Old Sep 22, 2012, 07:09 AM
AironeBlu is offline
Find More Posts by AironeBlu
AironeBlu's Avatar
Joined Apr 2012
Blade 130 X - Traslato e hovering di muso. (6 min 10 sec)
AironeBlu is offline Find More Posts by AironeBlu
Old Sep 23, 2012, 03:38 AM
rynldgalano is offline
Find More Posts by rynldgalano
REYNALDO
rynldgalano's Avatar
Cyprus, Nicosia
Joined Dec 2011
Originally Posted by PKM_Heliman View Post
Well,
I have an MCPx and I've done the same thing with it, and it works fine...I dunno if that's because it has a tail motor instead of a TT or not. I also have a Trex 250 that I do that with and there's no vibrations (belt drive versus TT). I have a blade 400 3D as well (again, belt drive versus TT)...same thing...no vibes. The 130X...it shook so bad the control rod actually came out of the guide. I don't think it's because it was in my hands, because without the blades on the tail it spun up to 100% throttle with little to no vibes at all (at least not noticeable to me), which leads me to think that the tail shaft is like in the first post's picture of the tail shafts that aren't square. I think I'll contact HH too, and see what can be done. I don't want to fly it and have it crash just to get parts to repair it, I'd rather prevent the crash
I guess I need to learn how to perform 'dynamic' blade balancing. I have a micro blade balancer and they're perfectly balanced with that.
I just want to help you in order to perform well your heli in the first thing you must dobefore the very first airborne push the tailboom until it clik, put another bearings on the tail from blade grip bearing of mcpx you have to ca the other near the tail slider and not to go apart to the stock bearing,put a half groomet on the tail servo linkage and tail slider linkage and you have to ca also the c gear coz the exxsisive play to the the tt well strip the bevel gear and sure the tail gears also. mine is stock solid and fly great,and as stated on the manual in lifting off go quickly to half troutle and hoover while in landing hoover in half troutle slowly to land quickly the heli while touching the ground quickly put down the truotle stick thou.
rynldgalano is offline Find More Posts by rynldgalano
Old Sep 23, 2012, 12:27 PM
PKM_Heliman is offline
Find More Posts by PKM_Heliman
United States, TX, Belton
Joined Sep 2009
Quick question...does the tail servo ever stop 'chattering'? I unplugged the main motor so I could check the pitch and the tail servo is CONSTANTLY moving back and forth....WITHOUT any stick input at all...just sitting there it won't stop chattering....is this normal?
Thanks...
Still waitin' on parts from HH...should be here in a couple days...
PKM_Heliman is offline Find More Posts by PKM_Heliman
Old Sep 23, 2012, 12:34 PM
Joined Sep 2009
Mine doesn't have any room for the little thrust washer from my Mcpx...it's too tight...it made the C/D gears bind...I put a new C gear on and ca'd it in place...the drive train is actually good right now...spun it up without the tail blades and there's no wobble or vibe...it won't stop the shakes/vibes with the tail blades installed. Got new parts coming courtesy of HH! Love their CS! I might go with the MH 'hardened steel' tail rotor shaft...IF it is an improvement over stock. Might have to get some better quality bearings if the new HH ones are still crap...
Old Sep 23, 2012, 04:34 PM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
Thanks...
That is normal for tail servos. The gyro is very sensitive.
jasmine2501 is offline Find More Posts by jasmine2501
Old Sep 23, 2012, 05:51 PM
Joined Sep 2009
Oh good...I was hoping that was the case!
Old Sep 23, 2012, 06:25 PM
sideburn is offline
Find More Posts by sideburn
sideburn's Avatar
USA, CA, Cardiff-by-the-Sea
Joined Nov 2005
The microheli tail shaft with blade grips is bogus. The shaft is like butter and bends way too easily. I wish the microheli stuff wasn't so hit or miss.
The MH tail pitch slider is great. I cannot believe you guys are able to fly this heli with the stock pitch slider. I was literally going through them after 1 - 3 flights.. they would instantly bust on me after a few hard pitch pumps/tic tocs.
