Joined Sep 2012
http://www.rcgroups.com/forums/showp...postcount=4956
And, please show us exactly where it says that in the manual because I just perused the on-line .pdf at Horizon and didn't see a single thing about that, nor do I recall anything even closely related when I read my physical manual long ago. |
A Horizion employee posted on HF that it was normal for the tail to viberate during spool up and just go ahead a spool up fast and it would be fine.
The same or perhaps anothe HH employee posted that they were aware of the out of square tail shafts and were taking measures to correct this but it did not really present any problems. I guess if it flys then all is A OK. I shimed the tail shaft on my 130X and it flys great. My son purchased one and both of us worked on it off and on for two weeks. Tried a new 3 n 1, new servos, Bocan flanged bearings, shimed the tail, balanced tail blades etc. It would fly fine for one or two flights thren throw another fit. Tail would hold then kick out 90 to 180 and then sometime hold great and sometimes wag. Run tail gains up and it would sometimes get better and sometimes get worse. He got tired of fighting it and traded it for a Trex 450. Charles |
Orlando, Fl
I think the 'resonance is ok' message, was from this post, which appeared over on HF.
Personally my 130x resonates, but if you amend you throttle curve it goes away, dont use the curve for normal in the instruction manual, make it steeper. Here is the message as was posted. ################### ###### Hi Guys, Here are some tips we have. Roll on take-off. Flybarless systems do not like it when the helicopter is light on the skids. As soon as the blades start spinning the pilot needs to start flying it. When taking off the 130 X, increase the throttle, once the blades are spinning rapidly increase the throttle to pop it off the ground. Letting the helicopter spool up slowly can cause vibration which will cause an unwanted roll. It is also recommended to take the helicopter off of a smooth surface such as concrete. The helicopter being so light can get stuck in the grass very easily. Tail Resonance. Upon spool up, the helicopters will experience a vibration in the tail assembly, but only during spool up. The tail is hitting a resonant frequency at a certain head speed; this is not a problem, it’s just something the 130 X does. The key is to quickly move through this head speed range. To avoid this issue, advance the throttle from low throttle to about 75% throttle immediately. The goal is to pop the helicopter off the ground as quickly as possible without letting it stay at the head speed that causes the resonant vibration. Once it moves past this head speed and is off the ground and in the air, the vibration will disappear. Tail resonance can also occur when holding the helicopter and spooling it up. Helicopters are not designed to be held static when the rotors are turning, and Horizon does not support or recommend doing this! Gear Stripping One thing to check is to hold the head and try to spin the tail assembly, using light pressure. The tail shouldn't spin. If the tail spins easily check the gears and make sure none of them are slipping on the shaft. Again taking off of concrete or something smooth is better. Since the helicopter sits low, grass can grab the tail and potentially strip a gear. If the tail is not holding, stripped or slipping gears is generally the cause. Motor Temperatures The motor temp is warm but well within an acceptable range for a brushless motor. The motor temperature is approximately 160 degrees Fahrenheit depending on ambient temp. A high performance motor does generate heat. As with ALL electric motors, it is advised to allow the motor to cool between flights. Servo Response When the motor is off the gyros are off. The servos will work like you are expecting them to: hold left servo goes left, center the stick the servo centers. When the motor is on the gyros are on. Therefore the servos act differently. When you hold full left rudder the error builds up. When you center the stick the gyro still thinks there is error and therefore continues to hold left rudder in. If you were to hold right rudder in for a little while, don't jab it, hold it in for a couple seconds it would then go right. Once the motor is turned off the servos will continue to operate this way for 4 seconds. Thanks, James __________________ Horizon Hobby Product Development |
| Thread Tools | |
| For Sale New in the box E-Flite Taylorcraft ARF Kit plus High Performance E-Flite components | Philscho | Aircraft - Electric - Airplanes (FS/W) | 4 | Aug 19, 2012 12:25 AM |
| For Sale E-Flite 300 32e SHP ****SOLD*** E-Flite still aviable | tomtheman | Aircraft - Electric - Airplanes (FS/W) | 2 | Mar 28, 2012 08:01 PM |
| Sold E-flite 60A ESC w/ E-flite Brushless 1010kV Motor | joshfneptune | Aircraft - Electric - Power Systems (FS/W) | 3 | Mar 05, 2012 08:18 PM |
| Discussion E-Flite Taylorcraft 450 ARF Kit and High Power E-Flite electrical components $300 | Philscho | Hot Online Deals | 1 | Mar 02, 2012 08:11 PM |
| Discussion E-Flite Su-26 and E-flite Extra 260 repair | Joe Slow | Crash Discussion | 1 | Sep 27, 2011 11:50 AM |
