Concerning dynamic balancing the tail blades...
It's just a bit of trial and error. Cut a piece of tape about 1/4" x 1/4" and place approx in the middle of one blade, spin it up. If it's better you got the right blade. If it's worse move the tape to the other blade. Once you have something that tells you it's better you can then add another sliver of tape on the blade with the piece of tape or you can move the original piece in or out. A few tries and it should be near perfect. It's ok to hold the heli in your hand for this as you spool it up. I got mine done in less than 10 minutes and ended up with a piece of tape on both blades. |
J |
Iowa
Joined Nov 2009
Also, make sure your tail blades have 0 degrees of pitch with the throttle stick all the way down. I check mine by rotating the tail blades until they hit the edge of the blade grips; one right, and the other left. They should form a straight line when viewed from above. You can adjust pitch by moving the servo tray for or aft, or by winding the tail blade control rod in or out. Otherwise plan on wearing goggles so when your heli sheds a tail blade, it doesn't hit you in you eyeball. Trust me on this one. I have delt with enough of these to know when the vibrations are excessive enough for it to loose a blade on it's maiden flight, and by the way you are describing it vibrating well past 1/3 throttle, I guarantee you what the outcome will be. Another thing to watch for is, don't over-tighten the tail blades because this can cause excessive tail vibrations. They should be adjusted so they are just loose enough to fall under their own weight with this particular heli as the tail rotor is being rotated.
Same here. I saw no good reason to put up with harmonic vibration in a system that spins at 20,000 RPM - especially when it was so easy to fix. And it does not vibrate when spooled-up in my hand, either. However, it did before I solved the tail vibration issue.Joel |
Latest blog entry: Eflite UMX Sbach 3D on 3s - 2300Kv/5043...
Any aggressive or intent vibrations are bad period. I have been flying my 2 back to back with no issues other than a C or D gear change out..doesn't take long at all anymore to do. My other 2 are shelved awaiting parts. I also have a 300x only flew a couple times and tail servo went out. I put in all align digital servos and am chasing a tail wag problem. I just want to sell it with my bucket of parts that I wasted my money on lol. It is too much for my back yard. J |
Orlando, Fl
I love this little heli, but I am still plagued by an occasional glitch. This morning it happened twice. The heli just stops responding for a second and then continues flying. If I am up high enough, I can recover before it hits the ground. I thought it might be temperature related, but this morning it was cool and it happened after 2 mins flying. It acts like the rx just loses signal and resets. I talked to some other guys that are having the same problem. How many on this forum have experienced this?
United States, CA
Joined Jan 2012
United States, TX, Belton
Joined Sep 2009
Ok, put her back together and spun her up. Horrific noise and vibration till about 3/4 stick then it went smooth. Flew 2 batts through it and did some inspecting. Tail pin for slider was almost out of its hole. Slop in tail bearings. Could have lost the entire tail which would have led to a nasty crash. Guess I'll have to contact HH and see what they can do to send me better parts...sad...I sure hope the nano cpx I have coming turns out better...I also see that the big dark gear now has a slight groove in it. Could this be from the FET on the front servo???
| Thread Tools | |
| For Sale New in the box E-Flite Taylorcraft ARF Kit plus High Performance E-Flite components | Philscho | Aircraft - Electric - Airplanes (FS/W) | 4 | Aug 19, 2012 12:25 AM |
| For Sale E-Flite 300 32e SHP ****SOLD*** E-Flite still aviable | tomtheman | Aircraft - Electric - Airplanes (FS/W) | 2 | Mar 28, 2012 08:01 PM |
| Sold E-flite 60A ESC w/ E-flite Brushless 1010kV Motor | joshfneptune | Aircraft - Electric - Power Systems (FS/W) | 3 | Mar 05, 2012 08:18 PM |
| Discussion E-Flite Taylorcraft 450 ARF Kit and High Power E-Flite electrical components $300 | Philscho | Hot Online Deals | 1 | Mar 02, 2012 08:11 PM |
| Discussion E-Flite Su-26 and E-flite Extra 260 repair | Joe Slow | Crash Discussion | 1 | Sep 27, 2011 11:50 AM |
