Joined Apr 2010
A great FP trainer for a CP is the walkera V120d01. It is not "self stabilizing" like helis with a 45 degree flybar. I was able to go from this heli to a flybar gaui 200.
I would agree that going from a 120SR to a small CP would be tough, but it depends on the stabilization system of the CP. Very hard to go from there to a flybar gaui 200, but not so hard to go from there to say a walkera v120D02s. And I bet the 130 has at least a just as good better stabilization system than the v120d02s... If you get a sim then anything is possible... Chief |
Malaysia, Penang, Bayan Lepas
Joined Apr 2010
You can't just increase pitch without adding headspeed, it is going to bog the motor down and cause the heli to fly like crap (believe me, I tried to push my 250 down to about 2k RPM, unstable as hell and are all over the place, same for my 4G6S). The 3 axis does not self stabilize. Inherent nature of 45 degrees flybar (120sr) is that when you release the aileron and elevator, it self stabilize (locks back into hover), but in 90 degrees flybar or 3 axis stabilization system, they don't. They'll continue the heading of the last command. My suggestion is that try out some sim (even free ones), and you'll see how flying CP is different from flying 45 degrees FP. For FBL FP or 90 degrees FP, they're quite similar to 130x. That's my 2c. FYI, I had flew 45 degrees FP (NE solo), 90 degrees FP (4#6), 90 degrees CP (4G6S, Trex250), and FBL CP (v120d02s)... Hope this helps... |
Sydney, Australia
Joined Dec 2008
Getting a little off topic here, but have you tried flybarless? Converted my 450 recently, and rebuild times and costs are now dramatically reduced. Once you're past the initial setup, most crash repairs involve little more than replacing a main gear, bent shaft and blades, and then checking your blade tracking. All that fiddley, sloppy flybar stuff that takes all day to tune is gone and is replaced with two simple links.
Toronto Canada
Joined Dec 2002
Some have also successfully set up the MCPx and other helis as fixed pitch helis by using a flat pitch curve on their transmitter. |
Joined Aug 2007
My point is that a symmetrical blade does not automatically REQUIRE a higher headspeed to get similar lift to a FP blade. You can run a FP blade and a CP blade at the same RPM and get similar lift, but the blades' angle of attack could be different. You may be correct in saying that for a given blade angle a symmetrical blade may require a higher headspeed for a given amount of lift compared to a FP blade. But that is not a rule. When a symmetrical blade is generating lift, it is actually acting as an asymmetric (or FP) blade. The advantage to a symmetrical blade is that it will generate the same amount of thrust relative to the blade disk for a given positive or negative blade angle, just the direction of the lift is different. There are a number of other reasons why you might run the head faster (more stability, faster response, etc.). You also might run the head slower if you wanted to reduce the damage because of a blade strike or to reduce the size of the servos required. Different helicopters will have a different sweet spot regarding head speed, stability, control response, and energy consumption. Having the highest headspeed possible is not automatically the best answer in all cases. You could end up making the helicopter too stable (say for 3D), having high speed airflow problems near the blade tips, or requiring servo forces that exceed the available servo size. |
Joined Feb 2011
I think the point has been made that no matter how you slice it the 130X will handle significantly different than a 45 degree flybar.
Yes there was a time in the dark ages when a 450 sized heli was considered small and people started out on big 60 size nitro powered helicopters. You can still do that, but the learning curve is steep and the price of failure is severe. A man was killed at my local flying field when a heli got away from him and struck his instructor, so this is not a game. http://rc.runryder.com/helicopter/t70830p1/ |
Joined Apr 2010
Think about it - Why do our fan has the FP like curve? Fan maker could just slap a 45 degrees angled blade and spool it up if curved and flat structure displaces as much air. And no, adding headspeed will not cause the heli to be "too stable". The reason you think that way is you're too used to self stabilizing heli (45 d flybar). Stability in CP is defined in how much control you have over the heli (ie how responsive). |
Sydney, Australia
Joined Dec 2008
You can try Clearview. It's a relatively small download, and it runs for about 10 minutes for free, then you need to pay $40 to register. Also, Pheonix has a free demo download that you can only watch, not fly, but it would give you a pretty good indication if your computer can handle the graphics.
| Thread Tools | |
| For Sale New in the box E-Flite Taylorcraft ARF Kit plus High Performance E-Flite components | Philscho | Aircraft - Electric - Airplanes (FS/W) | 4 | Aug 19, 2012 12:25 AM |
| For Sale E-Flite 300 32e SHP ****SOLD*** E-Flite still aviable | tomtheman | Aircraft - Electric - Airplanes (FS/W) | 2 | Mar 28, 2012 08:01 PM |
| Sold E-flite 60A ESC w/ E-flite Brushless 1010kV Motor | joshfneptune | Aircraft - Electric - Power Systems (FS/W) | 3 | Mar 05, 2012 08:18 PM |
| Discussion E-Flite Taylorcraft 450 ARF Kit and High Power E-Flite electrical components $300 | Philscho | Hot Online Deals | 1 | Mar 02, 2012 08:11 PM |
| Discussion E-Flite Su-26 and E-flite Extra 260 repair | Joe Slow | Crash Discussion | 1 | Sep 27, 2011 11:50 AM |
