keeps coming off?
I have it appart and the gear feels snug on the TT, and don't see any other issues.
Thanks, RUD
RUDDERLESS is offline Find More Posts by RUDDERLESS
Old Jan 29, 2013, 11:29 AM
harryhenderson - crvnation is offline
Find More Posts by harryhenderson - crvnation
Joined Dec 2012
Thanks, RUD
You can CA the gear to the TT. Just be sure it spins true before the CA sets. A better "fix" is to ensure the TT is seated fully into the B gear. You might need to grind down your boom a few mm's to allow the TT to seat further into the B gear. What happens is, if the TT isn't seated fully into the B gear, the TT can move forward and disengage itself from the C gear, especially if it isn't CA'd on. When that happens in flight, obviously, the C gear gets flung into outer space never to be seen again and you lose tail control = throttle hold/crash. I set my mesh by fully inserting the tail boom into the frame and TT fully into the B gear and then back it out just a *touch* to prevent any drive train binding. I also CA the C gear for good measure. Works every time for a nice, smooth and reliable tail.
harryhenderson - crvnation is offline Find More Posts by harryhenderson - crvnation
Reply With Quote  (Disabled)
Old Jan 29, 2013, 11:33 AM
jlk69 is offline
Find More Posts by jlk69
RC Aircraft Junkie
jlk69's Avatar
USA, CA, Chula Vista
Joined Sep 2004
What is the best place to buy a 130x from?
jlk69 is offline Find More Posts by jlk69
Old Jan 29, 2013, 11:37 AM
indoorheli is offline
Find More Posts by indoorheli
2 seconds from crashing
indoorheli's Avatar
United States, WA, Seattle
Joined Sep 2007
me
I think ultimatehobbies and wholesaletrains have the best deals on new ones
indoorheli is offline Find More Posts by indoorheli
Old Jan 29, 2013, 11:39 AM
Joined Dec 2012
Right now, it looks like Horizon. They just dropped the price thirty bucks to $249 and have some "bonus buy" deal going where they throw in two spare batteries, the metal A gear (a must), and a spare set of blades. Although some Horizon rep said there wasn't a V2 coming out, I'd wait a bit, if I were you. It's awfully suspicious with that price drop and the extras. They're wanting to move old 130X stock for some reason and Horizon virtually never drops the price on helis that are current and not discontinued.
Joined Dec 2012
Originally Posted by indoorheli View Post
me
Do they have the bonus buy deal with the extras? If so, how much? Those extras are about $60 alone. Good deal.
Old Jan 29, 2013, 11:45 AM
indoorheli's Avatar
Joined Sep 2007
Not sure I haven't looked in a while, but those two places are known for good deals. Wholesale you have to be a current member to see the lowest price
The stock batteries on the HH deal I dont care for (and always overpriced), but the metal A gear would be nice
Old Jan 29, 2013, 11:56 AM
lasakro is offline
Seeking Control
lasakro's Avatar
Joined Dec 2012
Horizon also has free shipping along with the free items. With a heli like this one and all the happy owners why wait for a possible V2, IMO.
For Sale New in the box E-Flite Taylorcraft ARF Kit plus High Performance E-Flite components Philscho Aircraft - Electric - Airplanes (FS/W) 4 Aug 19, 2012 12:25 AM
For Sale E-Flite 300 32e SHP ****SOLD*** E-Flite still aviable tomtheman Aircraft - Electric - Airplanes (FS/W) 2 Mar 28, 2012 08:01 PM
Sold E-flite 60A ESC w/ E-flite Brushless 1010kV Motor joshfneptune Aircraft - Electric - Power Systems (FS/W) 3 Mar 05, 2012 08:18 PM
Discussion E-Flite Taylorcraft 450 ARF Kit and High Power E-Flite electrical components $300 Philscho Hot Online Deals 1 Mar 02, 2012 08:11 PM
Discussion E-Flite Su-26 and E-flite Extra 260 repair Joe Slow Crash Discussion 1 Sep 27, 2011 11:50 AM
