Old Sep 20, 2012, 05:56 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
post 4609 snip
OK, I flew it...right now wishin' I hadn't bought it The tail servo, upon spool up (yes, on the ground, not in my hands) will NOT operate because of the immense vibrations. When I get to 3/4 stick it will lift off and start to pirouette like mad, with no tail control AND the gear has slipped so even if I had tail control, it would still spin like crazy
post 4615
The first two flights were really nice! Now...
One post sounds like it never was flyable then a follow up reads like it flew fine twice and then developed issues.
The tail boom not being fully inserted or being lose and backing out is a well known issue as well as many other issues.
With HH / E flite /Blade aircraft one can either look at them as a ARTF that
(only ?) needs a complete going over and deal with it ,
http://www.rcgroups.com/forums/showp...postcount=4611
which may take two months which is a very long time to have $300 invested in a useable product.
The first post of this thread has a lot of great info.
FWIW
I have had mine for two months. I spent 5 hours going over it before the first flight. After 10 flights I added a thrust washer to preload the tail shaft bearings.
I have 129 flights on mine. Right cyclic servo failed at flight #62, I replaced A gear with metal one after 40 flights, 100 + flights I crashed and split tail boom and bent TT,repair cost approx. $12 which is nothing compared to repairing a Blade 400 and the 130 X flys better IMO.
Charles
Old Sep 20, 2012, 12:59 PM
PKM_Heliman is offline
Find More Posts by PKM_Heliman
United States, TX, Belton
Joined Sep 2009
Finally got a chance to call HH. Tail shafts r out of stock till the 27th...they're sending a new tail shaft, bearings, gears and a tail pitch slider...the tail shaft will come in later :-( about the same time as my nano cpx...
PKM_Heliman is offline Find More Posts by PKM_Heliman
Old Sep 20, 2012, 07:20 PM
TonyTypeS is offline
Find More Posts by TonyTypeS
United States, CA, Hacienda Heights
Joined Jun 2004
Originally Posted by turboparker View Post
Just got my lightweight Hyp 500 35c Babbelbatt to test.
Weight w/Velcro is 26.50g, and the dimensions are 12 x 24.5 x 44. It just finished charging. Unfortunately, the wind is up to 13-24 MPH. Has anyone on here tried to fly the 130X in a 25 MPH wind?
Joel
I have.... 20+ mph winds is no match for the HP08 along with the Hyperion 500 haha. You will be surprise how well the 130x flies in wind.
TonyTypeS is offline Find More Posts by TonyTypeS
Old Sep 20, 2012, 09:52 PM
epoweredrc is offline
Find More Posts by epoweredrc
27 yrs. of Aircraft flying.
epoweredrc's Avatar
United States, GA, Tallapoosa
Stock 130X does well in wind, lot better then the MCPX it always knew the wind was there the 130X I compare more to the 450 fbl I do not mind the wind.
epoweredrc is offline Find More Posts by epoweredrc
Old Sep 20, 2012, 11:05 PM
deonjams is offline
Find More Posts by deonjams
Philippines, NCR, QC
Joined Dec 2011
130x handles the wind better than 450 3D (flybarred), and close to 300x and 450x. Blade FBL control systems work very well in wind, gives more confidence. Larger heli's or faster blade speeds will be more stable in wind (stating the obvious I guess). MCPX actually does pretty well in wind, considering its light weight and motor driven tail
deonjams is offline Find More Posts by deonjams
Old Sep 21, 2012, 07:49 AM
epoweredrc's Avatar
I flew my mcpx in wind all time was just saying it knew it was there the 130x fly like a larger heli you do not even notice the wind with it. My zyx b450 does fly better then my old b450
High hs and fbl does help
Joel, nice flying spot you have looks slike quite a back yard big enough for lots of things wish my current yard was bigger
Old Sep 21, 2012, 08:51 AM
turboparker is offline
Find More Posts by turboparker
I'd rather be flying!
turboparker's Avatar
Joined Jul 2009
I have flown my 130X in 10-15 MPH winds, and it did just fine. However, 25 MPH is a substantial increase. I was just wondering if anyone had tried flying in winds that strong with the stock motor.
Got a few flights in with the Hyp 500 VX pack. I love it! Lots of punch, even though it's only on the third cycle. Definitely more punch & a lot less bog at max collective than my Hyp 450 25c packs. I think I can tell that it's heavier than my TP 325s when doing flips & such - but that could have just been my flying! The Hyp 500 is my new favorite for general use. I'll still pop in a TP 325 when I practice aerobatics though.
