If you really like that shell buy a cheaper clone and then buy the shell and save yourself a $100 or more. Is something wrong with your 450 as it should be leaps and bounds more powerful than your 130x. |
A cheaper clone is a huge no-no in my book. |
West Monroe NY
Joined Feb 2009
so where is everyone getting batteries for their 130x, I just picked up some 350 mah nano paks from the HK USA warehouse http://www.hobbyking.com/hobbyking/s...dProduct=28644
what are you guys using?
Just got mine
Tail Blow Out Fixed
After setting the 130 aside for a week or so, I tackled it again this morning. It turns out that I had two problems, one masking the other. The first problem was the "C" gear slipping on the shaft. I replaced it and put some thread between the gear hole and shaft, but the problem still remained, the tail blew out during fast changes in pitch/throttle.
I had noticed that the tail was vibrating a little more than when it was in new (uncrashed) condition. I replaced the tail shaft (looks like a T-Pin) in the hopes that maybe the shaft was bent, causing vibration which was confusing the gyro. While reassembling the tail, I noticed that the pin on the pitch slider was broken off, plus I had installed the pitch slider upside down, with the broken pin at the bottom and the ball at the top. Embarassing heli moment # 2,136 for me Especially since I was ranting to all who would listen about BnF crap and Blade and Horizon and just about anything else I could think of. D'oh!!!Replaced the slider, installed correctly this time and just test flew, she's rock solid. Thanks to everyone who replied in an effort to help the partially retarded heli guy.... Simon |
TP's 65c packs are designed for 12c charging with no reduction in performance or lifespan, and TP claims 600 cycles before they fade away. The Hyp packs are designed for 5c charging with no reduction in performance or lifespan, and Hyp packs are typically good for around 300-cycles or so before they fade away. The 300 cycle lifespan of Hyperion's G3 LiPos is common knowledge. However, the TP's G6 65c packs have only been available for a couple years, so it's a bit early to tell if they will last for 600 cycles, as TP claims. I have 8 TP 325 UMX packs from RCBabbel, along with 3 TP 2250 65c 3s, 3 TP 1800 65c 2s, and 3 TP 1300 65c 2s packs. I charge all of them at 10-12c. None of them show any signs of getting old, and some of them are nearing the 300-cycle mark. Given the above, TP's 600-cycle claim does not seem unreasonable. The unbeaten performance & the amount of time saved by charging at 12c is enough to make the TP packs a real bargain. Add the 600-cycle lifespan, and the choice becomes a no-brainer. ![]() Joel |
Latest blog entry: Eflite UMX Sbach 3D on 3s - 2300Kv/5043...
Joined Apr 2008
Setting aside the vibration issue, the answer is yes. The problems you will encountered are: (1) having to made a mounting bracket, and (2) solder the wires.
The ds35 is a plug-n-play. I have it in both of my 130xs, on 2s and 3s using CC esc to govern the headspeed. |
| Thread Tools | |
| For Sale New in the box E-Flite Taylorcraft ARF Kit plus High Performance E-Flite components | Philscho | Aircraft - Electric - Airplanes (FS/W) | 4 | Aug 19, 2012 12:25 AM |
| For Sale E-Flite 300 32e SHP ****SOLD*** E-Flite still aviable | tomtheman | Aircraft - Electric - Airplanes (FS/W) | 2 | Mar 28, 2012 08:01 PM |
| Sold E-flite 60A ESC w/ E-flite Brushless 1010kV Motor | joshfneptune | Aircraft - Electric - Power Systems (FS/W) | 3 | Mar 05, 2012 08:18 PM |
| Discussion E-Flite Taylorcraft 450 ARF Kit and High Power E-Flite electrical components $300 | Philscho | Hot Online Deals | 1 | Mar 02, 2012 08:11 PM |
| Discussion E-Flite Su-26 and E-flite Extra 260 repair | Joe Slow | Crash Discussion | 1 | Sep 27, 2011 11:50 AM |
