Old Oct 08, 2012, 05:30 PM
indoorheli is offline
Find More Posts by indoorheli
2 seconds from crashing
indoorheli's Avatar
United States, WA, Seattle
Joined Sep 2007
Well I just made a 2s750 pack out of some new nanos i had laying around.
Not sure of the weight more just wanted to test the jst-xh connector I am about to install on one of my 130's. If the jst-xh connector works well then I wont need to find special batteries or resolder connections in the future.
indoorheli is offline Find More Posts by indoorheli
Old Oct 08, 2012, 05:57 PM
dkfuji is offline
Find More Posts by dkfuji
RC Helis: My Healthy Obsession
The OC, California
Joined Feb 2007
Originally Posted by indoorheli View Post
I have been flipping my 130x inside the living room a little bit ..I think if I had that motor setup in it I would have a few holes in the walls...and broke the tv.
Very nice! As always he sure can fly It looks like a 450 on 6s
How long out do you think the motor is from production?
Yeah, its pretty crazy seeing it live. I just don't know how he does it so effortlessly. Anyway, since it is Chinese New Years, the factory takes the entire month off!!! So I guess it won't be happening until then.
dkfuji is offline Find More Posts by dkfuji
Old Oct 08, 2012, 06:00 PM
PKM_Heliman is offline
Find More Posts by PKM_Heliman
United States, TX, Belton
Joined Sep 2009
Definitely need to know the performance on those batteries! I'd love a 750, IF it performs better, and isn't too heavy!!
Has anyone tried out the MH Delrin (OR the CNC, what's the difference?) main gear with autorotation hub? I had to hit TH the other day from about 15' up, before it went over the neighbors fence, and I wonder if that main gear with the auto rotation hub would have let me make a nicer, softer landing?
Here is what I'm looking at for my bird...
MH Titanium Swash with rear anti-rotation guide
MH Main gear with auto rotation hub (either the CNC or the delrin gear...not sure which would be best?)
RKH- Heatsink main motor mount
RKH- Main hub
RKH- Main blade grips
RKH- Tail Blade Grips
RKH- Tail gear case
RKH- Tail pitch slider
RKH- Tail push rod guide set
RKH- Servo mount set
RKH- Tail Fin (not sure which one...version 1 or 2?)
RKH- Swash leveler
OR, would you buy another 130X and keep them both stock??
PKM_Heliman is offline Find More Posts by PKM_Heliman
Old Oct 08, 2012, 06:05 PM
Joined Sep 2009
Anyone try these batteries out??
http://www.ebay.com/itm/2-Flytown-Bl...item416a047659
5C charging!! WOW!
Old Oct 08, 2012, 06:09 PM
erkq is online now
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
I haven't tried these, but I just wanted to say 5C charging is run-of-the-mill these days. It's expected.
BTW, there's no need to pay anywhere near $28 for a good 450mAh battery.
5C charging!! WOW!
erkq is online now Find More Posts by erkq
Old Oct 08, 2012, 06:18 PM
crvnation is offline
Find More Posts by crvnation
Joined Sep 2012
5C charging!! WOW!
Not those, but I tried some other Flytown batteries for my mCP X. Worked great at first, but did not last very long at all. Power was way down in less than 20 cycles.
crvnation is offline Find More Posts by crvnation
Reply With Quote  (Disabled)
Old Oct 08, 2012, 08:52 PM
Joined Sep 2009
Where? That price is for two...I saw some from the UK, but posting from there is a killer...
Old Oct 08, 2012, 09:31 PM
erkq is online now
Joined Dec 2010
Oh, well that makes more sense.
Old Oct 09, 2012, 08:13 AM
jhroof is offline
Find More Posts by jhroof
Orlando, Fl
5C charging!! WOW!
I don't if I would want to buy a battery that shows flames at 5C charge rate.
