Old Nov 13, 2012, 11:31 AM
Spyro37 is offline
Find More Posts by Spyro37
WIFE HAND LAUNCHED MY PLANES!
Spyro37's Avatar
Joined Jun 2009
Originally Posted by Santley View Post
Kevin my problem was the tail blade hitting the grass and stripping the C gear.
If your tail blades is hitting the grass, you really shouldn't do it on the grass. Use a helipad like recommended, otherwise there is a great risk stripping gears.
Compared to other micros I have, this one actually has got the most tail blade ground clearance. Big styro insulation foam from homedepot will cost you $2 than taking chances.
Spyro37 is offline Find More Posts by Spyro37
Old Nov 13, 2012, 11:36 AM
crvnation is offline
Find More Posts by crvnation
Joined Sep 2012
Not sure about that foam, but you do have to be sure that whatever you use is not so light that it will blow away and/or up into the rotors (i.e. carpet).
crvnation is offline Find More Posts by crvnation
Reply With Quote  (Disabled)
Old Nov 13, 2012, 02:25 PM
J_skaggs is offline
Find More Posts by J_skaggs
United States, CA
Joined Jan 2012
Originally Posted by crvnation View Post
What about a Blade 300 X?
I have the 450x and 300X. I like the 300X better. It just feels more precise and quicker responding to me and it is only slightly smaller than a 450X. I also have the 130X and like it as much as the 300X. The 450X is my least favorite of the three and sits on the shelf most of the time. Had the 300X come out before the 450X, I would not have bought the 450X.
J_skaggs is offline Find More Posts by J_skaggs
Old Nov 13, 2012, 02:38 PM
Joined Sep 2012
I have a 450 3D (flybar) and 130X. The 450 3D sits most of the time because I can't fly it at my house. I love the 130X, but I want something a bit bigger because I love how the 450 3D flies, but want FBL. I'm looking hard at the 300X, but there seems to be problems with frame flexing, mainshaft breaking from basic non-3D type flying.
How hard do you fly your 300X? How are your flight times on the 300X as compared to your 450X?
Old Nov 13, 2012, 02:53 PM
Petrie is offline
Find More Posts by Petrie
United States, AR, Lockesburg
Joined Feb 2012
I have a 450 3D (flybar) and 130X. The 450 3D sits most of the time because I can't fly it at my house. I love the 130X, but I want something a bit bigger because I love how the 450 3D flies, but want FBL. I'm looking hard at the 300X, but there seems to be problems with frame flexing, mainshaft breaking from basic no?
How about the 450 3D for parts cost and repair. I also am tkinking somthing bigger. I have a lot of room to fly so that is not a problem.
Petrie is offline Find More Posts by Petrie
Old Nov 13, 2012, 02:56 PM
Joined Sep 2012
I'd get the 450X, if I were you. Lower parts count and easier to repair. It's also FBL, if that's your thing. I didn't think I would like it, but I'm all about the FBL now.
Old Nov 13, 2012, 03:24 PM
KevinBuckley70 is offline
Find More Posts by KevinBuckley70
KevinBuckley70's Avatar
Oxfordshire, UK
Joined Jul 2001
FWIW, my experience of bumping the 450x into things is that it will:
  • Bend the feathering spindle (which is different to the 450 3d one)
  • Strip the main gear
  • Strip the plastic gears in the cyclic servos (so get some metal geared equivalents)
There is a thread dedicated to the 450 here: http://www.rcgroups.com/forums/showt...525691&page=26
KevinBuckley70 is offline Find More Posts by KevinBuckley70
Old Nov 13, 2012, 03:33 PM
J_skaggs is offline
United States, CA
Joined Jan 2012
To this list you can add rotor blades $40 and main shaft.
Old Nov 13, 2012, 03:39 PM
Joined Sep 2012
That's why I said to consider MONEY in the decision.
Old Nov 13, 2012, 03:41 PM
J_skaggs is offline
United States, CA
Joined Jan 2012
I'm into FFF and sport flying. No 3D. I am nearing 75 flights on it without incident. The main shaft has been upgraded. They changed the bolt and drilled the hole in the shaft more precise. My LHS pointed that out to me so I bought one and installed it on mine. I safely get about four minutes flight time on both with my style of flying.. I haven't tried to exceed that.
Old Nov 14, 2012, 08:12 AM
Petrie is offline
Joined Feb 2012
Opened the 130X box last night and flew. After the Nano this thing is great! I’ll sell the 130X after they pry my cold dead thumbs off the transmitter. However, I should have broke it down and balanced the tail. The gear mesh looked OK but it had some loud vibes from the tail and took out the “c” gear after only one battery. I’m not complaining though that all can be worked out.
Old Nov 14, 2012, 10:18 AM
Joined Sep 2012
Cool. If one were to order a 300 X right now, how would they know if the main shaft has been "upgraded"? Anything specific to look for?
Old Nov 14, 2012, 08:32 PM
J_skaggs is offline
United States, CA
Joined Jan 2012
Remove the lower bolt from the main shaft. If it is threaded all the way, it is the the first version. The new version is only threaded on the end.
Old Nov 14, 2012, 08:35 PM
Joined Sep 2012
So, a shouldered bolt is the "upgrade"? They should have had that all along. But, it was the mainshafts that were breaking. What's the visual difference (if any) between the original and "upgraded" shaft?
Old Nov 14, 2012, 09:12 PM
J_skaggs is offline
United States, CA
Joined Jan 2012
I was told the hole was more precisely drilled and the bolt is a little tighter fitting. My LHS owner told me that HH informed him. Actually, if he hadn't told me, I would never have changed the shaft. Even though I knew of the main shaft problem I wasn't't worried about it.
For Sale New in the box E-Flite Taylorcraft ARF Kit plus High Performance E-Flite components Philscho Aircraft - Electric - Airplanes (FS/W) 4 Aug 19, 2012 12:25 AM
For Sale E-Flite 300 32e SHP ****SOLD*** E-Flite still aviable tomtheman Aircraft - Electric - Airplanes (FS/W) 2 Mar 28, 2012 08:01 PM
Sold E-flite 60A ESC w/ E-flite Brushless 1010kV Motor joshfneptune Aircraft - Electric - Power Systems (FS/W) 3 Mar 05, 2012 08:18 PM
Discussion E-Flite Taylorcraft 450 ARF Kit and High Power E-Flite electrical components $300 Philscho Hot Online Deals 1 Mar 02, 2012 08:11 PM
Discussion E-Flite Su-26 and E-flite Extra 260 repair Joe Slow Crash Discussion 1 Sep 27, 2011 11:50 AM
