Old Nov 21, 2012, 02:12 AM
erkq is offline
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
Originally Posted by KevinBuckley70 View Post
It's probably worth pointing out that I always fly with my finger resting on the TH switch and 99% of the time TH is engaged by the time it hits anything.
+1000! Absolutely required for damage-free crashing! My buddies can't believe how quick I am on that switch.
erkq is offline Find More Posts by erkq
Old Nov 21, 2012, 07:58 PM
RUDDERLESS is offline
Find More Posts by RUDDERLESS
Joined Oct 2009
Picked up a 130x to-day
Checked for "vibration(s)...had the infamous "resonance" at lower throttle, but very smooth above that point, so I guess I have a square tail rotor shaft.
I will be dynamically balancing the tail rotor though.
The clearance between the torque tube gear and FET was tight enough to have a piece of printer paper indexed through when turning the main gear, so I sanded down the gear and appears to be enough clearance now.
Bought a TEAM GREAT HOBBIES 360 MA battery to try, weights 2 grams LESS than the stock battery.
Have a question, I keep hearing about using "throttle hold" to protect parts when going to crash, how does this differ from just dropping the throttle stick to zero?
The manual says the select "inhibit" for the gyro for a DX6i, but I don't see that on my DX6i ?
My previous choppers have been a PICO Z and a 120sr, so I will probably be bugging everybody here for suggestions.
Thanks, RUD
RUDDERLESS is offline Find More Posts by RUDDERLESS
Old Nov 21, 2012, 08:03 PM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
On a CP heli you usually fly in "idle up" so pulling the stick back goes to full negative pitch and full power. Not a good way to crash.
Even if you are not flying in idle up for some reason it is still good to learn to pull throttle hold instead of pulling the stick back. One less thing to unlearn later.
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
erkq is offline
Joined Dec 2010
When in idle up stunt mode there is NO stick positipn at which tje motor is off.
Stupid phone keyboard...
Old Nov 21, 2012, 10:06 PM
Spyro37 is offline
Find More Posts by Spyro37
WIFE HAND LAUNCHED MY PLANES!
Spyro37's Avatar
Joined Jun 2009
Thanks, RUD
Whether you are flying normal or stunt mode, it's still a good habbit that you hit TH before the crash.
If you have a small degree of negative pitch on your normal flight mode below mid-stick, If you pull the throttle stick down before the crash, the heli will gain downward momentum (unless it's inverted) towards the ground.
You could practice TH flying very low altitude over a thick grass, imagine that crash is about to happen.
Gyro is actually inhibitted, & you don't have to do anyting.
You have to go to HH website, follow the procedure to adjust gyro gain (if you are having issues with it). Supposedly, it's pre-adjusted @ the factory.
Most CP helis (larger), gyro gain setting is adjusted using the Tx (& seen on the screen).
Spyro37 is offline Find More Posts by Spyro37
Old Nov 22, 2012, 02:08 AM
KevinBuckley70 is offline
Find More Posts by KevinBuckley70
KevinBuckley70's Avatar
Oxfordshire, UK
Joined Jul 2001
Deleted due to erroneous multiple post.
KevinBuckley70 is offline Find More Posts by KevinBuckley70
Old Nov 22, 2012, 02:13 AM
Oxfordshire, UK
Joined Jul 2001
Throttle Hold simply cuts the power to the motor without changing any of the control surfaces. So it stops putting more energy into the the system and stops the gears getting stripped when it hits. If you fly with your finger resting on that switch, I think it's quicker than pulling the throttle/pitch lever down anyway. And as others have mentioned, when you start to fly in one of the 'idle-up' modes, pulling the pitch lever down won't stop the motor - it will just accelerate the heli. in whatever direction 'down' happens to be.
Old Nov 22, 2012, 10:49 AM
sgoodmeyer is offline
Find More Posts by sgoodmeyer
Joined Nov 2012
Just saw over on HF that the 130 X is now out for the Phoenix sim.
sgoodmeyer is offline Find More Posts by sgoodmeyer
Reply With Quote  (Disabled)
Old Nov 22, 2012, 01:52 PM
egaus is offline
Find More Posts by egaus
Quadrophenia
egaus's Avatar
Seattle
Joined Mar 2009
Just had my first two flights on new 130x, stock - no mods. Only sanded the A gear lightly. I did not notice any unwanted behaviors, smooth upright flying in normal mode only. Next flight try switching into idle up. I'm happy so far, though that gear is pretty close to the elev servo, stupid IMO.
e
egaus is offline Find More Posts by egaus
Old Nov 22, 2012, 04:22 PM
Joined Oct 2009
Many thanks to EVERBODY who responded to my post.