Thunder Power 325mah 65C have a 12C charge rate.
jhroof is offline Find More Posts by jhroof
Old Oct 09, 2012, 09:32 AM
SamNo3D is offline
Find More Posts by SamNo3D
Joined Jul 2012
Just doing some light hovering in the living room last night and noticed the motor was kind of warm to the touch. I had ran two packs back to back but how warm/hot is normal?
SamNo3D is offline Find More Posts by SamNo3D
Old Oct 09, 2012, 10:00 AM
erkq is online now
Joined Dec 2010
Yup... HH says 160 degrees is normal.
Old Oct 09, 2012, 05:10 PM
indoorheli's Avatar
Joined Sep 2007
Well for about 1/2 a battery I thought I finally got some tail shakes. There was absolutely no shakes until above 80% throttle so I bet I could have still flipped it around on a low flat curve without issues. Most of the bad shakes popped up after doing reverse loops. After I popped the hood I found out it was only the battery. It looked like it was secure but wasnít good enough and now I need to go find some better velcro. Just goes to show how a bit more power compared to the 120ís I have had can cause issues from simply not paying attention to something simple.
Now if I had Darryl's machine I would have really been in trouble
130x battery induced shakes (5 min 22 sec)
Old Oct 09, 2012, 05:59 PM
Joined Sep 2012
Well for about 1/2 a battery I thought I finally got some tail shakes. There was absolutely no shakes until above 80% throttle so I bet I could have still flipped it around on a low flat curve without issues. Most of the bad shakes popped up after doing reverse loops. After I popped the hood I found out it was only the battery. It looked like it was secure but wasn’t good enough and now I need to go find some better velcro. Just goes to show how a bit more power compared to the 120’s I have had can cause issues from simply not paying attention to something simple.
http://www.youtube.com/watch?v=D5RIU...ature=youtu.be
I noticed your TX beeping during flips. Is that your throttle timer when you transition through low stick in idle-up? If you set it to start/stop based on a throttle output percentage instead of a physical stick percentage, it won't do that. I know it probably doesn't really matter in the grand scheme, but I didn't like my TX beeping and timer stopping/starting every time I went through 1/4 low stick in idle-up. So, I changed it to a throttle output of 25% (independent of stick position, based on throttle curve) and the timer only beeps/stops going to low stick in NORM since my idle-up 2 and is a straight 100% "curve" and my idle-up 1 never drops below 25% at full low stick. Just thought that might help. If you do that on purpose, I'm curious as to why.
Old Oct 09, 2012, 06:27 PM
sideburn is offline
Find More Posts by sideburn
sideburn's Avatar
USA, CA, Cardiff-by-the-Sea
Joined Nov 2005
I have the same problem but I don't think there's anything g I can do about it. It's a mod kit for a dx7
sideburn is offline Find More Posts by sideburn
Old Oct 09, 2012, 06:32 PM
dkfuji is offline
The OC, California
Joined Feb 2007
Nice flight. Yep, at the headspeed my heli is running now, a little vibration would probably blow the heli apart in mid-air.
For Sale New in the box E-Flite Taylorcraft ARF Kit plus High Performance E-Flite components Philscho Aircraft - Electric - Airplanes (FS/W) 4 Aug 19, 2012 12:25 AM
For Sale E-Flite 300 32e SHP ****SOLD*** E-Flite still aviable tomtheman Aircraft - Electric - Airplanes (FS/W) 2 Mar 28, 2012 08:01 PM
Sold E-flite 60A ESC w/ E-flite Brushless 1010kV Motor joshfneptune Aircraft - Electric - Power Systems (FS/W) 3 Mar 05, 2012 08:18 PM
Discussion E-Flite Taylorcraft 450 ARF Kit and High Power E-Flite electrical components $300 Philscho Hot Online Deals 1 Mar 02, 2012 08:11 PM
Discussion E-Flite Su-26 and E-flite Extra 260 repair Joe Slow Crash Discussion 1 Sep 27, 2011 11:50 AM
