United States, CA, Menlo Park
Joined Nov 2005
http://www.rcgroups.com/forums/showp...postcount=3053 From what I've read so far, I'm not tempted by the nano CP X. Although a great improvement over the mCP X, people report that the nano CP X will still blow out it's tail when pressed hard. This limitation is characteristic of fixed pitch tail rotors driven by a motor in the tail. In contrast, the 130X has a variable pitch tail rotor and, once properly set up, does not blow out no matter how hard I push it (and I push it very hard). However, variable pitch tails are mechanically more complex. They take a bit more mechanical aptitude to set up and are typically not as durable as motor tails. The 130X is the right choice for me because 1) I'm interested in flying primarily 3D 2) I've been flying for 6 years and I don't crash often, and 3) I've built most of my helicopters from kits so I know how to set up them up and troubleshoot problems. However, if you're a beginner and durability is your chief concern, you should look at the video of a nano CP X in the following post: http://www.rcgroups.com/forums/showp...&postcount=330 The pilot crashes a dozen times per battery pack into concrete, and he just picks it up and continues to fly. I've never crashed a 130X anywhere near that much, but I doubt a 130X can take that much abuse without needing serious repair. |
United States, FL, West Palm Beach
Joined Feb 2012
Post
Reply Quote:
Charles |
Orlando, Fl
130x Telemetry
Very interesting thread on HF. I see other people are having range problems too.
http://www.helifreak.com/showthread.php?t=436967 |
United States, TX, Belton
Joined Sep 2009
I took the hub off last night (took an old pair of slip joint pliers, my dremel tool with a cutoff wheel, and tiny drill bit and made a 'puller' and wouldn't you know it...IT WORKED!!), 'enlarged' the hole a tiny bit, and put it back on with CA and let it sit till lunch today. Put it all back together and turned the rotor by hand. The tail rotors are perfectly lined up now. Spun it up and it still has that sound that I don't like till about 3/4 stick, but the vibe is gone. I'll put in the new bearings and gears and see if the noise goes away. Flew a battery through 'er and it flies like the first flight! YAY! Just got the parts in from HH too, so I need to put it all back to factory new tonight!!
On another note...If I install the RKH aluminium tail pitch slider and the RKH aluminium tail gear case set to this thing, is that going to put too much extra weight on the tail and throw off the CG too much? The difference between both aluminium parts and stock is only .5 grams...I wouldn't think that would be a big issue for this helicopter... |
| Thread Tools | |
| For Sale New in the box E-Flite Taylorcraft ARF Kit plus High Performance E-Flite components | Philscho | Aircraft - Electric - Airplanes (FS/W) | 4 | Aug 19, 2012 12:25 AM |
| For Sale E-Flite 300 32e SHP ****SOLD*** E-Flite still aviable | tomtheman | Aircraft - Electric - Airplanes (FS/W) | 2 | Mar 28, 2012 08:01 PM |
| Sold E-flite 60A ESC w/ E-flite Brushless 1010kV Motor | joshfneptune | Aircraft - Electric - Power Systems (FS/W) | 3 | Mar 05, 2012 08:18 PM |
| Discussion E-Flite Taylorcraft 450 ARF Kit and High Power E-Flite electrical components $300 | Philscho | Hot Online Deals | 1 | Mar 02, 2012 08:11 PM |
| Discussion E-Flite Su-26 and E-flite Extra 260 repair | Joe Slow | Crash Discussion | 1 | Sep 27, 2011 11:50 AM |