As I mentioned, I will be asking for more help,..be patient
After doing some research, I think that learning to fly this thing should be in STUNT MODE right off the bat, with throttle at %80, instead of %100 per the manual ??
Question, not that I will flying upside down anytime soon but, in trying to understand what's going on here, I don't see any neg, pitch in the manuals DX6i pitch curve settings ?
ALL opinions welcomed !!
RUD
Old Nov 22, 2012, 04:42 PM
egaus is offline
Quadrophenia
egaus's Avatar
Seattle
Joined Mar 2009
0 is most negative, 50 is centered and 100 is most positive pitch.
Evidenced by powering up, switch on throttle hold and put the heli in idle up (stunt mode). You will see the blades' pitch change from 0 to 100 as you move the throttle up. Center the stick, you are right around 50. Negative pitch is not necessarily a negative number in the radio.
Wow. Did some more flights and this time noticed the awful resonance on the tail at lower throttle. Best to power up quick to center stick and avoid that mess. Is this an issue people are worried about solving or just ignore and move stick up fast to avoid?
e
Old Nov 22, 2012, 04:46 PM
erkq is offline
Joined Dec 2010
e
You haven't been around long, have you? Much discussion about this with all sorts of fixes, including upgraded bearings, sliders, tail boxes, balancing, etc.
Old Nov 22, 2012, 04:50 PM
indoorheli is offline
Find More Posts by indoorheli
2 seconds from crashing
indoorheli's Avatar
United States, WA, Seattle
Joined Sep 2007
If it just has tail fin vibration at low throttle and not any other time I think there is no need to do anything and just throttle past it.
If it has vibration during flight then you might want to think about balancing the blades, looking over the torque tube, gears, tail box or bearings.
indoorheli is offline Find More Posts by indoorheli
Old Nov 22, 2012, 04:58 PM
egaus is offline
Quadrophenia
egaus's Avatar
Seattle
Joined Mar 2009
I just got my 130x the other day, been doing some reading, not sure if people were trying to fix that specific problem as it really isn't a problem since I won't be flying the heli at low throttle. Kinda dumb for HH to let that issue go to production. Their fix is in the manual I guess, quickly move throttle to 50%.
e
Old Nov 22, 2012, 08:01 PM
Spyro37 is offline
Spyro37's Avatar
Joined Jun 2009
Originally Posted by rudderless View Post
many thanks to everbody who responded to my post.
As i mentioned, i will be asking for more help,..be patient
after doing some research, i think that learning to fly this thing should be in stunt mode right off the bat, with throttle at %80, instead of %100 per the manual ??
NO. If you have never flown CP before, just fly it at normal mode on you first few flights, it's just like flying FP. When you feel that you have good control, click that switch to stunt mode for few seconds, and decide if you feel comfortable with it.
This heli will fly even on normal mode. You might cause some damage/injury if your thumb is not quick enough (TH) if you jump to stunt mode immediately.
question, not that i will flying upside down anytime soon but, in trying to understand what's going on here, i don't see any neg, pitch in the manuals dx6i pitch curve settings ?
if you follow the manual & setting for the dx6i, you should be ok, and could do more adjustments to your liking later on. The provided setting should be good as a starting point. Both normal & stunt flight mode settings. So you shouldn't worry about the "negative pitch". May not be a perfect world but it should be close enough.
all opinions welcomed !!
Rud
- spyro
For Sale New in the box E-Flite Taylorcraft ARF Kit plus High Performance E-Flite components Philscho Aircraft - Electric - Airplanes (FS/W) 4 Aug 19, 2012 12:25 AM
For Sale E-Flite 300 32e SHP ****SOLD*** E-Flite still aviable tomtheman Aircraft - Electric - Airplanes (FS/W) 2 Mar 28, 2012 08:01 PM
Sold E-flite 60A ESC w/ E-flite Brushless 1010kV Motor joshfneptune Aircraft - Electric - Power Systems (FS/W) 3 Mar 05, 2012 08:18 PM
Discussion E-Flite Taylorcraft 450 ARF Kit and High Power E-Flite electrical components $300 Philscho Hot Online Deals 1 Mar 02, 2012 08:11 PM
Discussion E-Flite Su-26 and E-flite Extra 260 repair Joe Slow Crash Discussion 1 Sep 27, 2011 11:50 AM
