Espritmodel.com Heli Air
Old Aug 10, 2012, 02:42 PM
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
Originally Posted by anthony7820 View Post
Check the little anti-rotation ball on the tail assembly. I had the exact same problem with the tail blowing out and I went over the tail a couple of times and noticed that the little anti-rotation ball had broken off. So I disassembled the part and took a 1/16 drill bit and drilled the plastic by hand until I got up to the bearing, then glued in a piece of small music wire. TADA!!, no more slop in the tail, actually it was a lot better than before.
Also did some dampening with half mcpx grommets, pictures attached. Hopefully this helps, I hate seeing people not being able to fly.
Thanks. That part is fine - they replaced that while it was there.
They are sending me a new board. They said if that doesn't fix it then they'll need to get the heli back. I told them that if sent the heli back that they will be sending me my money back.
turnerm is offline Find More Posts by turnerm
Old Aug 10, 2012, 03:10 PM
AMA # 949551
rikybob's Avatar
USA, FL, Orlando
Joined Oct 2009
This is literally my story circa 2008 with the "Blade SR, the next logical step from coaxial". Only I didn't ask for my money back. I wasn't going to let a little "whirlygig" beat me!
Eventually I would kick that little devils butt.....learn CP and mercifully a H/H fanboy from Fleabay relieved me of it!
I Love/Hate H/H!
Kinda like I feel about Tony Soprao and Walt White!
b
rikybob is offline Find More Posts by rikybob
Old Aug 10, 2012, 03:29 PM
United States, CA, Sebastopol
Joined Dec 2010
Off to build my 51" Slick.
Well, that will make you feel good! But you already know that.
erkq is offline Find More Posts by erkq
Old Aug 10, 2012, 03:31 PM
United States, FL, West Palm Beach
Joined Feb 2012
This was meant as a joke right? lol
liduno is offline Find More Posts by liduno
Old Aug 10, 2012, 03:33 PM
AMA # 949551
rikybob's Avatar
USA, FL, Orlando
Joined Oct 2009
It was terrible, just terrible.
Almost put me off CP and heli's in general.
I kicked it's butt then discovered clones and haven't looked back since!
b
Old Aug 10, 2012, 03:54 PM
Joined Feb 2012
b
Every time I'm in the hobby store and see some one buying parts for an Sr I have to bite my tongue..lol
Old Aug 10, 2012, 04:00 PM
Rocket Programmer
jasmine2501's Avatar
United States, CO, Golden
Joined Jul 2007
I saw that happen one day and the LHS owner convinced them to buy something else
jasmine2501 is offline Find More Posts by jasmine2501
Old Aug 10, 2012, 06:31 PM
xxxxxxxx
United States, CA
Joined Jan 2012
Today I replaced all four gears on my 130X. Upon completion I observed the following.
There is no mold line on the side of the A gear.
I was able to slip a sheet of paper between the A gear and FET on the servo board.
The mesh between the A and B gear was correct without adjustment of the boom.
The parts were received by my LHS this week. Could it be HH is tweaking dimensions of the parts based on problems reported or the manufacturer is holding tolerances better?
J_skaggs is offline Find More Posts by J_skaggs
Old Aug 10, 2012, 08:26 PM
Joined Dec 2010
b
I tried to warn a friend off the Blade SR but he didn't listen. It put him off the hobby for a good 9 months. He's back and doing well with a 130. He listens to me now...
Old Aug 10, 2012, 11:00 PM
tmsn's Avatar
USA, CA, San Francisco
Joined Dec 2009
I bought some 300mah Nanotech batteries for my stock 130X. I'm going to recycle some connectors since I'm still using a stock connector in my 130X.
So I have a question - the Nanotech have both a balance lead with 3 wires, and a standard JST connector with 2 wires, red and black. The stock blade batteries have 3 wires going into the standard connector. I'm confused about where to solder the connectors to the Nanotech. Should I solder the balance lead, or the regular lead?
tmsn is offline Find More Posts by tmsn
Old Aug 10, 2012, 11:14 PM
Team HeliProz
anthony7820's Avatar
United States, WV, Wheeling
Joined Jul 2009
Regular. red to red, black to black. The white wire on the stock battery is the balance wire for the stock charger.
anthony7820 is offline Find More Posts by anthony7820
Old Aug 10, 2012, 11:17 PM
tmsn's Avatar
Joined Dec 2009
Thanks - does that mean I won't be able to charge the battery with the stock charger?
Old Aug 10, 2012, 11:26 PM
Team HeliProz
Joined Jul 2009
You might still be able to. I'm not entirely sure. I know I use my regular charger on the stock batteries just by connecting the red and black wires. So I am assuming it will work.
Just watch it carefully the first time you go to charge it
Old Aug 11, 2012, 12:35 AM
Joined Dec 2010
It's actually the balance tap for any charger and should be kept, especially if you want to charge at more than 1C. I use the thicker power wires for the red and black to the UMX connector but run the white wire from the balance connector to the white wire of the UMX connector so you can balance charge it and use the thicker wires for power delivery. Sounds weird, but it works great.
Old Aug 11, 2012, 01:01 AM
Did you commit aviation today?
turboparker's Avatar
East Bethel, MN USA
Joined Jul 2009
+1000!
What a horrid machine! Buying the Blade SR is the worst purchase decision I've made so far in 28 years of flying RC. Thanks to that wretched excuse for a flying machine, my heli skills are at least a year behind where they should have been by now.
Joel
turboparker is online now Find More Posts by turboparker
For Sale New in the box E-Flite Taylorcraft ARF Kit plus High Performance E-Flite components Philscho Aircraft - Electric - Airplanes (FS/W) 4 Aug 19, 2012 12:25 AM
For Sale E-Flite 300 32e SHP ****SOLD*** E-Flite still aviable tomtheman Aircraft - Electric - Airplanes (FS/W) 2 Mar 28, 2012 08:01 PM
Sold E-flite 60A ESC w/ E-flite Brushless 1010kV Motor joshfneptune Aircraft - Electric - Power Systems (FS/W) 3 Mar 05, 2012 08:18 PM
Discussion E-Flite Taylorcraft 450 ARF Kit and High Power E-Flite electrical components $300 Philscho Hot Online Deals 1 Mar 02, 2012 08:11 PM
Discussion E-Flite Su-26 and E-flite Extra 260 repair Joe Slow Crash Discussion 1 Sep 27, 2011 11:50 AM
