Old Apr 11, 2012, 08:05 PM
pmpjohn is offline
Find More Posts by pmpjohn
Dr John
pmpjohn's Avatar
Lake Placid, Florida
Joined Dec 2001
F15 twin 50mm
Here are a couple of pics of the F15 I just maidened. Airframe is all laser cut Depron. My good friend Joe1320 convinced me the J Power 50mm fans, that I had two of, could actually make pretty good thrust and even handle 4s. So, that is what is powering this F15. I am useing a pair of Turnigy 20 amp esc's, two hs55's and an AR6100 rx. The first flights were made useing an 1800mah 3s nanotech pack but a larger batt is in order as the 1800 got pretty warm.
WS= 24" Length = 36" AUW w/1800 = 532gr 137 sq in wing area
A hand launch into a 10mph breeze was a non-event and she flew right out. A few clicks of up and left had her flying hands off. While not super fast on 3s, about 60 mph, she makes good thrust and will maintain a 60deg angle of climb until I backed out as she was getting small Rolls are fairly axial considering I am useing tailerons only for control. She is stable and predictable with a great dead stick glide path on landing. I have no doubt she will carry a larger batt, a coat of paint and an ordinance load.
John
pmpjohn is offline Find More Posts by pmpjohn
Old Apr 12, 2012, 08:06 PM
killer vtwin is offline
Find More Posts by killer vtwin
birmingham Al.
Joined Aug 2005
very cool
killer vtwin is offline Find More Posts by killer vtwin
Old Apr 12, 2012, 09:50 PM
pmpjohn is offline
Dr John
pmpjohn's Avatar
Joined Dec 2001
Thanks killer
I am leaning towards the Bicenntenial Thunderbirds livery as it is light, high visibility and I already have the artwork as used on my F15umx pusher jet shown here.
John
Old Apr 14, 2012, 08:16 AM
pmpjohn is offline
Dr John
pmpjohn's Avatar
Joined Dec 2001
A bit easier to see in the sky now The last flights have been made with a 4s 2200mah pack. The larger pack stays much cooler than the 3s 1800mah pack used on the first flights. Performance is also noticably better, about 10mph increase in top speed and she will really stand on her tail now.
John
Old Apr 14, 2012, 01:41 PM
Joe 1320 is offline
Find More Posts by Joe 1320
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
John, is this the revision, or the CAD file I have?
looks great! I think I might need to do V2 if I am going to do the afterburnerz.
Joe 1320 is offline Find More Posts by Joe 1320
Old Apr 14, 2012, 02:10 PM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
Given the availability of the JPower 50mm fan and motors, this could be a great kit for those used as twins. Twin EDFs, light weight, unlimited vertical, slows down nice. You could also add couple ailerons if the need arises. Fans are readily available, and dare I say it..... you could step it up to 4s and it would be such a rocket.......
You know me, guess which direction I'm going. 4s on those fans should consume 42-43 amps on average for a total of at least 550 watts. I think I would like to try a 4s 1800 mAh 40C lipo. It might not be heavy enough. Wide open will just be in burts anyways.
Old Apr 14, 2012, 02:40 PM
splitpilot is offline
Find More Posts by splitpilot
splitpilot's Avatar
trying to catch Mr. FrSky... It flyes
Joined Jan 2005
Really nice, got another kit to share!
splitpilot is offline Find More Posts by splitpilot
Old Apr 14, 2012, 02:41 PM
pmpjohn is offline
Dr John
pmpjohn's Avatar
Joined Dec 2001
Joe
This one was cut from the drawings you have. The revisions have not been loaded onto the thumb drive yet. I can email you the updates if you would like them. You could export them as a DXF and take that file to the Arcitectural place you drive past twice a day and get full size print outs. Then you can wear out a half a box of #11 blades or wait for me to get back in the fall and cut you a kit.
John
Old Apr 14, 2012, 03:02 PM
pmpjohn is offline
Dr John
pmpjohn's Avatar
Joined Dec 2001
PM replied to
John
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
Originally Posted by pmpjohn View Post
Joe
John
What arcitectural place? I'm usually busy watching the road.
yeah.... I'm not going to be cutting one any time soon. I still need to put together the Yak, another A-7, the micro F4D, etc. Once I sort out the F4d system, I'll let you know the results. I think it may work with an ultra micro brick and a 5g brushless motor.
Old Apr 14, 2012, 03:05 PM
pmpjohn is offline
Dr John
pmpjohn's Avatar
Joined Dec 2001
In the little strip mall across 27 from Veterans Park. At the north end. They have a large format printer.
John
Old Apr 14, 2012, 03:07 PM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
John
Gotcha. Thanks, may have to keep that in mind..... have an idea for something large.
Wanted Sky Angel 50mm SU-34 Twin wyldkrd Aircraft - Electric - Jets (FS/W) 2 Nov 15, 2011 04:03 PM
Discussion Twin micro fan F15 Cosmo21 Electric Ducted Fan Jet Talk 4 Oct 31, 2006 05:04 PM
Gallery El' Cheapo F15 Twin EDF MattinAZ Electric Ducted Fan Jet Talk 34 Dec 30, 2005 11:47 AM
F15 Twin EDF Blue Foam MattinAZ Foamies (Kits) 0 Dec 20, 2005 11:43 PM
F15 Twin EDF ARF fvbreemen Electric Ducted Fan Jet Talk 35 Aug 21, 2003 03:21 PM
