Joel |
Latest blog entry: Eflite UMX Sbach 3D on 3s - 2300Kv/5043...
Joined Dec 2012
What's this I keep hearing about not running it at more than 75% throttle with the wood blades? Are they really that bad that the thing is going to blow up in flight or something at 100% throttle with the blades that come with it? There was no warning like this with the 4503D and its stock wooden blades. I never had any trouble with a flat 100% idle-up curve, either.
Iowa
Joined Nov 2009
I fly both the stock battery, as well as, NanoTechs in my 300x. I don't notice any difference in performance between the two types in this heli, I just like the price of the NanoTechs.
Where are you finding the new main shaft for the 300x? I couldn't find one with a new part number. I ordered a set of main shafts recently, and the bolts are threaded the entire length. |
Iowa
Joined Nov 2009
You can replace the grommets on the swash with canopy grommets, if you notice the heli shakes in FFF. Plug in the battery, place the heli on a flat surface, and give it five seconds to calibrate the gyros. You should hear a second set of beeps once the calibration is complete. |
it could be better before your first flight you have to replace the B gear to a reliable metal bevel gear, loosen the screws where the boom attached as wellas the support and push forward the tailboom until it stop and check the D gears and if torque shaft never touch tail shaft you are good to go.
Got a new issue with my tail now! Check out this video. Any ideas? It seems to get into some sort of death wobble sort-of thing after giving hard collective. The tail shift, tail gears, and grips are brand new. Maybe a bent torque tube??
United States, CA
Joined Jan 2012
The bolt isn't tight in the hole on mine with the supposed new shaft and bolt either. I measured the old and new bolt with a caliper and the new bolt appears to be about one thousandth of an inch larger. I don't have any way to measure the holes in the shafts Jim. |
United States, CA
Joined Jan 2012
United States, CA
Joined Jan 2012
Joined Dec 2012
Another thing I was curious about was as to whether or not the tail parts (case, grips, etc) are the same as the 4503D/X. |
United States, CA
Joined Jan 2012
| Thread Tools | |
| For Sale New in the box E-Flite Taylorcraft ARF Kit plus High Performance E-Flite components | Philscho | Aircraft - Electric - Airplanes (FS/W) | 4 | Aug 19, 2012 12:25 AM |
| For Sale E-Flite 300 32e SHP ****SOLD*** E-Flite still aviable | tomtheman | Aircraft - Electric - Airplanes (FS/W) | 2 | Mar 28, 2012 08:01 PM |
| Sold E-flite 60A ESC w/ E-flite Brushless 1010kV Motor | joshfneptune | Aircraft - Electric - Power Systems (FS/W) | 3 | Mar 05, 2012 08:18 PM |
| Discussion E-Flite Taylorcraft 450 ARF Kit and High Power E-Flite electrical components $300 | Philscho | Hot Online Deals | 1 | Mar 02, 2012 08:11 PM |
| Discussion E-Flite Su-26 and E-flite Extra 260 repair | Joe Slow | Crash Discussion | 1 | Sep 27, 2011 11:50 AM |
