Old Sep 28, 2012, 12:26 PM
epoweredrc is offline
Find More Posts by epoweredrc
24 yrs. of Aircraft flying
epoweredrc's Avatar
United States, GA, Tallapoosa
Originally Posted by jasmine2501 View Post
Also, I've had a radio with a backlight for a couple years now, and its not actually very useful except for running the battery down. I mean, how much radio programming do you do in the dark?
Everyones driffrent but i loved the backlight on my dx8. It was nice do wish my dx7 had it for night flying its really nice
epoweredrc is offline Find More Posts by epoweredrc
Old Sep 28, 2012, 12:33 PM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
I thought it would be nice for that too, but when I tried it, I was simply blinded by the backlight and it made it harder for me to see everything else
jasmine2501 is offline Find More Posts by jasmine2501
Old Sep 28, 2012, 12:34 PM
liduno is offline
Find More Posts by liduno
liduno's Avatar
United States, FL, West Palm Beach
Joined Feb 2012
Originally Posted by everydayflyer View Post
Overall E Flite LiPolys suck. The 130 X ones are not 300 mAh closer to 360 but noy 25C either.
Best inexpenive LiPoly 2S 370 Nanotech. Less tha $5 ea. if 6X purchaeged .
Yes you need to change the connector.
Glacier 450 are now avai;. with UMX connector for $4.50. Great for sports flying a light 3D as they are heavier.
http://www.rcgroups.com/forums/showp...91&postcount=7
The mcpx stock batteries sucked but the 130 batteries aren't bad at all, I have 6 of them and they all perform well and take almost exactly the same amount of time to charge as the day they were new.
The new hyperions are supposed to be the right size with the right connector but more power, if I didn't already have 6 batteries I would try one.
Just changing between models is a pain with no back light, they should all have a back light and there should be a timer so the light turns off after 30 seconds or something like that.
liduno is offline Find More Posts by liduno
Old Sep 28, 2012, 12:36 PM
Rocket Programmer
Joined Jul 2007
It does, on the 9503 it turns off after a while. I guess I just don't have any problems seeing the screen without it. However, now that I think about it, whenever I'm looking, it's usually on. As soon as you do anything it comes on. But I don't have any trouble seeing the timer during flight or something like that. Everyone is different, I just wanted to warn people that sometimes the marketing department makes a big deal out of a feature that ends up not being a big deal.
Old Sep 28, 2012, 01:07 PM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
No one has the Hyperions in stock..... ?
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Sep 28, 2012, 01:33 PM
liduno is offline
liduno's Avatar
Joined Feb 2012
I haven't looked.
Old Sep 28, 2012, 03:34 PM
garryk is offline
Find More Posts by garryk
Corsair Captain
Joined Oct 2010
Does the HP08 motor upgrade allow for cooler operation? I don't like the idea of flying without cooling off the stock setup between flights.
Garry K.
garryk is offline Find More Posts by garryk
Old Sep 30, 2012, 03:26 AM
rynldgalano is offline
Find More Posts by rynldgalano
REYNALDO
rynldgalano's Avatar
Cyprus, Nicosia
Joined Dec 2011
is just so trickky to to remove the front servo, i am looking on it as i done cleaning the others, has any of you guys have an idea in how easy to take out?
rynldgalano is offline Find More Posts by rynldgalano
Old Sep 30, 2012, 06:46 AM
Willyboy is offline
Find More Posts by Willyboy
Willyboy's Avatar
United States, CA, Tehachapi
Joined Sep 2007
You have to split the frame completely apart.
Bob
Willyboy is offline Find More Posts by Willyboy
Old Sep 30, 2012, 10:35 AM
MarkEHansen is offline
Find More Posts by MarkEHansen
United States, CA, Sacramento
Joined Jun 2012
If you just want to clean the servo, you don't need to remove it. You can just give it a shot of FaderLube F5 directly into the servo.
MarkEHansen is offline Find More Posts by MarkEHansen
Old Sep 30, 2012, 10:52 AM
J_skaggs is offline
Find More Posts by J_skaggs
United States, CA
Joined Jan 2012
I don't remove the servo either. I spray Deoxit directly into the slot on the servo.
J_skaggs is offline Find More Posts by J_skaggs
Old Sep 30, 2012, 11:15 AM
livonia bob is offline
Find More Posts by livonia bob
Heli collector
livonia bob's Avatar
United States, MI, Livonia
Joined Apr 2009
Originally Posted by PKM_Heliman View Post
Those Walkera bearings are $10
Anyone try the tail rotor shaft from the Walkera V120 helicopters on the 130X?
Looks the same, but I don't wanna buy one if it doesn't fit, and I'm not familiar with Walkera cross fit stuff......
Sure would be nice if it did fit size wise and if the hubs fit on.. Then I could sell you guys a slipper clutch.. I know some of you have both heli's,, how about checking it out for me??
livonia bob is offline Find More Posts by livonia bob
Old Sep 30, 2012, 11:22 AM
Heli collector
Joined Apr 2009
Sure would be nice if it did fit size wise and if the hubs fit on. The groves are not a problem as they are not used with a slipper clutch.. But I would like to change the "D" gear to the other side and make you switch the tail rotor blades around and drive them CW. Then I could sell you guys a slipper clutch.. I know some of you have both heli's,, how about checking it out for me??
Old Oct 01, 2012, 10:33 AM
REYNALDO
Cyprus, Nicosia
Joined Dec 2011
ws the slipper clutch work? i dont think so that i need as long as i can not see how to differenciate to the stock one, can you post a video on it please?
Old Oct 01, 2012, 10:36 AM
REYNALDO
Cyprus, Nicosia
Joined Dec 2011
Over 130 flights with original tail gears. Simple solution to not trashing them is just do not crash. I do not understand wht so many think the 130 X is good for crashing. If you want crash and fly get a mCPX not a 130X.
Charles
+1 and my opinion the 130x is more sophisticated than the mcpx,and about changing parts on it is more easy thou.
For Sale New in the box E-Flite Taylorcraft ARF Kit plus High Performance E-Flite components Philscho Aircraft - Electric - Airplanes (FS/W) 4 Aug 19, 2012 12:25 AM
For Sale E-Flite 300 32e SHP ****SOLD*** E-Flite still aviable tomtheman Aircraft - Electric - Airplanes (FS/W) 2 Mar 28, 2012 08:01 PM
Sold E-flite 60A ESC w/ E-flite Brushless 1010kV Motor joshfneptune Aircraft - Electric - Power Systems (FS/W) 3 Mar 05, 2012 08:18 PM
Discussion E-Flite Taylorcraft 450 ARF Kit and High Power E-Flite electrical components $300 Philscho Hot Online Deals 1 Mar 02, 2012 08:11 PM
Discussion E-Flite Su-26 and E-flite Extra 260 repair Joe Slow Crash Discussion 1 Sep 27, 2011 11:50 AM
