Old Sep 26, 2012, 02:48 PM
dkfuji is offline
Find More Posts by dkfuji
RC Helis: My Healthy Obsession
The OC, California
Joined Feb 2007
Originally Posted by PKM_Heliman View Post
I took the hub off last night (took an old pair of slip joint pliers, my dremel tool with a cutoff wheel, and tiny drill bit and made a 'puller' and wouldn't you know it...IT WORKED!!), 'enlarged' the hole a tiny bit, and put it back on with CA and let it sit till lunch today. Put it all back together and turned the rotor by hand. The tail rotors are perfectly lined up now. Spun it up and it still has that sound that I don't like till about 3/4 stick, but the vibe is gone. I'll put in the new bearings and gears and see if the noise goes away. Flew a battery through 'er and it flies like the first flight! YAY! Just got the parts in from HH too, so I need to put it all back to factory new tonight!!
On another note...If I install the RKH aluminium tail pitch slider and the RKH aluminium tail gear case set to this thing, is that going to put too much extra weight on the tail and throw off the CG too much? The difference between both aluminium parts and stock is only .5 grams...I wouldn't think that would be a big issue for this helicopter...
Nice work on the hub. I am flying the MH tail and slider and the COG is perfect since I am using the Hyperion 500mah packs. I also tested the stock packs and the heli flies great either way.
dkfuji is offline Find More Posts by dkfuji
Old Sep 26, 2012, 02:52 PM
epoweredrc is offline
Find More Posts by epoweredrc
24 yrs. of Aircraft flying
epoweredrc's Avatar
United States, GA, Tallapoosa
Most say its nose heavy so some tail weight be fine.
epoweredrc is offline Find More Posts by epoweredrc
Old Sep 26, 2012, 03:50 PM
garryk is offline
Find More Posts by garryk
Corsair Captain
United States, AZ, Mesa
Joined Oct 2010
It is nose heavy.
Garry K.
garryk is offline Find More Posts by garryk
Old Sep 26, 2012, 04:17 PM
Willyboy is offline
Find More Posts by Willyboy
Willyboy's Avatar
United States, CA, Tehachapi
Joined Sep 2007
I
No, I have that plus the RKH tail grips.
Willyboy is offline Find More Posts by Willyboy
Old Sep 26, 2012, 04:31 PM
dkfuji is offline
The OC, California
Joined Feb 2007
Originally Posted by garryk View Post
It is nose heavy.
Garry K.
It is nose heavy. But, with the HP08S motor, you can slide the battery up the tray and get the COG correct. I have a layer of velcro on the tray to make sure the battery clears the spinning motor bell.
Old Sep 26, 2012, 06:21 PM
PKM_Heliman is offline
Find More Posts by PKM_Heliman
United States, TX, Belton
Joined Sep 2009
Thanks...I couldn't believe my make shift 'puller' actually worked! I will order a real one though...
where do you get those Hyperion 500mah packs, and how much are they???
Guess I need to order those RKH parts now...
PKM_Heliman is offline Find More Posts by PKM_Heliman
Old Sep 26, 2012, 06:29 PM
dkfuji is offline
The OC, California
Joined Feb 2007
You are welcome. IMO Hyperions are superior to the stock lipos in every way and they really wake up the heli both stock and HP08s version. Power and flight times are really good.
I got 2 from here: http://www.google.com/url?sa=t&rct=j...faZf2RUKRzKp-g
and the other 2 from here: http://www.google.com/url?sa=t&rct=j...r6WhPrVCbINYFA
Unfortunately, it appears everyone is out of stock. Bummer.
Old Sep 26, 2012, 10:42 PM
Sun flyer is offline
Find More Posts by Sun flyer
Phoenix, AZ
Joined Sep 2008
Need tail bearings
Where do you go to get good bearings for the tail? Thanks,
Allen
Sun flyer is offline Find More Posts by Sun flyer
Old Sep 26, 2012, 10:54 PM
dkfuji is offline
The OC, California
Joined Feb 2007
Allen
I know this is going to sound weird but...Walkera bearings from the V120 are actually an upgrade for this heli.
Old Sep 26, 2012, 11:00 PM
asosestrom is offline
Find More Posts by asosestrom
United States, CA, Santa Rosa
Joined Mar 2011
+1. I put them on mine, balanced the blades and it's smooth as buddah
asosestrom is offline Find More Posts by asosestrom
Old Sep 27, 2012, 12:26 PM
Joined Sep 2009
Those Walkera bearings are $10
Anyone try the tail rotor shaft from the Walkera V120 helicopters on the 130X?
Looks the same, but I don't wanna buy one if it doesn't fit, and I'm not familiar with Walkera cross fit stuff......
Old Sep 27, 2012, 12:49 PM
dkfuji is offline
The OC, California
Joined Feb 2007
The real issue is that the Walkera D gear is on the opposite side of the tail box. Which means you either have to continue the flat cut up the shaft to the perfect spot or mount the A gear under the B gear to get the tail to rotate the correct direction.
Old Sep 27, 2012, 03:58 PM
crvnation is offline
Find More Posts by crvnation
Joined Sep 2012
Is that a lot or something? The very best Boca bearings are $25 + shipping per set.
Better bearings are worth it because a smooth tail is a major component in a smooth and reliably running 130 X over the long term.
crvnation is offline Find More Posts by crvnation
Reply With Quote  (Disabled)
Old Sep 27, 2012, 04:29 PM
epoweredrc's Avatar
Just installed a Rakon pitch slider on mine along with the boco bearings and i can spool up nice and slow and there no vibrations at all sounds so nice. I did have to up my gyro gains if i did it right should be at +9. The lights suppose flash faster higher u go. What if you keep going right does it just start back at zero or mid?
Old Sep 27, 2012, 04:38 PM
cgriffith is offline
Find More Posts by cgriffith
cgriffith's Avatar
United States, FL, Oviedo
Joined Apr 2011
Originally Posted by epoweredrc View Post
...I did have to up my gyro gains if i did it right should be at +9. The lights suppose flash faster higher u go. What if you keep going right does it just start back at zero or mid?
I don't think +9 is possible. I don't think the light blinking speed changes. I think the values +/- max out at 5. So if you try more than that, it does nothing but stay at +/- 5.
cgriffith is offline Find More Posts by cgriffith
For Sale New in the box E-Flite Taylorcraft ARF Kit plus High Performance E-Flite components Philscho Aircraft - Electric - Airplanes (FS/W) 4 Aug 19, 2012 12:25 AM
For Sale E-Flite 300 32e SHP ****SOLD*** E-Flite still aviable tomtheman Aircraft - Electric - Airplanes (FS/W) 2 Mar 28, 2012 08:01 PM
Sold E-flite 60A ESC w/ E-flite Brushless 1010kV Motor joshfneptune Aircraft - Electric - Power Systems (FS/W) 3 Mar 05, 2012 08:18 PM
Discussion E-Flite Taylorcraft 450 ARF Kit and High Power E-Flite electrical components $300 Philscho Hot Online Deals 1 Mar 02, 2012 08:11 PM
Discussion E-Flite Su-26 and E-flite Extra 260 repair Joe Slow Crash Discussion 1 Sep 27, 2011 11:50 AM
