Old Aug 07, 2012, 09:51 AM
cactus is offline
Find More Posts by cactus
cactus's Avatar
United States, CO, Durango
Joined Sep 2001
I picked up a 130x at a HS while I was in Denver this past weekend. I got home Sunday and bound it to my JR9503 following the Dx7/Dx8 settings and charged the battery. I went to test it last night in the garage and before it reaches spool up speed, it tips over to the right without any cyclic input. I looked at the swash movement while TH is engaged and the swash is starting level and mid-stick and stays level through the whole pitch range, but when I spooled it up in NORM the swash starts tilting and pegs out to the right. No wonder it tilts over. Do I have a bad board? I initialize it sitting level and do not move it.
cactus is offline Find More Posts by cactus
Old Aug 07, 2012, 10:02 AM
everydayflyer is online now
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
I find it best to spool up fast as in St1 (Idl Up) and get of the ground as soon as possible.
I use mininum correction input during spoolup.
Some spool up slow and some say use not inputs until heli if in the air. Above is what works best for me.
If you do any reading at all you will find that the tail shaft bearing are awful and thus there is an extrem amout of tail vivbrations during spool up. There are many fixs for this and I have posted my fix about 6 times already in this thread. Many purchase $25 worth of Bocca Flange bearings and report they are great but that seems rather expensive to me when my free fix works so well.
Charles
everydayflyer is online now Find More Posts by everydayflyer
Old Aug 07, 2012, 10:26 AM
turnerm is offline
Find More Posts by turnerm
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
I'd take it back from you where you bought it personally. Even WITH the bad tail vibes that everyone else experiences the heli does not tip while spooling up nor should it. I'm not saying that the vibes aren't the cause - they may be, but other people have had bad vibes and not experienced this tipping issue.
If it's not possible to take it back from where you got it then call HH right away - they'll take care of you.
turnerm is offline Find More Posts by turnerm
Old Aug 07, 2012, 10:28 AM
cactus is offline
cactus's Avatar
Joined Sep 2001
Well I still have and fly my OEM v1 mcpx, so I may have a few of those in the parts bin. I was also reading about sub trim, but since mine stays level after initialization and cyclic inputs I am leaning towards vibes overwhelming the gyros or a flaw in the board.
Old Aug 07, 2012, 10:33 AM
cactus is offline
cactus's Avatar
Joined Sep 2001
I purchased it while in Denver which is about 7+ hours away. I called the hobby shop and left a message. If I don't hear from them soon, I will try giving HH a try.
My mcpx pops right up off the ground without any cyclic input. All my past CP birds without FBL I had to feed in some cyclic during lift off, but not much if the swash was leveled right during the radio setup.
turnerm is offline
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
It could be vibes. I'm just saying that others (including me) have experienced vibes without experiencing tipping on spool up (in any mode).
Old Aug 07, 2012, 10:34 AM
sertav is offline
Find More Posts by sertav
Joined Apr 2012
Yes, something is very wrong. That is not normal behavior. Take it back.
sertav is offline Find More Posts by sertav
Reply With Quote  (Disabled)
Old Aug 07, 2012, 10:38 AM
turnerm is offline
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
Yea - the 130x is somewhere in between. If you pop it off the ground (as opposed to trying to ease it off the ground) then you really don't need any cyclic input. But if you try to ease it off the ground you'll need to finesse in some cyclic to make it lift off straight.
Old Aug 07, 2012, 11:15 AM
cactus is offline
cactus's Avatar
Joined Sep 2001
As long as the swash is pinning itself all the way to the right under power, I am not going to attempt to lift off in this condition.
Old Aug 07, 2012, 11:29 AM
sertav is offline
Joined Apr 2012
And that is absolutely the correct move...don't fly it... I had very similar issues with my first 130 X. After a few blade scrapes on the kitchen tile from it wanting to roll over well below flight RPM, I boxed it up and returned it to HH for a refund before I *really* crashed it and they could blame me. I ordered a second one and put the new blades on the old one "just in case".
Old Aug 07, 2012, 11:31 AM
Southern Pride
Nor would I however the only times I have had mine flip over during spool up was during a slow spool. up.
Using St.2 for spoo lup most imes I need no input prior to lift off but sometimes it needs slight tail input and from time to time a slight amount of cyclic input. I have 60 flights on mine so have more than a few spool ups to base my input on.
Old Aug 07, 2012, 11:55 AM
cactus is offline
cactus's Avatar
Joined Sep 2001
Thanks for the feedback guys. I got in touch with the HS and they guy told me to rebind it. Going to try that first when I get home tonight. Then go from there.
Old Aug 07, 2012, 11:58 AM
lkagan is offline
Find More Posts by lkagan
lkagan's Avatar
United States, FL, Boynton Beach
Joined Aug 2011
Does anyone have the yellow tail and main blades that would like to trade for the orange ones (brand new in package)?
lkagan is offline Find More Posts by lkagan
Old Aug 07, 2012, 12:34 PM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
Make sure you don't have any trim entered in all your flight modes, then rebind it. Which shop did you go to?
jasmine2501 is offline Find More Posts by jasmine2501
Old Aug 07, 2012, 12:49 PM
sertav is offline
Joined Apr 2012
Didn't you already try that? That's like the "go-to" move when Blade/HH BNF aircraft start acting up.
For Sale New in the box E-Flite Taylorcraft ARF Kit plus High Performance E-Flite components Philscho Aircraft - Electric - Airplanes (FS/W) 4 Aug 19, 2012 12:25 AM
For Sale E-Flite 300 32e SHP ****SOLD*** E-Flite still aviable tomtheman Aircraft - Electric - Airplanes (FS/W) 2 Mar 28, 2012 08:01 PM
Sold E-flite 60A ESC w/ E-flite Brushless 1010kV Motor joshfneptune Aircraft - Electric - Power Systems (FS/W) 3 Mar 05, 2012 08:18 PM
Discussion E-Flite Taylorcraft 450 ARF Kit and High Power E-Flite electrical components $300 Philscho Hot Online Deals 1 Mar 02, 2012 08:11 PM
Discussion E-Flite Su-26 and E-flite Extra 260 repair Joe Slow Crash Discussion 1 Sep 27, 2011 11:50 AM
