Old Apr 11, 2012, 07:21 PM
motor12 is offline
Find More Posts by motor12
motor12's Avatar
United States, TX, Austin
Joined Jan 2010
Yippee!
Hangar 9 Taylorcraft electric conversion
Just thought i would post a photo of my just completed 80 in. Taylorcraft.It was a simple conversion and the kit was outstanding. I used an E-flite power 160 with a Phoenix HV110 speed controller and an XOAR 18x10 prop it all runs on 10S. The CG was almost dead on, only had to make a small adjustment. Thanks.
motor12 is offline Find More Posts by motor12
Old Apr 11, 2012, 09:24 PM
Thrawn150 is offline
Find More Posts by Thrawn150
Thrawn150's Avatar
USA, IL, Oak Lawn
Joined Apr 2007
looks great. What is the weight and and how many watts you got going on? I am just starting a conversion of a H9 p-51 80" wing. Same setup.
Thrawn150 is offline Find More Posts by Thrawn150
Old Apr 12, 2012, 08:33 AM
motor12 is offline
motor12's Avatar
Joined Jan 2010
Thrawn150 thanks, the weight is just shy of 16 lbs ready to fly.As of this post i have not yet put my watt meter in line to get a reading, but i am going to do so shortly and will post my results.
Old Jun 07, 2012, 07:01 AM
bigmoebbq is offline
Find More Posts by bigmoebbq
bigmoebbq's Avatar
United States, GA, Atlanta
Joined Mar 2008
What kind of flight times are you getting. I just got this plane and cant decide to go electric or gas. You said 10s but how many MAH? nice clean Electric would be awesome!
I have the power 160 laying around, ztw100HV esc, Castle BEC PRO, with all the accessories. Should I use the stock Servos? spektrum 6000's or upgrade them? I am a 3d guy mostly so I am hoping to do some mild acrobatics with this plane.
bigmoebbq is offline Find More Posts by bigmoebbq
Old Jun 11, 2012, 08:56 AM
Thrawn150's Avatar
USA, IL, Oak Lawn
Joined Apr 2007
Also can you take a pic of your battery bay? When ever someone does a e-conversion always curious about how the batteries are setup.
Old Jun 22, 2012, 12:23 PM
motor12 is offline
motor12's Avatar
Joined Jan 2010
Sorry to take so long to get back to my post. Here are some numbers on my set up .
Amps=59
Volts= 41.97
Watts= 2291
this is about 147 watts per pound. thats with a Power160 on 10s (6s+4s)5000 turning an 18x10 Xoar prop. my servos are hitec HS-485HB. I have my timer set at seven min. and land with about 1/2 left on batteries. This set up has plenty of power and the airplane will climb straight up.
For Sale Hanger 9 Clipped Wing Taylorcraft ARF Mad Man Marko Aircraft - Fuel - Airplanes (FS/W) 4 Feb 06, 2012 03:16 PM
Wanted Hanger 9 Clipped Wing Taylorcraft ARF grantypoo Aircraft - Fuel - Airplanes (FS/W) 4 Feb 05, 2012 10:08 PM
For Sale Hanger 9 Clipped Wing Taylorcraft ARF Mad Man Marko Aircraft - Fuel - Engines and Accessories (FS/W) 2 Jan 31, 2012 02:11 PM
Wanted Hanger 9 Taylorcraft headshot001 Aircraft - Electric - Airplanes (FS/W) 0 Dec 03, 2011 10:01 AM
Sold Taylorcraft hanger 9 mint! matthew james Aircraft - Fuel - Airplanes (FS/W) 13 Nov 10, 2011 07:01 PM