Today, I'm heading up to my hometown on Lake of the Woods for a week or so to do some walleye fishing with my brother & to do some flying with a friend of mine who built a flying field this summer. It started out as a pair of crossed 500' runways, but he has now extended the N-S runway to 1000'! (He's also building a full-scale runway & a full-service A&P shop.) I'm bringing the keychain cam & my 3CCD camcorder w/gyrostabilized lens. We'll be flying helis & fixed-wing. If I get any decent video, I'll post-up.
Epowered - we meet again! BTW - thanks for the sub on my YouTube channel! Yes, I love my yard! It's the first time I've ever had a yard large enough from which to fly anything larger than an mSR or Vapor. BTW - you're only seeing my backyard in the video. Off to the left (north), I have an open yard that's approximately 330' x 160'. I can fly both yards from one spot (not from the deck, though). I often fly a 2-dimensional L-shaped circuit from that spot with my fixed-wing UMs. That way, one circuit is about a 1/3-mile or so in circumference. It feels like I'm actually flying somewhere, and maneuvering between the trees & my ham radio antenna keeps things interesting. I find that to be much more fun that simply 'flying the pattern' at the club field. When I get a bit more comfortable with the 300X, I plan to do the same with it. Aught to be great for big-air maneuvers, which is also my favorite fixed-wing flying style.
Yeah, the mCP X definitely knows when it's windy! Almost lost my brushless mCP X a few times due to a combination of extreme translational lift & the inability make headway. I bailed & hit TH before the wind took the bird into my woods.
Joel
turboparker is offline Find More Posts by turboparker
Old Sep 21, 2012, 12:24 PM
liduno is offline
Find More Posts by liduno
liduno's Avatar
United States, FL, West Palm Beach
Joined Feb 2012
Anyone able to log on to helifreak?
liduno is offline Find More Posts by liduno
Old Sep 21, 2012, 12:34 PM
livonia bob is offline
Find More Posts by livonia bob
Heli collector
livonia bob's Avatar
United States, MI, Livonia
Joined Apr 2009
Not in the past 24 hours or so..
livonia bob is offline Find More Posts by livonia bob
Old Sep 21, 2012, 12:43 PM
liduno is offline
liduno's Avatar
Joined Feb 2012
I'm having withdrawals..lol
Old Sep 21, 2012, 12:48 PM
anthony7820 is offline
Find More Posts by anthony7820
Team CJ Youngblood
anthony7820's Avatar
United States, WV, Wheeling
Joined Jul 2009
It works fine for me on my computer. On my phone it doesn't
anthony7820 is offline Find More Posts by anthony7820
kauperhed is offline
Find More Posts by kauperhed
Joined Sep 2012
Yeah, what's up? I got on here to see if anyone knew anything.
kauperhed is offline Find More Posts by kauperhed
Old Sep 21, 2012, 12:55 PM
liduno is offline
liduno's Avatar
Joined Feb 2012
Really? Hmm! Maybe I will try restarting my computer and clearing my cookies.
Old Sep 21, 2012, 01:03 PM
liduno is offline
liduno's Avatar
Joined Feb 2012
That didn't work.
Old Sep 21, 2012, 01:27 PM
Willyboy is offline
Find More Posts by Willyboy
Willyboy's Avatar
United States, CA, Tehachapi
Joined Sep 2007
Haven't been able to get on since yesterday afternoon.
Willyboy is offline Find More Posts by Willyboy
For Sale New in the box E-Flite Taylorcraft ARF Kit plus High Performance E-Flite components Philscho Aircraft - Electric - Airplanes (FS/W) 4 Aug 19, 2012 12:25 AM
For Sale E-Flite 300 32e SHP ****SOLD*** E-Flite still aviable tomtheman Aircraft - Electric - Airplanes (FS/W) 2 Mar 28, 2012 08:01 PM
Sold E-flite 60A ESC w/ E-flite Brushless 1010kV Motor joshfneptune Aircraft - Electric - Power Systems (FS/W) 3 Mar 05, 2012 08:18 PM
Discussion E-Flite Taylorcraft 450 ARF Kit and High Power E-Flite electrical components $300 Philscho Hot Online Deals 1 Mar 02, 2012 08:11 PM
Discussion E-Flite Su-26 and E-flite Extra 260 repair Joe Slow Crash Discussion 1 Sep 27, 2011 11:50 AM
