Apr 12, 2012, 11:24 PM
Canada, BC, Salmon Arm
Joined Jan 2011
Originally Posted by waltoninn
I ve had my Swift T34 Helicopter since Christmas, but only started using it 2 days ago because the weather is just now right for flying. Having trouble getting the helo off the ground. Feels and sounds like not enough power. New batteries in the controler and battery in the bird is fully charged by the green light on the charger. There is a big power boost when the left and right trim knob is turned fully to the left. I m still very new to flying these, so I ve reset everything to the factory default, and still won t get off the ground. Anyone having the same trouble? anyone that can give me help or point me in the right direction, it would be much appreciated. Thanks again
If you have a tester check that you have about 8.4V when charged. Also check each cell on the balance plug to see if they are each ~4.2V, ie 'balanced'. If the cells have significantly different voltages, it can cause your symptoms, and the battery should be replaced.
For long term storage I fly a fully charged battery about 2 minutes. That gets them pretty close to a good storage voltage of about 3.8 to 3.9V per cell. There are a lot of opinions about correct storage voltage but in th 3.75 to 3.9V range per cell (or 7.6 to 7.8V total for your T34 battery) I have stored several for 1+ year with no apparent capacity loss.
Also, make sure you have the correct blades on the top and bottom and that there is absolutely no damage to the safety edge, or the heli will not fly.
Let us know how it goes.
regards . . . g
