Old Aug 17, 2012, 05:13 AM
GrahamWilson is offline
Find More Posts by GrahamWilson
Beating air into submission!
GrahamWilson's Avatar
Australia, NSW, Vaucluse
Joined Aug 2011
Dont you just love Horizon Hobbies quality control.
GrahamWilson is offline Find More Posts by GrahamWilson
Old Aug 17, 2012, 07:16 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Perhaps you are confusing quality control with QC which I believe in the case of HH ,E Flite , Blade stands for Quick Check.
Charles
Old Aug 17, 2012, 08:00 AM
jhroof is offline
Find More Posts by jhroof
Orlando, Fl
Originally Posted by everydayflyer View Post
perhaps you are confusing quality control with qc which i believe in the case of hh ,e flite , blade stands for quick check.
Charles
lol
jhroof is offline Find More Posts by jhroof
Old Aug 17, 2012, 08:03 AM
jhroof is offline
Orlando, Fl
Originally Posted by liduno View Post
Some one asked about how to make their 130 not shake.
And make sure your tail rotor shaft is square, some weren't square from the manufacturer
What size orings do you use?
Old Aug 17, 2012, 08:55 AM
selzoc is offline
Find More Posts by selzoc
Joined Oct 2011
001 for the tail
1/2 002 for the balls on the pitch slider and tail control arm
003 for the head
http://www.oringsandmore.com/servlet...ize-003/Detail
selzoc is offline Find More Posts by selzoc
Old Aug 17, 2012, 09:43 AM
turboparker is online now
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Originally Posted by TURBOOMNI View Post
I believe Radio Shack carries it.
They carry DeoxIT D-series, not the Fader series.
Joel
turboparker is online now Find More Posts by turboparker
Old Aug 17, 2012, 03:00 PM
Willyboy is offline
Find More Posts by Willyboy
Willyboy's Avatar
United States, CA, Tehachapi
Joined Sep 2007
Originally Posted by jhroof View Post
lol
You forgot to add Spektrum to the list. My DX18 is now in there hands and I am waiting to hear from them. Worked for one week and not not that well.
Bob
Ooops wrong quote but you know who I meant.
Willyboy is offline Find More Posts by Willyboy
Old Aug 17, 2012, 03:13 PM
d2tw4all is offline
Find More Posts by d2tw4all
United States, RI, Smithfield
Joined Dec 2011
Boca Bearings directionality?
I just got my bocas finally for the tail from the LHS, but are these tapered or directional in any way? I just want to make sure I put them in correctly. Also I've heard some have glued them in, do I need to do that or is press fit fine?
Tom
d2tw4all is offline Find More Posts by d2tw4all
Old Aug 17, 2012, 04:10 PM
liduno is offline
Find More Posts by liduno
liduno's Avatar
United States, FL, West Palm Beach
Joined Feb 2012
Originally Posted by selzoc View Post
001 for the tail
003 for the head
Yup, I actually didnt use the o-rings on the bottom of the pitch links, they rubbed on the swash.
liduno is offline Find More Posts by liduno
Old Aug 17, 2012, 07:07 PM
jhroof is offline
Orlando, Fl
Tom
If you are asking about the tail shaft bearings, they are flanged and will go in only one way.
Old Aug 17, 2012, 11:02 PM
d2tw4all is offline
Joined Dec 2011
The originals are clearly flanged, but the boca bearings that I got are not. Are the bocas also supposed to be flanged? If so, I guess I got the wrong bearings somehow...
I broke the stupid little plastic pin off of the pitch slider when taking the tail apart, barely touched it and it just broke off. REDICULOUS. I drilled out where the plasticrap pin was and glued in a piece of metal rod the same diameter of the pin. I think it will do but I'm nervous that these new bearings aren't flanged...
Tom
Old Aug 17, 2012, 11:29 PM
d2tw4all is offline
Joined Dec 2011
Yup LHS ordered the wrong bearings, these fit in the holes but are NOT flanged. Lovely. I'll have to have them order the correct ones, which I see are now unavailable. Awesome. I wonder if these ones without the flanges will fit in the tail shaft for the TT?
Tom
Old Aug 17, 2012, 11:40 PM
achogg33 is offline
Find More Posts by achogg33
Joined Oct 2011
My tail servo just packed up after around 10 flights
achogg33 is offline Find More Posts by achogg33
Old Aug 18, 2012, 09:52 AM
Southern Pride
It seems that many of the servos have very bad solder joints where the motor leads attach to the servo boards. Two of mine needed resloding when new and I have read many post of others have the same issue.
There have also been reports of the tail servo falling apart as in the screws that hold the mechanics on the board back out and some have been reported as having the threads striped on new ones.
I had the right cyclic servo go full up and the motor burning out right when I lifted off on flight #63. Voltage reqgulator on main board got hot enough to melt and split the heat shrink. I replaced the servo and informed Blade but to date only an email from them requesting photos ot the control board. Go figure I only asked about a relacement servo and only mentioned the control board in case it developed issues later.
Charles
Old Aug 18, 2012, 10:52 AM
jhroof is offline
Orlando, Fl
Tom
I would suggest ordering some good quality bearings from Boca.
Edit: Sorry, I didn't see the previous post. You did get Boca. These are the one's I ordered: SMF681X-ZZ.
For Sale New in the box E-Flite Taylorcraft ARF Kit plus High Performance E-Flite components Philscho Aircraft - Electric - Airplanes (FS/W) 4 Aug 19, 2012 12:25 AM
For Sale E-Flite 300 32e SHP ****SOLD*** E-Flite still aviable tomtheman Aircraft - Electric - Airplanes (FS/W) 2 Mar 28, 2012 08:01 PM
Sold E-flite 60A ESC w/ E-flite Brushless 1010kV Motor joshfneptune Aircraft - Electric - Power Systems (FS/W) 3 Mar 05, 2012 08:18 PM
Discussion E-Flite Taylorcraft 450 ARF Kit and High Power E-Flite electrical components $300 Philscho Hot Online Deals 1 Mar 02, 2012 08:11 PM
Discussion E-Flite Su-26 and E-flite Extra 260 repair Joe Slow Crash Discussion 1 Sep 27, 2011 11:50 AM