After i got the MH one, I no longer have any problems with this heli except the tail blades bust after 25 or so flights.
And of course when this happens.. the heli falls out of the sky, one of the tail gears strips, and some other parts break.
Has anyone come up with a solution to this problem? Or am I once again, the only unlucky one with the tail blades flinging off.
They just get looser and looser from rubbing agains the bolt until they finally bust.
sideburn is offline Find More Posts by sideburn
Old Sep 23, 2012, 06:30 PM
epoweredrc is offline
Find More Posts by epoweredrc
24 yrs. of Aircraft flying
epoweredrc's Avatar
United States, GA, Tallapoosa
Seems most on hf do not like the 130x MH parts everyone using Rakon
epoweredrc is offline Find More Posts by epoweredrc
Old Sep 23, 2012, 07:27 PM
Willyboy is offline
Find More Posts by Willyboy
Willyboy's Avatar
United States, CA, Tehachapi
Joined Sep 2007
Hmmm, mine chattered from day one until it went out last week. Since there are no tail servos available, I did the DS-35 substitute and have no more chattering. Do you have any idea why that is?
Bob
Willyboy is offline Find More Posts by Willyboy
Old Sep 23, 2012, 08:42 PM
epoweredrc's Avatar
Bob
Got any pics? Like to see how you mounted it thanks
Old Sep 23, 2012, 09:15 PM
indoorheli is offline
Find More Posts by indoorheli
2 seconds from crashing
indoorheli's Avatar
United States, WA, Seattle
Joined Sep 2007
Bob
I would think it is either due to a larger center pulse width or larger deadband when compared to stock
indoorheli is offline Find More Posts by indoorheli
Old Sep 23, 2012, 09:18 PM
Joined Sep 2009
Those look like good parts...the only problem is that Rakon doesn't have the tail shaft with hub... :-\
Old Sep 23, 2012, 09:50 PM
epoweredrc's Avatar
Oh you said tail shaft, i didnt know anyone had tail shafts except stock. Im sure more ppl will come out with more parts
Old Sep 23, 2012, 10:00 PM
ifoguy is offline
Find More Posts by ifoguy
United States, CA, Menlo Park
Joined Nov 2005
Also note that Wiskey reports that MicroHeli tail shaft isn't interchangeable with stock tail shaft:
http://www.rcgroups.com/forums/showp...postcount=4481
ifoguy is offline Find More Posts by ifoguy
Old Sep 23, 2012, 11:18 PM
liduno is offline
Find More Posts by liduno
liduno's Avatar
United States, FL, West Palm Beach
Joined Feb 2012
It sounds like you have a vibration problem, the stock slider doesnt break from normal use but if the tail has a vibe it will snap the pin off the bottom of the slider. a vibe could cause the blades to break too.
I have about 200 flights on a stock slider and tail blades but this heli has no spool up vibes.
On the other hand, I bought one that had a spool up vibe and it tossed a tail blade and broke the slider pin in a matter of minutes..lol
liduno is offline Find More Posts by liduno
For Sale New in the box E-Flite Taylorcraft ARF Kit plus High Performance E-Flite components Philscho Aircraft - Electric - Airplanes (FS/W) 4 Aug 19, 2012 12:25 AM
For Sale E-Flite 300 32e SHP ****SOLD*** E-Flite still aviable tomtheman Aircraft - Electric - Airplanes (FS/W) 2 Mar 28, 2012 08:01 PM
Sold E-flite 60A ESC w/ E-flite Brushless 1010kV Motor joshfneptune Aircraft - Electric - Power Systems (FS/W) 3 Mar 05, 2012 08:18 PM
Discussion E-Flite Taylorcraft 450 ARF Kit and High Power E-Flite electrical components $300 Philscho Hot Online Deals 1 Mar 02, 2012 08:11 PM
Discussion E-Flite Su-26 and E-flite Extra 260 repair Joe Slow Crash Discussion 1 Sep 27, 2011 11:50 AM
